viv_samples UnitTests execute failed
2,193 次查看
wei-fonglin
Hi All,
We made a custom i.MX6q board. The BSP version is imx-3.10.53-1.1.2_patch.
We executed the test applications in /opt/viv_samples/cl11/UnitTest/test_vivante
and found functions_and_kernels 、multi_dimensional_arrays、initializers and structs_and_enums were failed to pass.
But if we recompile the os with imx-gpu-viv version imx-gpu-viv_5.0.11.p4.1-hfp, these test applications passed.
Due to customer's spec, we have to use imx-gpu-viv version imx-gpu-viv_5.0.11.p4.3-hfp.
Is there any way to solve these problems in version 5.0.11.p4.3? Thanks.
Original Attachment has been moved to: structs_and_enums.log.zip
Original Attachment has been moved to: functions_and_kernels.log.zip
Original Attachment has been moved to: initializers.log.zip
Original Attachment has been moved to: multi_dimensional_arrays.log.zip
标签 (5)
1,986 次查看
Bio_TICFSL
Hi Wei-Fong,
You should give a try to the latest  imx-gpu-viv-5.0.11.p4.5
Hope it helps
1,986 次查看
wei-fonglin
Hi Bio_TICFSL,
Thanks for reply.
I tried imx-gpu-viv-5.0.11.p4.5 today but had the same situation.
Do you find the same problem in sabresd or any development board ?
Because I want to know if this is caused by our wrong settings or any other reason.
Thanks.
