wic image with custom names for u-boot and kernel Image
4,413 次查看
richc128
I'm working with gatesgarth and a compulab i.mx8mp module. I'm signing my flash.bin and Image file so I get new files flash.bin.signed and Image.signed.
I'd like these images to end up in the wic image rather than the unsigned files. I'd be fine with either of these solutions:
  1. I can figure out what recipe packages the wic file and change the names there
  2. Figure out who makes the symbolic links and change those. For instance, have a recipe do this imx-boot -> flash.bin.signed
What recipe controls wic image creation? Maybe I can start there.
4,379 次查看
richc128
thanks @Zhiming_Liu the file is imx-imx-boot-bootpart.wks.in and can be overwritten by simply defining ones own with WKS_FILE
6 回复数
4,380 次查看
richc128
4,399 次查看
richc128
@Zhiming_Liuimx-boot is the bootloader. What recipe controls wic image creation, e.g., figures out what the partition layout is and what files go into it?
4,386 次查看
Zhiming_Liu
The folder is meta-freescale/wic
wks document:
https://docs.yoctoproject.org/ref-manual/kickstart.html
4,406 次查看
Zhiming_Liu
You need find .bb file about imx-boot
4,353 次查看
songhongliang
I hope that the image compiled by yocto can automatically expand the partition, then I can compile a smaller image to flash, saving the flashing time.
4,354 次查看
songhongliang
hi Qmiller
imx8, after I flash the machine, the entire emmc is only used about 4GB, if my EMMC is a 16GB, how can I allocate the remaining storage to the root directory
