Communication protocol between IMX8 and RT1052
jiaxin
Hi,sir
Requirements:
The system requires data interaction between RT1052 and IMX8, and the wider the rate, the better
What is the maximum bandwidth communication mode between imx8 and RT1052?
Omar_Anguiano
The bandwidth will depend on the protocol used for communication.
You can opt to use LPSPI or ethernet for the communication between devices.
Omar
Omar_Anguiano
Omar
jiaxin
The amount of data each interaction between the two chips is 512 bytes, and the less time spent, the better
%3CLINGO-SUB%20id%3D%22lingo-sub-1895813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECommunication%20protocol%20between%20IMX8%20and%20RT1052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1895813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2Csir%3C%2FP%3E%3CP%3ERequirements%3A%3CBR%20%2F%3EThe%20system%20requires%20data%20interaction%20between%20RT1052%20and%20IMX8%2C%20and%20the%20wider%20the%20rate%2C%20the%20better%3C%2FP%3E%3CP%3EWhat%20is%20the%20maximum%20bandwidth%20communication%20mode%20between%20imx8%20and%20RT1052%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1899817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Communication%20protocol%20between%20IMX8%20and%20RT1052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1899817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20bandwidth%20will%20depend%20on%20the%20protocol%20used%20for%20communication.%3CBR%20%2F%3EYou%20can%20opt%20to%20use%20LPSPI%20or%20ethernet%20for%20the%20communication%20between%20devices.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EOmar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1896249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Communication%20protocol%20between%20IMX8%20and%20RT1052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1896249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20amount%20of%20data%20each%20interaction%20between%20the%20two%20chips%20is%20512%20bytes%2C%20and%20the%20less%20time%20spent%2C%20the%20better%3C%2FP%3E%3C%2FLINGO-BODY%3E
