- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
in the text to 20.8.3 SRC Reset Status Register SRC_SRSR is written that the register is write one to clear.
The graphical view of the register
shows that bit 0 to 7 are write one to clear but the tempsense_rst_b is not.
Is the picture or is the text not correct?
Kind regards,
Stefan
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Jeremy,
thank you for your reply. I figured out that the tempsense_rst_b is not write one to clear so the figure is correct. It is not the complete register write one to clear.
Kind regards,
Stefan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Stefan Mitterhauser ,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
1) Is the picture or is the text not correct?
-- No, it's correct.
TIC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Jeremy,
Kind regards,
Stefan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for your reply and I was wondering if you can upload your demo code and introduce the testing procedure, as I'd like to verify it by myself prior to reporting.
TIC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Jeremy,
I realized that there is an example project src_reset_source and the driver fsl_src.c. I only verified that the driver function SRC_ClearResetStatusFlags() does clear the tempsense_rst_b bit by writing zero to it and not by writing one.
Kind regards,
Stefan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for your reply and I've verified it.
The text information about the SRC Reset Status Register SRC_SRSR needs to be corrected to keep consistent with the figure and SRC_ClearResetStatusFlags() function.
TIC
