why mx28 soc io virt base defined as 0xf0000000?
959件の閲覧回数
ask
Hi all,
The below macro is defined in arch/arm/mach-mx28/include/mach/mx28.h in a file.
#define MX28_SOC_IO_VIRT_BASE 0xF0000000
Please any one can explain me the reason?
Thanks in advace.
ラベル(2)
826件の閲覧回数
igorpadykov
Hi ask
no special reason, but this figure makes code with
better visibility, also there is unification with i.MX23 codes.
