Debug issue on imxrt1176
745 次查看
smartpavan333
I am using MiMXRT1176 board in MCU IDE. When I run the customize code with CMSIS DAP debugger , it's working fine. But on power reset, its getting stuck in middle of the code(i.e. code consists of Display code and CAN code. On power reset, code is getting stuck after display code) and again if we reconnect the debugger cable, it's working properly. I am not getting where I have gone wrong.
Can you help with this issue?
Pavan
710 次查看
Pavel_Hernandez
Could you give me a clarification about the "MiMXRT1176 board" is it a custom board or you are working on an evaluation board?
And when you mentioned, "reconnect the debugger cable" when did you remove the cable?
Pavel
