I'm using following code for brownout detection. I included fsl_pmu.h and fsl_pmu.c in the code. However, I observed that IRQ is not getting served. Kindly suggest the corrections in the code.
解決済! 解決策の投稿を見る。
Please refer to this post to turn on the brownout detector: Solved: Re: How to enable brownout detection - NXP Community
These fields do not apply to the device even when accessing through CCM registers since they share space.
Please refer to the driver, it uses different registers to enable and set the BO.
Omar
Omar
