Generating a Bootable Image for the RT1050
Testing Boot times – Generating a bootable image
Bootable Image Structure:
The bootable image consists of:
  • FlexSPI Configuration Block (FCB)
  • Image Vector Table (IVT)
  • Boot Data
  • Device Configuration Data (DCD)
  • Program image
  • CSF, Certificates, and signatures (this stuff is optional and only comes with high-assurance boot
I’ll briefly explain each below:
The FCB will configure the settings of the FlexSPI communication. It will establish how many ports will be used, what clock speed to run the FlexSPI controller at, etc. This is the first thing that happens, as everything else is stored in Flash memory. In order to read anything else, the flash must first be configured.
The IVT is a table that tells the memory the addresses of where everything is stored.
Boot Data
The Boot Data contains pointers to the start address of the Memory.
The DCD contains configuration data to configure any peripherals.
Program image
The program image contains the code you write to go into the application.
These things are optional. They come with high-assurance boot sequence and will not be covered in this writeup.
Below is a rough table outlining these different parts of the boot image:
Bootable Image generation software / tools:
  1. MCUXpresso – download the MCUXpresso IDE
  2. Flash Loader – download from RT1050 page > software and tools > flashloader
  3. This entire folder will include the MFGTool, elftosb tool, and more documentation.
  4. DCD.bin file: I found mine included in this document: https://community.nxp.com/docs/DOC-340655
Bootable Image Generation Overview
MCUXpresso can generate bootable images for Hyperflash and QSPI XiP, but if trying to boot and execute in place of SDRAM or intern SRAM, or from your own memory module, then you must generate a bootable image by through a combination of generating an s record or elf image on MCUXpresso, and then using the flashloader tool suite (elftosb and mfgtool) to create a bootable image and then a bootable program to upload to the board.
The entire general process is described below. In subsequent sections, a more detailed step-by-step guide is provided for Hyperflash XiP, SDRAM, and SRAM, each.
MCUXpresso Configurations and output:
Begin with your application code in MCUXpresso. Change memory allocation in the memory configuration editor of the MCU Settings part of MCUXpresso according to where you would like to boot from. If applicable, be sure to specify in the preprocessor settings if you would like to enable the dcd in the boot image.
Generate an s-record (.s19) file from MCUXpresso using binary utilities.
Elftosb tool – .bin file generation
You can find this tool in the flashloader. Call an imx command to it which will take as input the s-record file containing the program image, a dcd.bin file (may or may not be in the s-record), a FCB?, and a bd_file (given to you, specific to your memory configuration). The elftosb tool will generate as an output a .bin file.
Elftosb tool – Bootable image generation
Then call the elftosb tool again with a kinetis command. This will take the .bin file and convert it to a boot_image.sb file.
MFG tool
Then we can use the mfg tool to generate the program image for the board, and upload it.
In order to do this, the board SW7 must be set to OFF-ON-OFF-ON, and switch the jumper from J1  (5-6) to J1 (3-4). Connect the USB cable to J9 to power the board. Then connect the board to your computer and run the Mfg tool. Click start and the image will be uploaded.
After this the bootable image will be uploaded to the board and you’ll be good to go!
Remember to switch the pin headers back, so the board can boot normally. J1 (5-6) and SW7 to OFF-ON -ON -OFF to boot from Hyperflash.
Now in the following sections I’ll break down specific examples of what to do depending on the specific memory location you’d like to boot from.
Bootable Image Generation – XiP Hyperflash
Please note that this can also be done in MCUXpresso, but In order to use my own dcd file, I did this project using the traditional flashloader tools.
Begin by changing memory allocation in the memory configuration editor (edit project settings >> C/C++ Build >> MCU settings >>edit. It should look like the one below.
Then go to C/C++ Build >>settings > MCU C compiler > preprocessor and set the XIP_boot_header enable and and XIP_boot_header_DCD_enable both to 0 if you have a dcd.bin file to use. Otherwise set these fields to 1.
Hit apply and close.
Go to the debug portion and click on binary utilities, then generate an s-record (.s19) file from MCUXpresso.
Click build to re-build the project.
Copy this .s19 file.
In the flashloader tool, go to Tools > elftosb > Win, and drop the .s19 file in this folder, as well as the dcd.bin file.
Fire up command prompt in administrator mode, and use command cd [elftosb directory] to get to this folder
To generate the .bin file, call the command:
elftosb.exe -f imx -V -c ../../bd_file/imx10xx/imx-flexspinor-normal-unsigned-dcd.bd -o ivt_flexspi_nor_led_blinky.bin HYPERFLASH_led_blinky.s19
This command essentially uses the imx-flexspinor bd linker file to generate a .bin file that will include the dcd.bin header inside. Note that HYPERFLASH_led_blinky.s19 should be renamed to your actual file name acquired from MCUXpresso
Then we must generate the boot_image.sb
The command is:
elftosb.exe -f kinetis -V -c ../../bd_file/imx10xx/program_flexspinor_image_hyperflash.bd -o boot_image.sb ivt_flexspi_nor_led_blinky_nopadding.bin
Note: The output of the first imx command we made must match the input of this one (ivt_flexspi_nor_led_blinky_nopadding.bin). Also, the output must remain named boot_image.sb, otherwise it will not work.
MFG tool
Copy the boot_image.sb file that we created in the last step. Move it to the directory Tools > mfgtools-rel > Profiles > MXRT105X > OS Firmware, and drop it in here.
Next, set SW7 on the board to OFF-ON-OFF-ON, and switch the jumper at the bottom to power the board. Then connect the USB cable to J9. This will allow you to program the board.
Go back to the folder mfgtools-rel and Open the Mfg Tool. It should say HID- compliant vendor-defined device. Otherwise double check SW7 and the power pin at the bottom right.
Click start and if successful it should look like:
Please note that this success only means that it was able to upload the bootable image to the board. This usually works well. However, if you find later that the board doesn’t do what it’s supposed to, then there might be a problem in the other steps of the processor. Check to make sure you used the right linker file, and that the settings in MCUXpresso are configured correctly.
