u-boot env does not changes after flashing new u-boot
adarsh1997
I need to change some u-boot environment variable for our use.
Steps i did:
1.changes env in include/configs file
2.clean u-boot
3.compile u-boot
4.Flash u-boot
But after flashing u-boot , env remain same as earlier.What wrong i am doing or what is the issue?
Also if i am trying to change env from command line utility(fw_setenv) then also i am not able to change env after reboot.
FYI: I am trying to change env -->> console = null. but it remains ttymxc0 always
Please let me know how can i change u-boot env from command line or by flashing u-boot after changes.
Hi Adarsh
one can look at uboot documentation
https://www.denx.de/wiki/publish/DULG/to-delete/UBootCmdGroupEnvironment.html
For "fw_setenv" may be useful below
https://lists.yoctoproject.org/g/meta-freescale/topic/80166140#24632
