yocto eSDK issue with hardknott
12,160 次查看
JK38
Hi everyone,
I have been using the imx8M plus evaluation board and so far things are working great.  I can build images, SDK's and eSDK's with no problem but where I am running into issues is when I tried to unpack an eSDK for our firmware team.  SDK's work great but we would like to use the eSDK to go deeper into configuring the image.
I use wsl2 on Windows 10 for my Yocto builds but when I unpack it on WSL I get the following error:
ERROR: Task (virtual:native:/home/hulk/fsl-imx-wayland_sdk_ext/layers/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_fetch) failed with exit code 'setscene whitelist'
ERROR: SDK preparation failed: error log written to /home/hulk/fsl-imx-wayland_sdk_ext/preparing_build_system.log
I did find the issue has been identified and corrected on 2021-07-10 here
https://git.yoctoproject.org/cgit.cgi/poky/commit/?id=7f9f9a0c37970c555e17e24ea1e6f25fbea6ae35
and it looks like hardknott 3.3.2 and it appears that the imx is using hardknott 3.3
Has anyone fixed this issue or have an idea on how to fix it?  I have tried to update the poky later to hardknott 3.3.2 but I still run into the issue.
8 回复数
11,929 次查看
erwing
Hi everyone,
Any updates on this topic?
We ran into the same issue using BSP 5.10.35 of NXP.
See attached log.
Any help would be appreciated.
Kind regards,
Erwin Groenendaal
8,122 次查看
deampse
I also encountered this problem today, and the exception is the same as yours. Could you please share with me how you solved the problem at that time?
11,922 次查看
Zhiming_Liu
12,129 次查看
JK38
Hi @Zhiming_Liu
The steps are pretty simple
  1. bitbake core-image-base -c populate_sdk_ext
  2. Install the eSDK found in /tmp/deplay/sdk
  3. Watch it fail
12,124 次查看
Zhiming_Liu
@JK38
lzm@WIN-JRIFK9G98EH:~/imx-yocto-bsp/build_test$ bitbake core-image-base -c populate_sdk_ext
NOTE: Your conf/bblayers.conf has been automatically updated.
WARNING: You are running bitbake under WSLv2, this works properly but you should optimize your VHDX file eventually to avoid running out of storage space
Loading cache: 100% |        | ETA:  --:--:--
Loaded 0 entries from dependency cache.
Parsing recipes: 100% |##################################################################################| Time: 0:00:49
Parsing of 3218 .bb files complete (0 cached, 3218 parsed). 4819 targets, 249 skipped, 3 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION           = "1.50.0"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "ubuntu-18.04"
TARGET_SYS           = "aarch64-poky-linux"
MACHINE              = "imx8mpevk"
DISTRO               = "fsl-imx-xwayland"
DISTRO_VERSION       = "5.10-hardknott"
TUNE_FEATURES        = "aarch64 armv8a crc cortexa53 crypto"
TARGET_FPU           = ""
meta
meta-poky            = "HEAD:58cbdaecf75b0248f96780b6882e8d4f232d038a"
meta-oe
meta-multimedia
meta-python          = "HEAD:c3a36263f91e42302ad7c347e051cf1cd83e39f6"
meta-freescale       = "HEAD:80dbe4bd63bd537fc9cfda2e009f8543464b4698"
meta-freescale-3rdparty = "HEAD:7f23af99cb97a12134a46b5b9d497f05b758bf0c"
meta-freescale-distro = "HEAD:916df6d24c0a33a3b1533bde70b6a2724ec77af4"
meta-bsp
meta-sdk
meta-ml
meta-v2x             = "HEAD:15fddd76b460fb56d9de121eb2d16a1e22cbe900"
meta-nxp-demo-experience = "HEAD:46107357abd2d2da9ffd702c87fce3984a422435"
meta-chromium        = "HEAD:cb3278e31340c7f081e8deb0683df2145da515c9"
meta-clang           = "HEAD:d797409435d3b0e9f2859992439989ff1d81e66d"
meta-gnome
meta-networking
meta-filesystems     = "HEAD:c3a36263f91e42302ad7c347e051cf1cd83e39f6"
meta-qt5             = "HEAD:a00af3eae082b772469d9dd21b2371dd4d237684"
meta-python2         = "HEAD:810d6d842f103eb59f18b06426106462b15de7e2"
Initialising tasks: 100% |###############################################################################| Time: 0:00:04
Sstate summary: Wanted 2344 Local 0 Network 0 Missed 2344 Current 0 (0% match, 0% complete)
NOTE: Executing Tasks
WARNING: expat-2.2.10-r0 do_fetch: Failed to fetch URL https://downloads.sourceforge.net/expat/expat-2.2.10.tar.bz2, attempting MIRRORS if available
WARNING: boost-1.75.0-r0 do_fetch: Failed to fetch URL https://dl.bintray.com/boostorg/release/1.75.0/source/boost_1_75_0.tar.bz2, attempting MIRRORS if available
WARNING: netbase-1_6.2-r0 do_fetch: Failed to fetch URL http://ftp.debian.org/debian/pool/main/n/netbase/netbase_6.2.tar.xz, attempting MIRRORS if available
WARNING: apt-2.2.2-r0 do_fetch: Failed to fetch URL http://ftp.debian.org/debian/pool/main/a/apt/apt_2.2.2.tar.xz, attempting MIRRORS if available
WARNING: jailhouse-0.12-r0 do_fetch: Failed to fetch URL git://source.codeaurora.org/external/imx/imx-jailhouse.git;protocol=ssh;branch=lf-5.10.y_2.0.0, attempting MIRRORS if available
WARNING: linux-imx-5.10.35+gitAUTOINC+ef3f2cfc60-r0 do_fetch: Failed to fetch URL git://source.codeaurora.org/external/imx/linux-imx.git;protocol=https;branch=lf-5.10.y, attempting MIRRORS if available
NOTE: Tasks Summary: Attempted 6124 tasks of which 0 didn't need to be rerun and all succeeded.
