u-boot config file
u-boot config file
2,044 次查看
goto11
Hello,Community
The following two configuration files are stored in "... / board / freescale / mx7dsabresd".
What is the difference between the files?
How should I use files properly?
imximage.cfg
imximage_TO_1_1.cfg
best regards
Goto
1,952 次查看
joanxie
it seems the silicon version, imximage_TO_1_1.cfg should be the latest version, for detailed information, you can refer to your own i.mx7d DCD settings, I compare these two files, imximage_TO_1_1.cfg add DDR_PHY settings and Anadig DDR PLL Control Register
1,953 次查看
joanxie
