I've build uboot, kernel, and rootfs images(using bitbake commands) and success bring up on the Yocto board, but i meet some issue on toolchain and native library when not to use bitbake commands...
- source .../fsl-imx-wayland/4.14-sumo/environment-setup-aarch64-poky-linux
- trying to build busybox by make commands => failed by "some native library not found"
- Also, i got similar issues when trying to build kernel driver module which using xenomai-3.x => failed by "can not found linux native headers"
Any suggestion to solve these conflicts between toolchain and linux native library and headers
Thank You~
[Error detail]
- busybox error msg:
/usr/bin/ld: cannot find -lncursesw
=> i found library under "imx-yocto-bsp/build-wayland/tmp/work/aarch64-poky-linux/busybox/1.27.2-r0/recipe-sysroot-native/" and trying to copy the library to toolchain, but still failed - the headers in 3rd party xenomai using "include_next" to include the linux native headers, and failed by "file not found", since kernel can not include glibc headers