Summary: There were 7 WARNING messages shown.
My WSL2 kernel is  5.4.72-microsoft-standard-WSL2 . It's successfully in L5.10.35_2.0.0
12,114 次查看
JK38
@Zhiming_Liu
Did you try installing the eSDK in WSL?
This is where my eSDK fails.  Again the build of the eSDK is find but the installation process fails with the errors I have stated above.
12,132 次查看
Zhiming_Liu
Hi @JK38
Can you offer the steps that i can reproduce this issue?
12,101 次查看
JK38
Steps when I deploy the eSDK in WSL followed by the error's (Error log is attached)
user1@PC_2818:~/imx8plus_yocto_bsp/imx8_build/tmp/deploy/sdk$ ./fsl-imx-wayland-glibc-x86_64-imx-image-core-cortexa53-crypto-imx8mpevk-toolchain-ext-5.10-hardknott.sh
NXP i.MX Release Distro Extensible SDK installer version 5.10-hardknott
Enter target directory for SDK (default: ~/fsl-imx-wayland_sdk):
The directory "/home/user1/fsl-imx-wayland_sdk" already contains a SDK for this architecture.
If you continue, existing files will be overwritten! Proceed [y/N]? y
Extracting SDK...........................................................................................................................................................................................done
Setting it up...
Extracting buildtools...
Preparing build system...
Parsing recipes: 100% |########################################################################################################################################| Time: 0:01:19
Initialising tasks: 100% |#####################################################################################################################################| Time: 0:00:13
Checking sstate mirror object availability: 100% |#############################################################################################################| Time: 0:00:00
WARNING: The imx-m7-demos:do_fetch sig is computed to be 21fa6b44c1c0360ae9b313472f8b55dbfec6e61863461ed2a5ffe7bacab9e276, but the sig is locked to 8aaaa8ce139fb877f41310770d9dbe4b57b826bca2d260344c04b4df88c2e138 in SIGGEN_LOCKEDSIGS_t-cortexa53-crypto-mx8mp
The imx-gpu-viv:do_fetch sig is computed to be eab5b4a7d14d380d6ed3f1064e1d22c4f618bc62e90218a586298a0ad0754680, but the sig is locked to 374b00172e77bc09f362e506bda29b6c314db3db19e2c9b29ee99ea58db9f49b in SIGGEN_LOCKEDSIGS_t-cortexa53-crypto-mx8mp
The firmware-imx-8m:do_fetch sig is computed to be ba44a971bd2690578d07420bcbb0aa17288665777eafcd94b71b52d8beaff73c, but the sig is locked to c13151a8d6512a8b03a23cbbdf768724ce846b84b8c51a4a2bf8f9258aea90d2 in SIGGEN_LOCKEDSIGS_t-cortexa53-crypto-mx8mp
The imx-gpu-g2d:do_fetch sig is computed to be 4d51f75377d8cb02142e1df86ec54e82b8625a421d3972eef06a6f1c9cb4f2ea, but the sig is locked to c306db4ec9b3340266ee60b6d9232c1e7929f6ec6247211cc71cd830ba843929 in SIGGEN_LOCKEDSIGS_t-cortexa53-crypto-mx8mp
The imx-vpu-hantro:do_fetch sig is computed to be 1a739d4bfc1ca9e18eacd9b0f72fd54738b06829a685fe14af88431ecef0174d, but the sig is locked to c2d6882b7db8abcb3ecc0fc0683528c6d15d14f8b9b711fe38d7a9e56706322c in SIGGEN_LOCKEDSIGS_t-cortexa53-crypto-mx8mp
The firmware-imx:do_fetch sig is computed to be 2e6f633c96057a5cde9c7408ac5dfd74340a92f78a1813e541dfd3bee7d50e93, but the sig is locked to 6078ffd079402dcef7fc216f92c580c005936625e7cb3c3eb619e640d4459ad6 in SIGGEN_LOCKEDSIGS_t-allarch
The imx-sw-pdm:do_fetch sig is computed to be 01820419598503850423ddb66fb6088f7c7dfbf4e6b4a01e1ba4d26652a764f2, but the sig is locked to 0cd5768d98012072d08a6f1508ebfc50427e58087e01e6de2ef1a07ed4ec2cd7 in SIGGEN_LOCKEDSIGS_t-cortexa53-crypto
ERROR: Task glib-2.0-native.do_write_config attempted to execute unexpectedly
/....List of task executed omitted due to character limits in forum..../
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale-distro/recipes-graphics/devil/devil_1.8.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale-distro/recipes-graphics/rapidopencl/rapidopencl_1.1.0.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale-distro/recipes-graphics/rapidopenvx/rapidopenvx_1.1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale/recipes-bsp/imx-test/imx-test_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale/recipes-core/udev/udev-rules-imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale/recipes-graphics/drm/libdrm_2.4.102.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale/recipes-graphics/wayland/wayland-protocols_1.20.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale/recipes-graphics/wayland/weston_9.0.0.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale/recipes-graphics/wayland/weston_9.0.0.imx.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-freescale/recipes-support/opencv/opencv_4.5.2.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-bsp/firmware-imx/firmware-imx-8m_8.12.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-bsp/firmware-imx/firmware-imx_8.12.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-bsp/imx-atf/imx-atf_2.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-bsp/imx-mkimage/imx-boot_1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-bsp/imx-vpu-hantro/imx-vpu-hantro_1.22.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-bsp/u-boot/u-boot-imx_2021.04.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-connectivity/nxp-wlan-sdk/nxp-wlan-sdk_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-core/systemd/systemd-gpuconfig_1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-fsl/m4-demos/imx-m7-demos_2.9.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-graphics/imx-gpu-g2d/imx-gpu-g2d_6.4.3.p2.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-graphics/imx-gpu-viv/imx-gpu-viv_6.4.3.p2.0-aarch64.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-kernel/kernel-modules/kernel-module-nxp89xx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-kernel/kernel-tests/kernel-tools.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-kernel/linux-firmware/sof-imx_1.8.0-1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_5.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx-headers_5.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx_5.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx_5.10.bb:do_shared_workdir',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-multimedia/alsa/imx-alsa-plugins_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-base_1.18.0.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer1.0_1.18.0.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-multimedia/imx-sw-pdm/imx-sw-pdm_1.0.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-security/optee-imx/optee-client_3.13.0.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-security/optee-imx/optee-os_3.13.0.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-security/optee-imx/optee-test_3.13.0.imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-security/smw/keyctl-caam_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-security/smw/smw_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-connectivity/wireless-tools/wireless-tools_30.pre9.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-devtools/half/half_2.1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-devtools/stb/stb_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-extended/jailhouse/jailhouse_0.12.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-extended/sudo/sudo_1.9.5p2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-fsl/images/imx-image-core.bb:do_image_complete',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-fsl/images/imx-image-core.bb:do_image_qa',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-fsl/packagegroup/packagegroup-fsl-optee-imx.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-fsl/packagegroup/packagegroup-imx-core-tools.