Press stop and exit
Bootable Image Generation – SDRAM
The guide is based off this link: https://community.nxp.com/docs/DOC-340655 . Download the files provided there, and unzip. Everything is good except the first step of that pdf document is a little unclear.
Begin by changing memory allocation in the memory configuration editor of the MCU Settings part of MCUXpresso. It should look like the one below.
Then go to settings > MCU C compiler > preprocessor and set the XIP_boot_header enable and and XIP_boot_header_DCD_enable both to 0
Go to C/C++ Build >> Settings >> MCU Linker >> Manage linker script, and check the box Link application to RAM.
You can check the console to verify the correct allocations of memory:
There’s another step for booting from SDRAM. Take the file imx-sdram-normal-unsigned-dcd.bd (included in the link posted) and drag it into Tools > bd_file > imx10xx
elftosb.exe -f imx -V -c ../../bd_file/imx10xx/imx-sdram-normal-unsigned-dcd.bd -o evkbimxrt1050_led_blinky.bin SDRAM1_led_blinky.s19
The command is:
elftosb.exe -f kinetis -V -c ../../bd_file/imx10xx/program_flexspinor_image_hyperflash.bd -o boot_image.sb evkbimxrt1050_led_blinky_nopadding.bin
The output of the first imx command we made must match the input of this one. Also, the output must remain named boot_image.sb, otherwise it will not work. Also note that this says flexspinor image hyperflash, but that is correct since we are still technically needing to boot from Hyperflash initially before we copy everything over to SDRAM.
Copy the boot_image.sb file.
MFG tool
Press stop and exit
Bootable Image Generation – SRAM
This one was a little trickier as there was no appnote, but not too bad.
Begin by changing memory allocation in the memory configuration editor of the MCU Settings part of MCUXpresso. It should look like the one below. We are linking to copy everything to dtc RAM
You can verify that application is linked to SRAM in the console:
This step is specific to dtcm ram: Go to Tools >>bd_file >> imx10xx, and open up the imx-dtcm-unsigned-dcd.bd file and change the ivtOffset address to 0x1000. 0x400 is the default for SDCARD booting.
To be clear, the bd file should look as below:
elftosb.exe -f imx -V -c ../../bd_file/imx10xx/imx-dtcm-unsigned-dcd.bd -o evkbimxrt1050_led_blinky.bin SRAM1_led_blinky.s19
This command essentially uses the imx-flexspinor bd linker file to generate a .bin file that will include the dcd.bin header inside. Note that SRAM_led_blinky.s19 should be renamed to your actual file name acquired from MCUXpresso.
The command is:
MFG tool
Press stop and exit
Please note that this success only means that it was able to upload the bootable image to the board. This usually works well. However, if you find later that the board doesn’t do what it’s supposed to, then there might be a problem with the other steps of the processor. Check to make sure you used the right linker file, and that the settings in MCUXpresso are configured correctly.
コメント
Hello, very interesting document.
Its possible also apply run software from SDRAM, with boot from SD or QSPI ?
These instructions are also useful for RT1020 or only for RT1050 ?
Hi Manuel, thank you for this interesting document.
Unfortunately elftosb crashes when I attempt to create the binaries. It keeps looking for "section 0x0", although the addresses in the S19 file are correct. This happens both with SDRAM and internal RAM version.
Giuseppe
In the end, I discovered that my flashloader has some problems.
Today I was able to create an image, write it in flash and run it in SDRAM.
Later, we were also able to have MCUXpresso create the binary image (no flashloader). You need to load it to the right location via Segger Ozone, but everything works well.
Manuel, if you ever pass in Firenze, there is a free beer for you ;-)
Giuseppe
You can also try this tool, with this tool, You can flash bare image into various boot devices easily and don't need to care about headers (ivt, boot data...)
GitHub - JayHeng/nxp-sec-boot-ui: A one-stop GUI tool to work with NXP MCU (Kinetis, i.MXRT, LPC) RO...
Why we need .s19 file.
Adrian,
In my Flashloader download, I don't see any of the "-dcd"  bd files  that you used.
Ive been banging my head against the wall for the past three days.  RT1050-EVKB.  I can download images happily via MCUXpresso.  I have been able to create images that I burn into flash, that are copied into either DTC or ITC ram.  I use either NXP-MCUBootutility or MCUXpresso Secure provisioning tool.  Both work for me.  Next on the list is creating images that XIP and run from SDRam.  I have tried every thing that I have found - NG. I can take the sample images from the provisioning tool: evkbimxrt1050_iled_blinky_ext_FLASH and evkbimxrt1050_iled_blinky_SDRAM, and burn these, and have them run.  So its not my toolset - its obviously something Im doing wrong or not doing.  I have SDK ver 2.3.  The guides look really simple, but I must be missing something on each.  Thoughts?  If I were to ask for somewhere to start, it would be give me the steps to get an XIP image built and downloaded, using MCUXpresso.  Which compiler defs need to be set.  I know I have to have the image running at 0x60002000, with the flash as the top item.  What else is there?
Thanks in advance.
Larry
EDIT:
   OH MY GOD!!! I will tell you what else there is: The MCUXPresso IDE doesnt know that it isnt the latest version!!!!!!!!!!!!!!!!!!  I've been using V10.3 for a year now, for another project.  I have REPEATEDLY had it check for updates, and it said there were none available.  It doesnt know that there is a version 11.1 available.  And RT1050 SDK v 2.7 works with that and automatically provides all of the flash burning functionality!!!  WOW!  RT1050 SDK2.3 does not.
