I am working on yocto project to create an image for imx6ull14x14evk.'m Working on a VM ubuntu 20.04 and following the user_guide:imx-yocto-L6.1.36_2.1.0/i.MX_Yocto_Project_User's_Guide.pdf
Solved! Go to Solution.
The code in sources could be incomplete, you can try to sync again.Best RegardsZhiming
I tried many times and the results showed success.;But the problem still exists
