uboot, linux, root fs for desktop display in QSB
1,332 次查看
jk1z
Dear All,
I compiled uboot, linux sources and able to boot from it using uSD and NFS.
Once I enable the VGA display, here is TUX symbol display only there. how to get the desktop kind of display in that, do I need to update rootfs?
the current rootfs I have taken from LTIB contents (one that came along with KIT).
I want to check some demo applications on the board. How to proceed on this?
kindly suggest.
regard,
jk
1,205 次查看
jk1z
Dear Lvica,
thanks for the reply. is there any rootfs I can directly use for this window based desktop environment in the IMX53 QSB?
regards,
jk
1,205 次查看
IvicaEftimovski
I am assuming you are talking about window manager (WM) when you say desktop. There are two flavors of it in the LTIB distribution that I have used: Matchbox and Enlightenment WM.
You will also need the X Windows, GNOME and their dependencies. I suggest building your package selection “FSL gnome release package”. This by default selects everything that you need for a WM and bundles the Matchbox with it.