%3CLINGO-SUB%20id%3D%22lingo-sub-1123079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1050%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-382421616%22%20id%3D%22toc-hId-1303143159%22%3E%E3%83%96%E3%83%BC%E3%83%88%E6%99%82%E9%96%93%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%E2%80%93%20%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-1072983090%22%20id%3D%22toc-hId-1993704633%22%3E%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%A7%8B%E9%80%A0%EF%BC%9A%3C%2FH2%3E%3CP%3E%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EFlexSPI%20%E8%A8%AD%E5%AE%9A%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%88FCB%EF%BC%89%3C%2FLI%3E%3CLI%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20(IVT)%3C%2FLI%3E%3CLI%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%88DCD%EF%BC%89%3C%2FLI%3E%3CLI%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FLI%3E%3CLI%3ECSF%E3%80%81%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%80%81%E7%BD%B2%E5%90%8D%EF%BC%88%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%80%81%E3%83%8F%E3%82%A4%E3%83%BB%E3%82%A2%E3%82%B7%E3%83%A5%E3%82%A2%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%96%E3%83%BC%E3%83%88%E3%81%A7%E3%81%AE%E3%81%BF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%B0%A1%E5%8D%98%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1763544564%22%20id%3D%22toc-hId--1610701189%22%3EFlexSPI%20%E8%A8%AD%E5%AE%9A%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%88FCB%EF%BC%89%3C%2FH3%3E%3CP%3EFCB%E3%81%AFFlexSPI%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E6%95%B0%E3%80%81FlexSPI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E9%80%9F%E5%BA%A6%E3%81%AA%E3%81%A9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9A%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20style%3D%22font-weight%3A%20bold%3B%22%20id%3D%22toc-hId--43909899%22%20id%3D%22toc-hId-876811644%22%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%EF%BC%88IVT%EF%BC%89%3C%2FH3%3E%3CP%3EIVT%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E4%BC%9D%E3%81%88%E3%82%8B%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1851364362%22%20id%3D%22toc-hId--930642819%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%3C%2FH3%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E3%81%AF%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E9%96%8B%E5%A7%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%B8%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-636148471%22%20id%3D%22toc-hId-1556870014%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%88DCD%EF%BC%89%3C%2FH3%3E%3CP%3EDCD%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1171305992%22%20id%3D%22toc-hId--250584449%22%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FH3%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%80%E3%82%88%E3%81%86%E3%81%AB%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1316206841%22%20id%3D%22toc-hId--2058038912%22%3ECSF%E3%80%81%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%80%81%E7%BD%B2%E5%90%8D%3C%2FH3%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E3%83%8F%E3%82%A4%E3%83%BB%E3%82%A2%E3%82%B7%E3%83%A5%E3%82%A2%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%A7%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%90%84%E9%83%A8%E5%88%86%E3%82%92%E5%A4%A7%E3%81%BE%E3%81%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%9F%E6%A6%82%E7%95%A5%E5%9B%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20562px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63209iF36619076CC1CF86%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1305703737%22%20id%3D%22toc-hId--2068542016%22%3E%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E7%94%9F%E6%88%90%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%EF%BC%8F%E3%83%84%E3%83%BC%E3%83%AB%EF%BC%9A%3C%2FH2%3E%3COL%3E%3CLI%3EMCUXpresso%20%E2%80%93%20MCUXpresso%20IDE%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLI%3E%3CLI%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%20%E2%80%93%20RT1050%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%20%26gt%3B%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%83%84%E3%83%BC%E3%83%AB%20%26gt%3B%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%81%AF%E3%80%81MFGTool%E3%80%81elftosb%E3%83%84%E3%83%BC%E3%83%AB%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3EDCD.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9A%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%93%E3%81%A1%E3%82%89%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-340655%22%20target%3D%22_blank%22%3Ehttps%EF%BC%9A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-340655%3C%2FA%3E%3C%2FLI%3E%3C%2FOL%3E%3CH2%20id%3D%22toc-hId--501750726%22%20id%3D%22toc-hId-418970817%22%3E%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E4%BD%9C%E6%88%90%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FH2%3E%3CP%3EMCUXpresso%E3%81%AF%E3%80%81Hyperflash%E3%81%8A%E3%82%88%E3%81%B3QSPI%20XiP%E7%94%A8%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81SDRAM%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%85%E9%83%A8SRAM%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%8B%E3%82%89%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81MCUXpresso%E3%81%A7S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AFELF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B9%E3%82%A4%E3%83%BC%E3%83%88%EF%BC%88elftosb%E3%81%8A%E3%82%88%E3%81%B3mfgtool%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%81%86%E3%81%88%E3%81%A7%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E4%BB%A5%E4%B8%8B%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AE%E5%85%A8%E4%BD%93%E3%81%AE%E6%B5%81%E3%82%8C%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81Hyperflash%20XiP%E3%80%81SDRAM%E3%80%81SRAM%E3%81%AE%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%82%88%E3%82%8A%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%BB%E3%83%90%E3%82%A4%E3%83%BB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%BB%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FEM%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--506352731%22%20id%3D%22toc-hId-414368812%22%3EMCUXpresso%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E5%87%BA%E5%8A%9B%3C%2FH3%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%81%AF%E3%80%81MCUXpresso%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MCUXpresso%E3%81%AE%20%5BMCU%20Settings%EF%BC%88MCU%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%E9%83%A8%E5%88%86%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%87%E3%82%A3%E3%82%BF%E3%81%A7%E3%80%81%E8%B5%B7%E5%8B%95%E5%85%83%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7dcd%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%83%97%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E8%A8%AD%E5%AE%9A%E3%81%A7%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81MCUXpresso%E3%81%8B%E3%82%89S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%88.s19%EF%BC%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1981160102%22%20id%3D%22toc-hId--1393085651%22%3EElftosb%E3%83%84%E3%83%BC%E3%83%AB%20%E2%80%93%20.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E7%94%9F%E6%88%90%3C%2FH3%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82imx%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%90%AB%E3%82%80S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81dcd.