Hi NXP
Because yocto is too big to build system images, and I want to use buildroot to build linux system images. Can I should to do?please share me some docs or links?
解決済! 解決策の投稿を見る。
HI @liangyan
You can use the bitbake imx-image-core command to generate the small image.
B,R
