the error of the sd with qsb program
ylw
i designed one design that is full of references to the QSB,.and
one board can boot from sd and works fine,but the other board is
not ok .i uused the external power boxeri to supply the power and
the power is 12v,and i used one dc-dc to make 5v.if not plug the
sd into the socket,the power is 12v,but when plug the sd into the
socket ,the power is down to 5v.and when i plug the sd (no
program) into the socket, the power is 12v and all power of the
imx53 is fine .so i want to know what happens .thanks a lot !
jimmychan
if one board is working fine but the other one is not working well, most likely is a hardware issue. Please double check all the pmic voltage outputs are correct and check the SD part of circuit.
ylw
hi ,i guess the problem is MICROSD part of circuit.and if i fix it ok ,i will try to boot the board by sd3.thank you again .
在 2013-01-09 16:23:26,jimmychan <admin@community.freescale.com> 写道:
created by jimmychan in i.MX Community - View the full discussion
Reply to this message by replying to this email -or- go to the message on Freescale Community
Start a new discussion in i.MX Community by email or at Freescale Community
