uboot transition between imx6q to imx6d
877件の閲覧回数
balasubramanian
My custom is same as the sabresd board. We are using  imx6d processor in our custom board. Can we use sabresd uboot 2013-04 for my custom board? If not means what are the files and contents  should i have to change in uboot.!!!
ラベル(3)
777件の閲覧回数
igorpadykov
Hi Bala
imx6q uboot will run on imx6d fine, for loading linux
one needs to use maxcpus=2 parameter.
Regarding usage of several cores one can look below
UBootStandalone < DULG < DENX
