usb device tree
usb device tree
1,478 次查看
razriel
I am working on imx8mn-ddr4-evk board preparing the images for my Target board.
I have modified the device tree files:
  • removing/disable elelment not needed.
  • allocating pins for GPIO's
although I have not touched anything related to the USB-C interface it is not identified after I flash the new device tree created.
probably there is something I disable that affect the USB-C. most of my changes are done in imx8mn-evk.dtsi file I am attaching.
please help identify what I am doing wrong.
1,431 次查看
shai_b
Senior Contributor II
Hi @razriel ,
After reviewing your device tree I have noticed that you by mistake disabled I2C2.
Please try to change the status to be "okay".
Hope this'll help you.
Kind regards,
Shai
1,450 次查看
Rita_Wang
Can the board work well when you using the default images?