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-fsl/packagegroup/packagegroup-imx-security.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-graphics/gli/gli_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-graphics/imx-gpu-sdk/imx-gpu-sdk_5.7.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-graphics/rapidvulkan/rapidvulkan_1.2.162.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-sdk/recipes-graphics/vulkan/vulkan-validationlayers_1.2.170.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-networking/recipes-daemons/ptpd/ptpd_2.3.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-networking/recipes-support/ntp/ntp_4.2.8p15.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-networking/recipes-support/ntp/ntp_4.2.8p15.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-benchmark/memtester/memtester_4.5.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-bsp/cpufrequtils/cpufrequtils_008.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-connectivity/linuxptp/linuxptp_3.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-devtools/giflib/giflib_5.1.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-devtools/protobuf/protobuf_3.15.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-devtools/rapidjson/rapidjson_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-extended/libidn/libidn_1.36.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-extended/liblogging/liblogging_1.0.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-extended/rsyslog/libfastjson_0.99.9.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-extended/rsyslog/librelp_1.10.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-extended/rsyslog/rsyslog_8.2102.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-extended/socketcan/can-utils_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-extended/socketcan/libsocketcan_0.0.12.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-graphics/glm/glm_0.9.9.8.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-graphics/gphoto2/libgphoto2_2.5.27.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-graphics/leptonica/leptonica_1.80.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-graphics/tesseract/tesseract-lang_4.1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-graphics/tesseract/tesseract_4.1.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-kernel/spidev-test/spidev-test.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-multimedia/v4l2apps/v4l-utils_1.20.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-security/keyutils/keyutils_1.6.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/fbset/fbset-modes.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/fbset/fbset_2.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/fmt/fmt_7.1.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/libestr/libestr_0.1.11.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/libusb/libusb-compat_0.1.7.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/lvm2/lvm2_2.03.11.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/nano/nano_5.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/opencl/clinfo_2.2.18.04.06.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/opencv/ade_0.1.1f.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/pps-tools/pps-tools_1.0.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/tbb/tbb_2021.2.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-support/thin-provisioning-tools/thin-provisioning-tools_0.8.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-test/evtest/evtest_1.34.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-test/googletest/googletest_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-python2/recipes-devtools/python/python-native_2.7.18.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-python2/recipes-devtools/python/python-native_2.7.18.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/meta-python2/recipes-devtools/python/python_2.7.18.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-bsp/alsa-state/alsa-state.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-bsp/lrzsz/lrzsz_0.12.20.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-bsp/pciutils/pciutils_3.7.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-bsp/usbutils/usbutils_013.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/avahi/avahi_0.8.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/avahi/avahi_0.8.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/bluez5/bluez5_5.56.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/iproute2/iproute2_5.11.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/iw/iw_5.9.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/libnss-mdns/libnss-mdns_0.14.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/libpcap/libpcap_1.10.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/mobile-broadband-provider-info/mobile-broadband-provider-info_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/neard/neard_0.16.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/nfs-utils/nfs-utils_2.5.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/nfs-utils/nfs-utils_2.5.3.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/ofono/ofono_1.31.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/openssh/openssh_8.5p1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/openssh/openssh_8.5p1.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/openssl/openssl_1.1.1k.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/socat/socat_1.7.4.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/wpa-supplicant/wpa-supplicant_2.9.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/base-files/base-files_3.0.14.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/base-passwd/base-passwd_3.5.29.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/busybox/busybox_1.33.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/coreutils/coreutils_8.32.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/dbus/dbus-test_1.12.20.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/dbus/dbus_1.12.20.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/dbus/dbus_1.12.20.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/ell/ell_0.38.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/expat/expat_2.2.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/gettext/gettext_0.21.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glib-2.0/glib-2.0_2.66.7.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glibc/cross-localedef-native_2.33.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glibc/cross-localedef-native_2.33.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glibc/glibc-locale_2.33.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glibc/glibc-mtrace_2.33.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glibc/glibc_2.33.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/kbd/kbd_2.4.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/libxcrypt/libxcrypt_4.4.18.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/libxml/libxml2_2.9.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/ncurses/ncurses_6.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/netbase/netbase_6.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/os-release/os-release.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-base.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-core-boot.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-core-buildessential.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-core-nfs.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-core-sdk.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-core-ssh-openssh.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-core-standalone-sdk-target.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-core-tools-debug.