uboot building
uboot building
kapilkumar
Hi, All my dear Friends
I am trying to build androiid jb4.3_1.1.0 using the command
make 2>&1|tee build_sabresd_androoid.log
so, with the above command kernel image created (uImage). But, uboot i.e., (mkimage) is not created and showing some error like below:
make[1]: Leaving directory `/home/salher/IMX_SOURCES/home/calixto/freescale/kernel_imx'
install kernel modules: kernel_imx/drivers/net/wireless/rtl8723as/8723as.ko kernel_imx/net/wireless/cfg80211.ko
make[1]: Entering directory `/home/salher/IMX_SOURCES/home/calixto/freescale/bootable/bootloader/uboot-imx'
make[1]: Leaving directory `/home/salher/IMX_SOURCES/home/calixto/freescale/bootable/bootloader/uboot-imx'
awk '(NF && $1 !~ /^#/) { print $1 ": " $1 "_config; $(MAKE)" }' boards.cfg > .boards.depend
make: *** No rule to make target `mx6q_sabresd_android_config'. Stop.
make[1]: *** [mx6q_sabresd_android_config] Error 1
System not configured - see README
make[1]: *** [all] Error 1
install: cannot stat `bootable/bootloader/uboot-imx/u-boot.bin': No such file or directory
make: *** No rule to make target `mx6dl_sabresd_android_config'. Stop.
make[1]: *** [mx6dl_sabresd_android_config] Error 1
make: *** [out/target/product/sabresd_6dq/u-boot.bin] Error 1
Please, help me to solve it out.
Kapil Kumar
jimmychan
Are you follow the steps in Android user guide to build the BSP?
kapilkumar
Hi jimmychan
Thanks for your effort to answer my query. I got my problem solved by downloading u-boot source code from the link
git clone git://git.denx.de/u-boot-imx.git          // u-boot-imx(this got from   https://community.freescale.com/thread/310172)
jimmychan
kapilkumar
Yes.
