using PlatformIO with mimxrt1010-EVK and onboard debugger
Daniel_Jankins
I am trying to use the PlatformIO with mimxrt1010-EVK.  I can compile the program fine.  I can can not download the program.
I am using zephyr-blink example.my platformio.ini file is
; PlatformIO Project Configuration File
;   Build options: build flags, source filter, extra scripting
;   Upload options: custom port, speed and extra flags
;   Library options: dependencies, extra library storages
; Please visit documentation for the other options and examples
[env:mimxrt1010_evk]
platform = nxpimxrt
framework = zephyr
board = mimxrt1010_evk
thank you
kerryzhou
Hi @Daniel_Jankins ,
  Do you try to use the west to flash the code like the following method:
In the old-time, we use the west to download the code successfully.
Wish it helps you!
Kerry