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/packagegroups/packagegroup-core-tools-profile.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/psplash/psplash_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/readline/readline_8.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/systemd/systemd-compat-units.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/systemd/systemd-conf_247.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/systemd/systemd-serialgetty.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/systemd/systemd_247.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/systemd/systemd_247.6.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/udev/udev-extraconf_1.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/update-rc.d/update-rc.d_0.8.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/util-linux/util-linux-libuuid_2.36.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/util-linux/util-linux_2.36.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/volatile-binds/volatile-binds.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/zlib/zlib_1.2.11.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/autoconf-archive/autoconf-archive_2019.01.06.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/autoconf/autoconf_2.71.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/automake/automake_1.16.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/binutils/binutils_2.36.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/bison/bison_3.7.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/btrfs-tools/btrfs-tools_5.10.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/ccache/ccache_4.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/cmake/cmake-native_3.19.5.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/cmake/cmake-native_3.19.5.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/cmake/cmake_3.19.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/diffstat/diffstat_1.64.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/dosfstools/dosfstools_4.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/dpkg/dpkg_1.20.7.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/e2fsprogs/e2fsprogs_1.46.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/elfutils/elfutils_0.183.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/file/file_5.39.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/flex/flex_2.6.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/gcc/gcc-runtime_10.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/gcc/gcc-sanitizers_10.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/gcc/gcc_10.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/gcc/libgcc_10.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/gdb/gdb-cross_10.1.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/gdb/gdb-cross_10.1.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/gdb/gdb_10.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/i2c-tools/i2c-tools_4.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/json-c/json-c_0.15.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/libtool/libtool_2.4.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/m4/m4_1.4.18.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/make/make_4.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/mmc/mmc-utils_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/mtd/mtd-utils_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/ninja/ninja_1.10.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/opkg-utils/opkg-utils_0.4.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/opkg/opkg-arch-config_1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/opkg/opkg_0.4.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/orc/orc_0.4.32.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/patch/patch_2.7.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/perl/liberror-perl_0.17029.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/perl/perl_5.32.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python-numpy/python3-numpy_1.20.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-atomicwrites_1.4.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-attrs_20.3.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-dbus_1.2.16.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-hypothesis_6.2.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-importlib-metadata_3.4.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-iniconfig_1.1.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-mako_1.1.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-more-itertools_8.7.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-packaging_20.9.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-pathlib2_2.3.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-pluggy_0.13.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-py_1.10.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-pycairo_1.20.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-pygobject_3.38.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-pyparsing_2.4.7.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-pytest_6.2.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-setuptools_54.1.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-six_1.15.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-sortedcontainers_2.3.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-toml_0.10.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-wcwidth_0.2.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-zipp_3.4.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3_3.9.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/qemu/qemu-helper-native_1.0.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/qemu/qemu-helper-native_1.0.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/qemu/qemu-native_5.2.0.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/qemu/qemu-native_5.2.0.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/qemu/qemu-system-native_5.2.0.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/qemu/qemu-system-native_5.2.0.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/quilt/quilt_0.66.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/rsync/rsync_3.2.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/run-postinsts/run-postinsts_1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/strace/strace_5.11.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/tcltk/tcl_8.6.11.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/valgrind/valgrind_3.16.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/bash/bash_5.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/bc/bc_1.07.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/bzip2/bzip2_1.0.8.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/cracklib/cracklib_2.9.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/diffutils/diffutils_3.7.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/ed/ed_1.17.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/ethtool/ethtool_5.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/findutils/findutils_4.8.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/gawk/gawk_5.1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/grep/grep_3.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/gzip/gzip_1.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/iptables/iptables_1.8.7.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/less/less_563.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libaio/libaio_0.3.112.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libarchive/libarchive_3.5.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libidn/libidn2_2.3.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libmnl/libmnl_1.0.