I'm using the CST tool to encrypt the image and trying to use the HAB API to decrypt that
However, I found the CST tool needs to reference the CSF file.
The CSF file describes the SRK information and certificate.
but when I run the CST tool to generate csf.bin. The size is around 7K always.
Is there any idea to reduce the bin.csf file size?
Thank you.