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E3%81%82%E3%82%8B%EF%BC%89%E3%80%81FCB%3F%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3bd_file%EF%BC%88%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%EF%BC%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82elftosb%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-173705639%22%20id%3D%22toc-hId-1094427182%22%3EElftosb%E3%83%84%E3%83%BC%E3%83%AB%20%E2%80%93%20%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E7%94%9F%E6%88%90%3C%2FH3%3E%3CP%3E%E7%B6%9A%E3%81%84%E3%81%A6%E3%80%81kinetis%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6elftosb%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E5%86%8D%E5%BA%A6%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8Cboot_image.sb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1633748824%22%20id%3D%22toc-hId--713027281%22%3EMFG%E3%83%84%E3%83%BC%E3%83%AB%3C%2FH3%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81MFGTool%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AESW7%E3%82%92OFF-ON-OFF-ON%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%82%92J1%EF%BC%885-6%EF%BC%89%E3%81%8B%E3%82%89J1%EF%BC%883-4%EF%BC%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92J9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81MFGTool%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%5BStart%EF%BC%88%E9%96%8B%E5%A7%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20307px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75204i7FDA579C86D9C6EE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E6%BA%96%E5%82%99%E3%81%AF%E5%AE%8C%E4%BA%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%94%E3%83%B3%E3%83%BB%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E5%BF%85%E3%81%9A%E5%85%83%E3%81%AB%E6%88%BB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Hyperflash%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81J1%EF%BC%885-6%EF%BC%89%E3%81%A8SW7%E3%82%92OFF-ON-ON-OFF%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%84%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%8D%E7%BD%AE%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%E4%BD%95%E3%82%92%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%AE%E5%85%B7%E4%BD%93%E4%BE%8B%E3%82%92%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%AC%E6%98%8E%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-724681290%22%20id%3D%22toc-hId-1645402833%22%3E%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E7%94%9F%E6%88%90%20%E2%80%93%20XiP%20Hyperflash%3C%2FH2%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AFMCUXpresso%E3%81%A7%E3%82%82%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AEdcd%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--953690454%22%20id%3D%22toc-hId--32968911%22%3EMCUXpresso%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E5%87%BA%E5%8A%9B%3C%2FH3%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%87%E3%82%A3%E3%82%BF%E3%81%A7%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%5BEdit%20project%20settings%EF%BC%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AE%E7%B7%A8%E9%9B%86%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BC%2FC%2B%2B%20Build%EF%BC%88C%2FC%2B%2B%E3%83%93%E3%83%AB%E3%83%89%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BMCU%20settings%EF%BC%88MCU%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BEdit%EF%BC%88%E7%B7%A8%E9%9B%86%EF%BC%89%5D%20%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63286i8759045661DD85EE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%5BC%2FC%2B%2B%20Build%EF%BC%88C%2FC%2B%2B%E3%83%93%E3%83%AB%E3%83%89%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BSettings%EF%BC%88%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%26gt%3B%20%5BMCU%20C%20compiler%EF%BC%88MCU%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%EF%BC%89%5D%20%26gt%3B%20%5BPreprocessor%EF%BC%88%E3%83%97%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%EF%BC%89%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8Bdcd.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81XIP_boot_header_enable%E3%81%A8XIP_boot_header_DCD_enable%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%920%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%921%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20441px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75183i38DEDE93A2245128%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%5BApply%20and%20Close%EF%BC%88%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E9%96%89%E3%81%98%E3%82%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E9%83%A8%E5%88%86%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%5BBinary%20Utilities%EF%BC%88%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81MCUXpresso%E3%81%8B%E3%82%89S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%88.s19%EF%BC%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63381i497052297DC72225%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%5BBuild%EF%BC%88%E3%83%93%E3%83%AB%E3%83%89%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%86%8D%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE.s19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1533822379%22%20id%3D%22toc-hId--1840423374%22%3EElftosb%E3%83%84%E3%83%BC%E3%83%AB%20%E2%80%93%20.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E7%94%9F%E6%88%90%3C%2FH3%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%80%81%5BTools%EF%BC%88%E3%83%84%E3%83%BC%E3%83%AB%EF%BC%89%5D%20%26gt%3B%20%5Belftosb%5D%20%26gt%3B%20%5BWin%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81.s19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8dcd.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%AE%A1%E7%90%86%E8%80%85%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%BB%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%80%8Ccd%20%5Belftosb%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%5D%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eelftosb.exe%20-f%20imx%20-V%20-c%20..%2F..%2Fbd_file%2Fimx10xx%2Fimx-flexspinor-normal-unsigned-dcd.bd%20-o%20ivt_flexspi_nor_led_blinky.bin%20HYPERFLASH_led_blinky.s19%20%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%80%81imx-flexspinor%20bd%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%86%85%E9%83%A8%E3%81%ABdcd.bin%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E5%90%AB%E3%82%80.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82HYPERFLASH_led_blinky.s19%E3%81%AF%E3%80%81MCUXpresso%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId--273632084%22%20id%3D%22toc-hId-647089459%22%3EElftosb%E3%83%84%E3%83%BC%E3%83%AB%20%E2%80%93%20%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E7%94%9F%E6%88%90%3C%2FH3%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81boot_image.sb%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%B6%9A%E3%81%84%E3%81%A6%E3%80%81kinetis%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6elftosb%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E5%86%8D%E5%BA%A6%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8Cboot_image.sb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eelftosb.exe%20-f%20kinetis%20-V%20-c%20..%2F..