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libnsl/libnsl2_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libsolv/libsolv_0.7.17.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libtirpc/libtirpc_1.3.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/logrotate/logrotate_3.18.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/lsb/lsb-release_1.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/mdadm/mdadm_4.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/minicom/minicom_2.7.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/newt/libnewt_0.52.21.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/pam/libpam_1.5.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/procps/procps_3.3.17.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/quota/quota_4.06.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/rpcbind/rpcbind_1.2.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/rpcbind/rpcbind_1.2.5.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/sed/sed_4.8.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/shadow/shadow-securetty_4.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/shadow/shadow_4.8.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/slang/slang_2.3.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/tar/tar_1.34.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/tcp-wrappers/tcp-wrappers_7.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/timezone/tzcode-native.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/timezone/tzcode-native.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/timezone/tzdata.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/unzip/unzip_6.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/which/which_2.21.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/xz/xz_5.2.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/zip/zip_3.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/zstd/zstd_1.4.9.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gdk-pixbuf/gdk-pixbuf_2.40.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gnome/adwaita-icon-theme_3.34.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gobject-introspection/gobject-introspection_1.66.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gtk+/gtk+3_3.24.25.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/hicolor-icon-theme/hicolor-icon-theme_0.17.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/cairo/cairo_1.16.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/cantarell-fonts/cantarell-fonts_0.301.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/fontconfig/fontconfig_2.13.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/freetype/freetype_2.10.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/glslang/glslang_11.2.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/harfbuzz/harfbuzz_2.7.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/jpeg/libjpeg-turbo_2.0.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/libepoxy/libepoxy_1.5.5.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/mesa/mesa_21.0.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/packagegroups/packagegroup-core-weston.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/pango/pango_1.48.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/spir/spirv-headers_1.5.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/spir/spirv-tools_2020.7.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/ttf-fonts/liberation-fonts_2.00.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/vulkan/assimp_5.0.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/vulkan/vulkan-headers_1.2.170.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/vulkan/vulkan-loader_1.2.170.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/wayland/libinput_1.16.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/wayland/mtdev_1.1.6.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/wayland/wayland-utils_1.0.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/wayland/wayland_1.19.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/wayland/weston-init.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/wayland/weston-init.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libpciaccess_0.16.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libpthread-stubs_0.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libx11-compose-data_1.6.8.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxkbcommon_1.0.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/pixman_0.40.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/xkeyboard-config_2.32.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-util/util-macros_1.19.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/blktrace/blktrace_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/cryptodev/cryptodev-linux_1.12.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/cryptodev/cryptodev-module_1.12.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/kmod/kmod-native_git.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/kmod/kmod-native_git.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/kmod/kmod_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/linux-firmware/linux-firmware_20210208.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/lttng/babeltrace2_2.0.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/lttng/babeltrace_1.5.8.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/make-mod-scripts/make-mod-scripts_1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/perf/perf.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/powertop/powertop_2.13.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/systemtap/systemtap_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/wireless-regdb/wireless-regdb_2020.11.20.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/alsa/alsa-lib_1.2.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/alsa/alsa-topology-conf_1.2.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/alsa/alsa-ucm-conf_1.2.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/alsa/alsa-utils_1.2.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/flac/flac_1.3.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libogg/libogg_1.3.4.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libpng/libpng_1.6.37.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libsamplerate/libsamplerate0_0.1.9.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libsndfile/libsndfile1_1.0.28.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libtheora/libtheora_1.1.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libtiff/tiff_4.2.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libvorbis/libvorbis_1.3.7.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/webp/libwebp_1.2.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/atk/atk_2.36.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/attr/acl_2.2.53.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/attr/attr_2.5.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/bash-completion/bash-completion_2.11.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/boost/boost-build-native_4.3.0.bb:do_deploy_source_date_epoch',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/boost/boost-build-native_4.3.0.bb:do_populate_sysroot',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/boost/boost_1.75.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/ca-certificates/ca-certificates_20210119.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/curl/curl_7.75.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/db/db_5.3.28.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/fribidi/fribidi_1.0.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/gdbm/gdbm_1.19.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/gmp/gmp_6.2.