yocto package generation
1,233件の閲覧回数
ronjacoby1
hi,
generating the imx-image-full for iMX8, it seems that the different deb files are generated each time i run the full build, after deleting tmp folder.
for example, i used  packagegroup-fsl-gstreamer1.0-base, and it was not created after a rebuild. i made no change to local.conf
1,183件の閲覧回数
Harvey021
Hi @ronjacoby1
It should be no such difference when no changes to build configuration or environments, such as change the target MACHINE? Or do repo sync on the basis of internal xml?
Harvey
