yocto project problem to setup-environment
1,573 次查看
wangchao5128
I am working on yocto project to create an image for imx6ull14x14evk.
'm Working on a VM ubuntu 20.04 and following the user_guide:
imx-yocto-L6.1.36_2.1.0/i.MX_Yocto_Project_User's_Guide.pdf
1,551 次查看
Zhiming_Liu
The code in sources could be incomplete, you can try to sync again.
Best Regards
Zhiming
4 回复数
1,516 次查看
wangchao5128
I tried many times and the results showed success.;But the problem still exists
1,552 次查看
Zhiming_Liu
Best Regards
Zhiming
1,504 次查看
wangchao5128
1,539 次查看
wangchao5128