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/gnome-desktop-testing/gnome-desktop-testing_2018.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/gnutls/gnutls_3.7.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/icu/icu_68.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/iso-codes/iso-codes_4.6.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libatomic-ops/libatomic-ops_7.6.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcap-ng/libcap-ng_0.8.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcap/libcap_2.48.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcheck/libcheck_0.15.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcroco/libcroco_0.6.13.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libdaemon/libdaemon_0.14.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libevdev/libevdev_1.11.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libevent/libevent_2.1.12.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libexif/libexif_0.6.22.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libffi/libffi_3.3.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libgcrypt/libgcrypt_1.9.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libgpg-error/libgpg-error_1.41.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libical/libical_3.0.9.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libmpc/libmpc_1.2.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libnl/libnl_3.5.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libpcre/libpcre_8.44.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libunistring/libunistring_0.9.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libunwind/libunwind_1.5.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libusb/libusb1_1.0.24.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/lzo/lzo_2.10.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/mpfr/mpfr_4.1.0.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/nettle/nettle_3.7.2.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/popt/popt_1.18.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/ptest-runner/ptest-runner_2.4.1.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/shared-mime-info/shared-mime-info_git.bb:do_package',
'/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/sqlite/sqlite3_3.35.0.bb:do_package',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-bsp/u-boot/u-boot-imx-tools_2021.04.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-bsp/u-boot/u-boot-imx-tools_2021.04.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-devtools/python/python3-pycryptodomex_3.9.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-devtools/python/python3-pycryptodomex_3.9.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-devtools/python/python3-pyelftools_0.25.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-imx/meta-bsp/recipes-devtools/python/python3-pyelftools_0.25.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-devtools/protobuf/protobuf_3.15.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-oe/recipes-devtools/protobuf/protobuf_3.15.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-python/recipes-devtools/python/python3-pycrypto_2.6.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/meta-openembedded/meta-python/recipes-devtools/python/python3-pycrypto_2.6.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/openssl/openssl_1.1.1k.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-connectivity/openssl/openssl_1.1.1k.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/coreutils/coreutils_8.32.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/coreutils/coreutils_8.32.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/dbus/dbus_1.12.20.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/dbus/dbus_1.12.20.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/expat/expat_2.2.10.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/expat/expat_2.2.10.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/gettext/gettext_0.21.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/gettext/gettext_0.21.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glib-2.0/glib-2.0_2.66.7.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glib-2.0/glib-2.0_2.66.7.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/libxml/libxml2_2.9.10.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/libxml/libxml2_2.9.10.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/ncurses/ncurses_6.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/ncurses/ncurses_6.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/readline/readline_8.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/readline/readline_8.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/update-rc.d/update-rc.d_0.8.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/update-rc.d/update-rc.d_0.8.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/util-linux/util-linux-libuuid_2.36.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/util-linux/util-linux-libuuid_2.36.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/util-linux/util-linux_2.36.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/util-linux/util-linux_2.36.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/binutils/binutils_2.36.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/binutils/binutils_2.36.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/chrpath/chrpath_0.16.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/chrpath/chrpath_0.16.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/docbook-xml/docbook-xml-dtd4_4.5.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/docbook-xml/docbook-xml-dtd4_4.5.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/docbook-xml/docbook-xsl-stylesheets_1.79.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/docbook-xml/docbook-xsl-stylesheets_1.79.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/dosfstools/dosfstools_4.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/dosfstools/dosfstools_4.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/dwarfsrcfiles/dwarfsrcfiles.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/dwarfsrcfiles/dwarfsrcfiles.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/e2fsprogs/e2fsprogs_1.46.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/e2fsprogs/e2fsprogs_1.46.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/elfutils/elfutils_0.183.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/elfutils/elfutils_0.183.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/fdisk/gptfdisk_1.0.7.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/fdisk/gptfdisk_1.0.7.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/file/file_5.39.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/file/file_5.39.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/help2man/help2man_1.48.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/help2man/help2man_1.48.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/intltool/intltool_0.51.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/intltool/intltool_0.51.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/meson/meson_0.57.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/meson/meson_0.57.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/mtools/mtools_4.0.26.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/mtools/mtools_4.0.26.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/ninja/ninja_1.10.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/ninja/ninja_1.10.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/opkg-utils/opkg-utils_0.4.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/opkg-utils/opkg-utils_0.4.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/opkg/opkg_0.4.