%2Fbd_file%2Fimx10xx%2Fprogram_flexspinor_image_hyperflash.bd%20-o%20boot_image.sb%20ivt_flexspi_nor_led_blinky_nopadding.bin%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E6%B3%A8%EF%BC%9A%3C%2FSTRONG%3E%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9Fimx%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%85%A5%E5%8A%9B%EF%BC%88ivt_flexspi_nor_led_blinky_nopadding.bin%EF%BC%89%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%87%BA%E5%8A%9B%E3%81%AFboot_image.sb%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%88%A5%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%A7%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--2081086547%22%20id%3D%22toc-hId--1160365004%22%3EMFG%E3%83%84%E3%83%BC%E3%83%AB%3C%2FH3%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81MFGTool%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AESW7%E3%82%92OFF-ON-OFF-ON%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%82%92J1%EF%BC%885-6%EF%BC%89%E3%81%8B%E3%82%89J1%EF%BC%883-4%EF%BC%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92J9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81MFGTool%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%5BStart%EF%BC%88%E9%96%8B%E5%A7%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20307px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63429i793759D2D6656B47%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%20boot_image.sb%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%20Tools%20%26gt%3B%20mfgtools-rel%20%26gt%3B%20Profiles%20%26gt%3B%20MXRT105X%20%26gt%3B%20OS%20Firmware%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AESW7%E3%82%92OFF-ON-OFF-ON%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E4%B8%8B%E9%83%A8%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92J9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emfgtools-rel%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E6%88%BB%E3%82%8A%E3%80%81MFGTool%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%5BHID-compliant%20vendor-defined%20device%EF%BC%88HID%E6%BA%96%E6%8B%A0%E3%81%AE%E3%83%99%E3%83%B3%E3%83%80%E5%AE%9A%E7%BE%A9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%89%5D%20%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SW7%E3%81%A8%E5%8F%B3%E4%B8%8B%E3%81%AE%E9%9B%BB%E6%BA%90%E3%83%94%E3%83%B3%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20433px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75182i30459A630501CFA5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%5BStart%EF%BC%88%E9%96%8B%E5%A7%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%A8%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20443px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63527iC12A10684CBC350C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E8%A8%80%E3%81%86%E6%88%90%E5%8A%9F%E3%81%A8%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E3%81%A0%E3%81%91%E3%81%AE%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%BE%8C%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%83%B3%E5%AE%9A%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E3%81%97%E3%81%84%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A8%E3%80%81MCUXpresso%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%5BStop%EF%BC%88%E5%81%9C%E6%AD%A2%EF%BC%89%5D%20%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%94%E3%83%B3%E3%83%BB%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E5%BF%85%E3%81%9A%E5%85%83%E3%81%AB%E6%88%BB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Hyperflash%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81J1%EF%BC%885-6%EF%BC%89%E3%81%A8SW7%E3%82%92OFF-ON-ON-OFF%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CH2%20id%3D%22toc-hId-277343567%22%20id%3D%22toc-hId-1198065110%22%3E%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E7%94%9F%E6%88%90%20%E2%80%93%20SDRAM%3C%2FH2%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%80%81%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-340655%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-340655%3C%2FA%3E%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%A1%E3%82%89%E3%81%AB%E3%81%82%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81PDF%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A0%E3%81%91%E3%81%AF%E5%B0%91%E3%81%97%E4%B8%8D%E6%98%8E%E7%9E%AD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--702866236%22%20id%3D%22toc-hId-217855307%22%3EMCUXpresso%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E5%87%BA%E5%8A%9B%3C%2FH3%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81MCUXpresso%E3%81%AE%20%5BMCU%20Settings%EF%BC%88MCU%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%E9%83%A8%E5%88%86%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%87%E3%82%A3%E3%82%BF%E3%81%A7%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20583px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63571iF3AAF7FEE35C9DCE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%5BSettings%EF%BC%88%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%26gt%3B%20%5BMCU%20C%20compiler%EF%BC%88MCU%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%EF%BC%89%5D%20%26gt%3B%20%5BPreprocessor%EF%BC%88%E3%83%97%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%EF%BC%89%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81XIP_boot_header_enable%E3%81%A8XIP_boot_header_DCD_enable%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%920%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5BApply%20and%20Close%EF%BC%88%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E9%96%89%E3%81%98%E3%82%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5BC%2FC%2B%2B%20Build%EF%BC%88C%2FC%2B%2B%E3%83%93%E3%83%AB%E3%83%89%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BSettings%EF%BC%88%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BMCU%20Linker%EF%BC%88MCU%E3%83%AA%E3%83%B3%E3%82%AB%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BManage%20linker%20script%EF%BC%88%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E7%AE%A1%E7%90%86%EF%BC%89%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%5BLink%20application%20to%20RAM%EF%BC%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92RAM%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%EF%BC%89%5D%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75181i6618A6F2B7533AC7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E9%83%A8%E5%88%86%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%5BBinary%20Utilities%EF%BC%88%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81MCUXpresso%E3%81%8B%E3%82%89S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%88.s19%EF%BC%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63526i7A9CA4CB6A02549C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5BBuild%EF%BC%88%E3%83%93%E3%83%AB%E3%83%89%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%86%8D%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63608i92CD2E3D1C13AA0B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE.s19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1784646597%22%20id%3D%22toc-hId--1589599156%22%3EElftosb%E3%83%84%E3%83%BC%E3%83%AB%20%E2%80%93%20.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E7%94%9F%E6%88%90%3C%2FH3%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%80%81%5BTools%EF%BC%88%E3%83%84%E3%83%BC%E3%83%AB%EF%BC%89%5D%20%26gt%3B%20%5Belftosb%5D%20%26gt%3B%20%5BWin%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81.s19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8dcd.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESDRAM%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E3%81%AF%E5%88%A5%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82imx-sdram-normal-unsigned-dcd.bd%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88%E5%89%8D%E8%BF%B0%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E5%85%88%E3%81%AB%E3%81%82%E3%82%8A%EF%BC%89%E3%82%92%E3%80%81%5BTools%EF%BC%88%E3%83%84%E3%83%BC%E3%83%AB%EF%BC%89%5D%20%26gt%3B%20%5Bbd_file%5D%20%26gt%3B%20%5Bimx10xx%5D%20%E3%81%AB%E3%83%89%E3%83%A9%E3%83%83%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%AE%A1%E7%90%86%E8%80%85%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%BB%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%80%8Ccd%20%5Belftosb%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%5D%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eelftosb.exe%20-f%20imx%20-V%20-c%20..%2F..%2Fbd_file%2Fimx10xx%2Fimx-sdram-normal-unsigned-dcd.bd%20-o%20evkbimxrt1050_led_blinky.bin%20SDRAM1_led_blinky.s19%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%80%81imx-flexspinor%20bd%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%86%85%E9%83%A8%E3%81%ABdcd.bin%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E5%90%AB%E3%82%80.