Azure NetX network driver for ENET_QOS peripheral
DrJonM
Are there any example network drivers for Azure NetX duo for the ENET_QOS peripheral on the iMX.RT1176?
There is an example driver file nx_driver_imxrt.c in the SDK samples but this only covers the ENET and ENET_1G peripherals.
Jon
nxf77486
Thank you for contacting NXP support.
In this case unfortunately we only have the for Azure NetX Duo what is available on the latest version of the SDK. But I would highly recommend going to the Azure Community and asking the creators themselves, as they would most likely be able to provide you probably an example you require.