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/opkg/opkg_0.4.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/orc/orc_0.4.32.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/orc/orc_0.4.32.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/patchelf/patchelf_0.12.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/patchelf/patchelf_0.12.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/perl/libxml-parser-perl_2.46.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/perl/libxml-parser-perl_2.46.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/perl/perl_5.32.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/perl/perl_5.32.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/prelink/prelink_git.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/prelink/prelink_git.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-cython_0.29.22.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-cython_0.29.22.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-mako_1.1.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-mako_1.1.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-setuptools-scm_5.0.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-setuptools-scm_5.0.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-setuptools_54.1.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-setuptools_54.1.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-six_1.15.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-six_1.15.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-toml_0.10.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3-toml_0.10.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3_3.9.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/python/python3_3.9.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/rpm/rpm_4.16.1.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/rpm/rpm_4.16.1.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/swig/swig_3.0.12.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/swig/swig_3.0.12.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/tcltk/tcl_8.6.11.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/tcltk/tcl_8.6.11.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/unfs3/unfs3_git.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/unfs3/unfs3_git.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/xmlto/xmlto_0.0.28.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-devtools/xmlto/xmlto_0.0.28.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/asciidoc/asciidoc_9.1.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/asciidoc/asciidoc_9.1.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/bc/bc_1.07.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/bc/bc_1.07.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/bzip2/bzip2_1.0.8.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/bzip2/bzip2_1.0.8.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/cracklib/cracklib_2.9.5.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/cracklib/cracklib_2.9.5.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/cwautomacros/cwautomacros_20110201.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/cwautomacros/cwautomacros_20110201.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libarchive/libarchive_3.5.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libarchive/libarchive_3.5.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libnsl/libnsl2_git.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libnsl/libnsl2_git.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libsolv/libsolv_0.7.17.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libsolv/libsolv_0.7.17.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libtirpc/libtirpc_1.3.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/libtirpc/libtirpc_1.3.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/lzip/lzip_1.22.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/lzip/lzip_1.22.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/parted/parted_3.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/parted/parted_3.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/pbzip2/pbzip2_1.1.13.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/pbzip2/pbzip2_1.1.13.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/pigz/pigz_2.6.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/pigz/pigz_2.6.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/shadow/shadow_4.8.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/shadow/shadow_4.8.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/unzip/unzip_6.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-extended/unzip/unzip_6.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gdk-pixbuf/gdk-pixbuf_2.40.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gdk-pixbuf/gdk-pixbuf_2.40.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gobject-introspection/gobject-introspection_1.66.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gobject-introspection/gobject-introspection_1.66.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gtk+/gtk+3_3.24.25.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gtk+/gtk+3_3.24.25.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gtk-doc/gtk-doc_1.33.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/gtk-doc/gtk-doc_1.33.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/librsvg/librsvg_2.40.21.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-gnome/librsvg/librsvg_2.40.21.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/cairo/cairo_1.16.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/cairo/cairo_1.16.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/drm/libdrm_2.4.104.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/drm/libdrm_2.4.104.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/fontconfig/fontconfig_2.13.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/fontconfig/fontconfig_2.13.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/freetype/freetype_2.10.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/freetype/freetype_2.10.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/glslang/glslang_11.2.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/glslang/glslang_11.2.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/harfbuzz/harfbuzz_2.7.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/harfbuzz/harfbuzz_2.7.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/jpeg/libjpeg-turbo_2.0.6.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/jpeg/libjpeg-turbo_2.0.6.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/libepoxy/libepoxy_1.5.5.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/libepoxy/libepoxy_1.5.5.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/libsdl2/libsdl2_2.0.14.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/libsdl2/libsdl2_2.0.14.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/mesa/mesa_21.0.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/mesa/mesa_21.0.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/pango/pango_1.48.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/pango/pango_1.48.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/virglrenderer/virglrenderer_0.8.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/virglrenderer/virglrenderer_0.8.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/wayland/wayland_1.19.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/wayland/wayland_1.19.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-app/xrandr_1.5.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-app/xrandr_1.5.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libice_1.0.10.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libice_1.0.10.