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82HYPERFLASH_led_blinky.s19%E3%81%AF%E3%80%81MCUXpresso%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId--22807866%22%20id%3D%22toc-hId-897913677%22%3EElftosb%E3%83%84%E3%83%BC%E3%83%AB%20%E2%80%93%20%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E7%94%9F%E6%88%90%3C%2FH3%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81boot_image.sb%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%B6%9A%E3%81%84%E3%81%A6%E3%80%81kinetis%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6elftosb%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E5%86%8D%E5%BA%A6%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8Cboot_image.sb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eelftosb.exe%20-f%20kinetis%20-V%20-c%20..%2F..%2Fbd_file%2Fimx10xx%2Fprogram_flexspinor_image_hyperflash.bd%20-o%20boot_image.sb%20evkbimxrt1050_led_blinky_nopadding.bin%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9Fimx%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%87%BA%E5%8A%9B%E3%81%AFboot_image.sb%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%88%A5%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%A7%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%AA%E3%81%8A%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E4%B8%AD%E3%81%A7flexspinor_image_hyperflash%E3%81%A8%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E9%96%93%E9%81%95%E3%81%84%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%8A%80%E8%A1%93%E7%9A%84%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9A%E3%81%AFHyperflash%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%A4%89%E3%82%8F%E3%82%8A%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92SDRAM%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eboot_image.sb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1830262329%22%20id%3D%22toc-hId--909540786%22%3EMFG%E3%83%84%E3%83%BC%E3%83%AB%3C%2FH3%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81MFGTool%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AESW7%E3%82%92OFF-ON-OFF-ON%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%82%92J1%EF%BC%885-6%EF%BC%89%E3%81%8B%E3%82%89J1%EF%BC%883-4%EF%BC%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92J9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81MFGTool%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%5BStart%EF%BC%88%E9%96%8B%E5%A7%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20307px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75180i5C55BA84CD863AE2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%20boot_image.sb%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%20Tools%20%26gt%3B%20mfgtools-rel%20%26gt%3B%20Profiles%20%26gt%3B%20MXRT105X%20%26gt%3B%20OS%20Firmware%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AESW7%E3%82%92OFF-ON-OFF-ON%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E4%B8%8B%E9%83%A8%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92J9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emfgtools-rel%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E6%88%BB%E3%82%8A%E3%80%81MFGTool%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%5BHID-compliant%20vendor-defined%20device%EF%BC%88HID%E6%BA%96%E6%8B%A0%E3%81%AE%E3%83%99%E3%83%B3%E3%83%80%E5%AE%9A%E7%BE%A9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%89%5D%20%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SW7%E3%81%A8%E5%8F%B3%E4%B8%8B%E3%81%AE%E9%9B%BB%E6%BA%90%E3%83%94%E3%83%B3%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20433px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75179iE90BB1BBF2C1BABE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5BStart%EF%BC%88%E9%96%8B%E5%A7%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%A8%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20443px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63669iA90B5EA610DBECE6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E8%A8%80%E3%81%86%E6%88%90%E5%8A%9F%E3%81%A8%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E3%81%A0%E3%81%91%E3%81%AE%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%BE%8C%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%83%B3%E5%AE%9A%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E3%81%97%E3%81%84%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A8%E3%80%81MCUXpresso%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5BStop%EF%BC%88%E5%81%9C%E6%AD%A2%EF%BC%89%5D%20%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%94%E3%83%B3%E3%83%BB%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E5%BF%85%E3%81%9A%E5%85%83%E3%81%AB%E6%88%BB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Hyperflash%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81J1%EF%BC%885-6%EF%BC%89%E3%81%A8SW7%E3%82%92OFF-ON-ON-OFF%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CH2%20id%3D%22toc-hId-528167785%22%20id%3D%22toc-hId-1448889328%22%3E%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E7%94%9F%E6%88%90%20%E2%80%93%20SRAM%3C%2FH2%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E5%B0%91%E3%81%97%E5%8E%84%E4%BB%8B%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%95%E3%81%BB%E3%81%A9%E9%9B%A3%E3%81%97%E3%81%8F%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1150203959%22%20id%3D%22toc-hId--229482416%22%3EMCUXpresso%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E5%87%BA%E5%8A%9B%3C%2FH3%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81MCUXpresso%E3%81%AE%20%5BMCU%20Settings%EF%BC%88MCU%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%E9%83%A8%E5%88%86%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%87%E3%82%A3%E3%82%BF%E3%81%A7%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92DTC%20RAM%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63704i21DBEF1139634705%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%5BSettings%EF%BC%88%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%26gt%3B%20%5BMCU%20C%20compiler%EF%BC%88MCU%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%EF%BC%89%5D%20%26gt%3B%20%5BPreprocessor%EF%BC%88%E3%83%97%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%EF%BC%89%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81XIP_boot_header_enable%E3%81%A8XIP_boot_header_DCD_enable%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%920%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5BApply%20and%20Close%EF%BC%88%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E9%96%89%E3%81%98%E3%82%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5BC%2FC%2B%2B%20Build%EF%BC%88C%2FC%2B%2B%E3%83%93%E3%83%AB%E3%83%89%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BSettings%EF%BC%88%E8%A8%AD%E5%AE%9A%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BMCU%20Linker%EF%BC%88MCU%E3%83%AA%E3%83%B3%E3%82%AB%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5BManage%20linker%20script%EF%BC%88%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E7%AE%A1%E7%90%86%EF%BC%89%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%5BLink%20application%20to%20RAM%EF%BC%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92RAM%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%EF%BC%89%5D%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63520i80C4D624B4159162%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_15.png%22%20alt%3D%22pastedImage_15.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E9%83%A8%E5%88%86%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%5BBinary%20Utilities%EF%BC%88%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81MCUXpresso%E3%81%8B%E3%82%89S%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%88.s19%EF%BC%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63747i66F79D0FC9CB50B2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5BBuild%EF%BC%88%E3%83%93%E3%83%AB%E3%83%89%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%86%8D%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8CSRAM%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63250i768953FF77056455%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_17.png%22%20alt%3D%22pastedImage_17.