use of VPU
use of VPU
998 次查看
erikraynolds
I'd like to use and try to use VPU unit for decoding h.264 - please can you share some example and use of VPU ?
952 次查看
joanxie
you can use gstreamer to playback the video, the simplest way is that you can use gplay-1.0, the command like "gplay-1.0 test.mp4", you also can refer to the document as below:
https://community.nxp.com/docs/DOC-343017
