Hi NXP,
I'm testing with imx8qm mek and 4 ov10635 cameras.
I run below command to save image files as jpeg.
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=NV12 ! v4l2jpegenc output-io-mode=5 ! multifilesink location=cam1_%05d.jpeg \
gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=NV12 ! v4l2jpegenc output-io-mode=5 ! multifilesink location=cam2_%05d.jpeg \
gst-launch-1.0 v4l2src device=/dev/video3 ! video/x-raw,format=NV12 ! v4l2jpegenc output-io-mode=5 ! multifilesink location=cam3_%05d.jpeg \
gst-launch-1.0 v4l2src device=/dev/video4 ! video/x-raw,format=NV12 ! v4l2jpegenc output-io-mode=5 ! multifilesink location=cam4_%05d.jpeg -e
But I couldn't keep this command for about 30 minutes. Because there's an error about rpc message timeout and system was killed.
[ 1989.060952] imx-scu scu: RPC send msg timeout
[ 1989.065348] a72_clk: failed to get clock rate -110
[ 1992.128892] imx-scu scu: RPC send msg timeout
[ 1992.133305] read temp sensor 144 failed, could be SS powered off, ret -110
[ 1995.200825] imx-scu scu: RPC send msg timeout
Could you let me know is this a known issue? Or can I fix it by any update?
Dongjin Ha.