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE.s19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1337308874%22%20id%3D%22toc-hId--2036936879%22%3EElftosb%E3%83%84%E3%83%BC%E3%83%AB%20%E2%80%93%20.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E7%94%9F%E6%88%90%3C%2FH3%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%80%81%5BTools%EF%BC%88%E3%83%84%E3%83%BC%E3%83%AB%EF%BC%89%5D%20%26gt%3B%20%5Belftosb%5D%20%26gt%3B%20%5BWin%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81.s19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8dcd.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%AE%A1%E7%90%86%E8%80%85%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%BB%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%80%8Ccd%20%5Belftosb%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%5D%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDTCM%20RTAM%E3%81%AB%E5%9B%BA%E6%9C%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%5BTools%EF%BC%88%E3%83%84%E3%83%BC%E3%83%AB%EF%BC%89%5D%20%26gt%3B%26gt%3B%20%5Bbd_file%5D%20%26gt%3B%26gt%3B%20%5Bimx10xx%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81imx-dtcm-unsigned-dcd.bd%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81ivtOffset%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%920x1000%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SD%E3%82%AB%E3%83%BC%E3%83%89%E8%B5%B7%E5%8B%95%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF0x400%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%BF%B5%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E7%A4%BA%E3%81%99%E3%81%A8%E3%80%81bd%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75178i057FA600CF86478B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_18.png%22%20alt%3D%22pastedImage_18.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eelftosb.exe%20-f%20imx%20-V%20-c%20..%2F..%2Fbd_file%2Fimx10xx%2Fimx-dtcm-unsigned-dcd.bd%20-o%20evkbimxrt1050_led_blinky.bin%20SRAM1_led_blinky.s19%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%80%81imx-flexspinor%20bd%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%86%85%E9%83%A8%E3%81%ABdcd.bin%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E5%90%AB%E3%82%80.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82SRAM_led_blinky.s19%E3%81%AF%E3%80%81MCUXpresso%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId--470145589%22%20id%3D%22toc-hId-450575954%22%3EElftosb%E3%83%84%E3%83%BC%E3%83%AB%20%E2%80%93%20%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E7%94%9F%E6%88%90%3C%2FH3%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81boot_image.sb%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%B6%9A%E3%81%84%E3%81%A6%E3%80%81kinetis%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6elftosb%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E5%86%8D%E5%BA%A6%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8Cboot_image.sb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eelftosb.exe%20-f%20kinetis%20-V%20-c%20..%2F..%2Fbd_file%2Fimx10xx%2Fprogram_flexspinor_image_hyperflash.bd%20-o%20boot_image.sb%20evkbimxrt1050_led_blinky_nopadding.bin%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9Fimx%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%87%BA%E5%8A%9B%E3%81%AFboot_image.sb%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%88%A5%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%A7%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%AA%E3%81%8A%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E4%B8%AD%E3%81%A7flexspinor_image_hyperflash%E3%81%A8%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E9%96%93%E9%81%95%E3%81%84%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%8A%80%E8%A1%93%E7%9A%84%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9A%E3%81%AFHyperflash%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%A4%89%E3%82%8F%E3%82%8A%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92SDRAM%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2017367244%22%20id%3D%22toc-hId--1356878509%22%3EMFG%E3%83%84%E3%83%BC%E3%83%AB%3C%2FH3%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81MFGTool%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AESW7%E3%82%92OFF-ON-OFF-ON%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%82%92J1%EF%BC%885-6%EF%BC%89%E3%81%8B%E3%82%89J1%EF%BC%883-4%EF%BC%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92J9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81MFGTool%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%5BStart%EF%BC%88%E9%96%8B%E5%A7%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%20style%3D%22width%3A%20307px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63848i2DD1FF5C49390FA4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_19.png%22%20alt%3D%22pastedImage_19.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%20boot_image.sb%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%20Tools%20%26gt%3B%20mfgtools-rel%20%26gt%3B%20Profiles%20%26gt%3B%20MXRT105X%20%26gt%3B%20OS%20Firmware%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AESW7%E3%82%92OFF-ON-OFF-ON%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E4%B8%8B%E9%83%A8%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92J9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emfgtools-rel%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E6%88%BB%E3%82%8A%E3%80%81MFGTool%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%5BHID-compliant%20vendor-defined%20device%EF%BC%88HID%E6%BA%96%E6%8B%A0%E3%81%AE%E3%83%99%E3%83%B3%E3%83%80%E5%AE%9A%E7%BE%A9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%89%5D%20%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SW7%E3%81%A8%E5%8F%B3%E4%B8%8B%E3%81%AE%E9%9B%BB%E6%BA%90%E3%83%94%E3%83%B3%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%20style%3D%22width%3A%20433px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75177i1003543996E91267%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_20.png%22%20alt%3D%22pastedImage_20.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%5BStart%EF%BC%88%E9%96%8B%E5%A7%8B%EF%BC%89%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%A8%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%20style%3D%22width%3A%20443px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63380i54843662F243617C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_21.png%22%20alt%3D%22pastedImage_21.