I want to start to use the RT1170. I'm thinking of buying the MIMXRT1170-EVK evaluation board for the development. But I need to connect multiple microphones to the PDM pins of the RT1170. I can not find out if these pins are accessible.
I found the schematic of the MIMXRT1170-EVK board. But the PDM pins are not mentioned. The reference manual does not tell me which pins to look for.
Any advice how to do this?
Solved! Go to Solution.
Ah, found it. I didn't look good enough.
In the reference manual chapter 11 about pin multiplexing you can find the pin candidates for those pins.
And so I found the signals on the evaluation board. There are even microphones on the board!