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libpciaccess_0.16.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libpciaccess_0.16.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libpthread-stubs_0.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libpthread-stubs_0.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libsm_1.2.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libsm_1.2.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libx11_1.7.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libx11_1.7.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxau_1.0.9.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxau_1.0.9.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxcb_1.14.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxcb_1.14.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxcomposite_0.4.5.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxcomposite_0.4.5.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxcursor_1.2.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxcursor_1.2.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxdamage_1.1.5.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxdamage_1.1.5.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxdmcp_1.1.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxdmcp_1.1.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxext_1.3.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxext_1.3.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxfixes_5.0.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxfixes_5.0.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxft_2.3.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxft_2.3.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxi_1.7.10.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxi_1.7.10.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxrandr_1.5.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxrandr_1.5.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxrender_0.9.10.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxrender_0.9.10.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxtst_1.2.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxtst_1.2.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxxf86vm_1.1.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/libxxf86vm_1.1.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/pixman_0.40.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/pixman_0.40.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/xtrans_1.4.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-lib/xtrans_1.4.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-proto/xcb-proto_1.14.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-proto/xcb-proto_1.14.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-proto/xorgproto_2020.1.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-proto/xorgproto_2020.1.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-util/makedepend_1.0.6.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-util/makedepend_1.0.6.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-util/util-macros_1.19.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-graphics/xorg-util/util-macros_1.19.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/dtc/dtc_1.6.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-kernel/dtc/dtc_1.6.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/alsa/alsa-lib_1.2.4.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/alsa/alsa-lib_1.2.4.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libpng/libpng_1.6.37.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-multimedia/libpng/libpng_1.6.37.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/atk/at-spi2-atk_2.38.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/atk/at-spi2-atk_2.38.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/atk/at-spi2-core_2.38.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/atk/at-spi2-core_2.38.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/atk/atk_2.36.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/atk/atk_2.36.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/bmap-tools/bmap-tools_3.6.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/bmap-tools/bmap-tools_3.6.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/curl/curl_7.75.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/curl/curl_7.75.0.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/db/db_5.3.28.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/db/db_5.3.28.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/debianutils/debianutils_4.11.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/debianutils/debianutils_4.11.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/fribidi/fribidi_1.0.10.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/fribidi/fribidi_1.0.10.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/gdbm/gdbm_1.19.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/gdbm/gdbm_1.19.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/icu/icu_68.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/icu/icu_68.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/itstool/itstool_2.0.6.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/itstool/itstool_2.0.6.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcap-ng/libcap-ng_0.8.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcap-ng/libcap-ng_0.8.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcap/libcap_2.48.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcap/libcap_2.48.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcroco/libcroco_0.6.13.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libcroco/libcroco_0.6.13.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libffi/libffi_3.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libffi/libffi_3.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libgcrypt/libgcrypt_1.9.2.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libgcrypt/libgcrypt_1.9.2.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libgpg-error/libgpg-error_1.41.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libgpg-error/libgpg-error_1.41.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libical/libical_3.0.9.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libical/libical_3.0.9.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libpcre/libpcre2_10.36.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libpcre/libpcre2_10.36.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libpcre/libpcre_8.44.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libpcre/libpcre_8.44.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libxslt/libxslt_1.1.34.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/libxslt/libxslt_1.1.34.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/lzo/lzo_2.10.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/lzo/lzo_2.10.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/lzop/lzop_1.04.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/lzop/lzop_1.04.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/re2c/re2c_2.0.3.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/re2c/re2c_2.0.3.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/shared-mime-info/shared-mime-info_git.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/shared-mime-info/shared-mime-info_git.bb:do_populate_sysroot',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/sqlite/sqlite3_3.35.0.bb:do_deploy_source_date_epoch',
'virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-support/sqlite/sqlite3_3.35.0.bb:do_populate_sysroot'}
ERROR: Task (virtual:native:/home/user1/fsl-imx-wayland_sdk/layers/poky/meta/recipes-core/glib-2.0/glib-2.0_2.66.7.bb:do_write_config) failed with exit code 'setscene whitelist'