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E8%A8%80%E3%81%86%E6%88%90%E5%8A%9F%E3%81%A8%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E3%81%A0%E3%81%91%E3%81%AE%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%BE%8C%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%83%B3%E5%AE%9A%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E3%81%97%E3%81%84%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A8%E3%80%81MCUXpresso%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%5BStop%EF%BC%88%E5%81%9C%E6%AD%A2%EF%BC%89%5D%20%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%94%E3%83%B3%E3%83%BB%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E5%BF%85%E3%81%9A%E5%85%83%E3%81%AB%E6%88%BB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Hyperflash%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81J1%EF%BC%885-6%EF%BC%89%E3%81%A8SW7%E3%82%92OFF-ON-ON-OFF%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E8%A8%80%E3%81%86%E6%88%90%E5%8A%9F%E3%81%A8%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E3%81%A0%E3%81%91%E3%81%AE%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%BE%8C%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%83%B3%E5%AE%9A%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E3%81%97%E3%81%84%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A8%E3%80%81MCUXpresso%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E6%BA%96%E5%82%99%E3%81%AF%E5%AE%8C%E4%BA%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1123079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20105%E5%80%8D%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123086%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1050%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123086%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE3%E6%97%A5%E9%96%93%E3%80%81%E3%81%84%E3%82%8D%E3%81%84%E3%82%8D%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82RT1050-EVKB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82MCUXpresso%E3%81%8B%E3%82%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%A8%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%97%E3%80%81DTC%20RAM%E3%82%84ITC%20RAM%E3%81%AB%E3%82%82%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFNXP-MCUBootutility%E3%81%8BMCUXpresso%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%AC%A1%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%AF%E3%80%81XIP%E3%81%A7SDRAM%E3%81%8B%E3%82%89%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E6%83%85%E5%A0%B1%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81evkbimxrt1050_iled_blinky_ext_FLASH%E3%81%A8evkbimxrt1050_iled_blinky_SDRAM%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%83%84%E3%83%BC%E3%83%AB%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E3%80%81%E7%A7%81%E3%81%8C%E4%BD%95%E3%81%8B%E3%81%AE%E3%82%84%E3%82%8A%E6%96%B9%E3%82%92%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E4%BD%95%E3%81%8B%E3%82%92%E6%8A%9C%E3%81%8B%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AESDK%E3%81%AF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.3%E3%81%A7%E3%81%99%E3%80%82%E5%AE%9F%E3%81%AB%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AA%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E6%80%9D%E3%81%88%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%8C%E5%80%8B%E3%80%85%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E4%BD%95%E3%81%8B%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E6%89%8B%E5%A7%8B%E3%82%81%E3%81%AB%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81MCUXpresso%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6XIP%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E5%AE%9A%E7%BE%A9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%920x60002000%E3%81%8B%E3%82%89%E5%AE%9F%E8%A1%8C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A8%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9C%80%E4%B8%8A%E4%BD%8D%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELarry%3C%2FP%3E%3CP%3E%E7%B7%A8%E9%9B%86%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%A9%9A%E3%81%8D%E3%81%AE%E7%B5%90%E6%9C%AB%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E7%AD%94%E3%81%88%E3%81%8C%E5%88%A4%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82MCUXPresso%20IDE%E3%81%8C%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E3%81%9D%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E5%BD%93%E3%81%AEIDE%E3%81%8C%E8%AA%8D%E8%AD%98%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%EF%BC%81%EF%BC%81%E7%A7%81%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7V10.3%E3%82%92%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A71%E5%B9%B4%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E8%A1%A8%E7%A4%BA%E3%81%8C%E5%87%BA%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AEIDE%E3%81%AF%E3%80%81%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B311.1%E3%81%8C%E5%87%BA%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8A%8A%E6%8F%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82RT1050%20SDK%20v2.7%E3%81%AF%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E9%80%A3%E6%90%BA%E3%81%97%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%A9%9F%E8%83%BD%E3%82%82%E3%81%99%E3%81%B9%E3%81%A6%E8%87%AA%E5%8B%95%E3%81%A7%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%EF%BC%81%E3%81%99%E3%81%94%E3%81%84%E3%81%A7%E3%81%99%EF%BC%81RT1050%20SDK2.3%E3%81%AF%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1050%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EAdrian%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%20Flashloader%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%80%8C-dcd%E3%80%8Dbd%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1050%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AA%E3%81%9C.s19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1050%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%93%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%99%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E3%81%8D%E3%80%81%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%EF%BC%88ivt%E3%80%81boot%20data...%EF%BC%89%E3%82%92%E6%B0%97%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CA%20class%3D%22%22%20href%3D%22https%3A%2F%2Fgithub.com%2FJayHeng%2Fnxp-sec-boot-ui%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2FJayHeng%2Fnxp-sec-boot-ui%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGitHub%20-%20JayHeng%2Fnxp-sec-boot-ui%3A%20NXP%20MCU%20(Kinetis%E3%80%81i.MXRT%E3%80%81LPC)%20ROM%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E6%93%8D%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%AF%E3%83%B3%E3%82%B9%E3%83%88%E3%83%83%E3%83%97GUI%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E2%80%A6%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1050%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%B5%90%E5%B1%80%E3%80%81%E7%A7%81%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E6%97%A5%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%80%81SDRAM%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AA%E3%81%97%E3%81%A7%E3%80%81MCUXpresso%E3%81%A7%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Segger%20Ozone%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%84%E5%A0%B4%E6%89%80%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EManuel%E3%81%95%E3%82%93%E3%80%81%E3%82%82%E3%81%97%E3%83%95%E3%82%A3%E3%83%AC%E3%83%B3%E3%83%84%E3%82%A7%E3%81%AB%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%A3%E3%81%9F%E3%82%89%E3%80%81%E3%83%93%E3%83%BC%E3%83%AB%E3%82%921%E6%9D%AF%E3%81%8A%E3%81%94%E3%82%8A%E3%81%BE%E3%81%99%E3%82%88%20%3CLI-EMOJI%20id%3D%22lia_winking-face%22%20title%3D%22%3Awinking_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGiuseppe%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1050%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%9E%E3%83%8C%E3%82%A8%E3%83%AB%E3%81%95%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E6%96%87%E6%9B%B8%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8elftosb%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82S19%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%80%8C%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B30x0%E3%80%8D%E3%82%92%E6%8E%A2%E3%81%97%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AFSDRAM%E3%81%A8%E5%86%85%E9%83%A8RAM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EGiuseppe%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1050%E3%81%AE%E3%83%96%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESD%E3%82%84QSPI%E3%81%8B%E3%82%89%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%80%81SDRAM%E3%81%8B%E3%82%89%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AFRT1020%E3%81%A7%E3%82%82%E4%BD%BF%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82RT1050%E5%B0%82%E7%94%A8%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎08-17-2018 12:47 PM
更新者:
