the Linux host can not assign a device node to the SD/MMC card reader
2,432 次查看
cody
I am using a Linux Host to Set Up an SD/MMC Card.
I  used Ubuntu 9.04.
when I  punge in the SD/MMC Card and enter the command:
aaron@aaron:~$ cat  /proc/partitions
major minor  #blocks  name
  8        0   20971520 sda
   8        1   20049088 sda1
   8        2          1 sda2
   8        5     915673 sda5
-------it  looks like that   the Linux host can  not  assign a device node to the SD/MMC card reader
aaron@aaron:~$ sudo dmesg
[    0.000000] BIOS EBDA/lowmem at: 0009f800/0009f800
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.28-19-generic (buildd@vernadsky) (gcc version 4.3.3 (Ubuntu 4.3.3-5ubuntu4) ) #66-Ubuntu SMP Sat Oct 16 17:39:04 UTC 2010 (Ubuntu 2.6.28-19.66-generic)
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   NSC Geode by NSC
[    0.000000]   Cyrix CyrixInstead
[    0.000000]   Centaur CentaurHauls
[    0.000000]   Transmeta GenuineTMx86
[    0.000000]   Transmeta TransmetaCPU
[    0.000000]   UMC UMC UMC UMC
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[    0.000000]  BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000ca000 - 00000000000cc000 (reserved)
[    0.000000]  BIOS-e820: 00000000000dc000 - 00000000000e4000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e8000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 000000001fef0000 (usable)
[    0.000000]  BIOS-e820: 000000001fef0000 - 000000001feff000 (ACPI data)
[    0.000000]  BIOS-e820: 000000001feff000 - 000000001ff00000 (ACPI NVS)
[    0.000000]  BIOS-e820: 000000001ff00000 - 0000000020000000 (usable)
[    0.000000]  BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[    0.000000]  BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[    0.000000]  BIOS-e820: 00000000fffe0000 - 0000000100000000 (reserved)
[    0.000000] DMI present.
[    0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working it around.
[    0.000000] last_pfn = 0x20000 max_arch_pfn = 0x100000
[    0.000000] Scanning 0 areas for low memory corruption
[    0.000000] modified physical RAM map:
[    0.000000]  modified: 0000000000000000 - 0000000000010000 (reserved)
[    0.000000]  modified: 0000000000010000 - 000000000009f800 (usable)
[    0.000000]  modified: 000000000009f800 - 00000000000a0000 (reserved)
[    0.000000]  modified: 00000000000ca000 - 00000000000cc000 (reserved)
[    0.000000]  modified: 00000000000dc000 - 00000000000e4000 (reserved)
[    0.000000]  modified: 00000000000e8000 - 0000000000100000 (reserved)
[    0.000000]  modified: 0000000000100000 - 000000001fef0000 (usable)
[    0.000000]  modified: 000000001fef0000 - 000000001feff000 (ACPI data)
[    0.000000]  modified: 000000001feff000 - 000000001ff00000 (ACPI NVS)
[    0.000000]  modified: 000000001ff00000 - 0000000020000000 (usable)
[    0.000000]  modified: 00000000e0000000 - 00000000f0000000 (reserved)
[    0.000000]  modified: 00000000fec00000 - 00000000fec10000 (reserved)
[    0.000000]  modified: 00000000fee00000 - 00000000fee01000 (reserved)
[    0.000000]  modified: 00000000fffe0000 - 0000000100000000 (reserved)
[    0.000000] kernel direct mapping tables up to 20000000 @ 10000-15000
[    0.000000] RAMDISK: 1f7a8000 - 1fedf437
[    0.000000] ACPI: RSDP 000F6940, 0024 (r2 PTLTD )
[    0.000000] ACPI: XSDT 1FEF079A, 004C (r1 INTEL  440BX     6040000 VMW   1324272)
[    0.000000] ACPI: FACP 1FEFEE98, 00F4 (r4 INTEL  440BX     6040000 PTL     F4240)
[    0.000000] ACPI: DSDT 1FEF0960, E538 (r1 PTLTD  Custom    6040000 MSFT  3000001)
[    0.000000] ACPI: FACS 1FEFFFC0, 0040
[    0.000000] ACPI: BOOT 1FEF0938, 0028 (r1 PTLTD  $SBFTBL$  6040000  LTP        1)
[    0.000000] ACPI: APIC 1FEF08DA, 005E (r1 PTLTD   APIC    6040000  LTP        0)
[    0.000000] ACPI: MCFG 1FEF089E, 003C (r1 PTLTD  $PCITBL$  6040000  LTP        1)
[    0.000000] ACPI: SRAT 1FEF081E, 0080 (r2 VMWARE MEMPLUG   6040000 VMW         1)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 0MB HIGHMEM available.
[    0.000000] 512MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 20000000
[    0.000000]   low ram: 00000000 - 20000000
[    0.000000]   bootmap 00011000 - 00015000
[    0.000000] (9 early reservations) ==> bootmem [0000000000 - 0020000000]
[    0.000000]   #0 [0000000000 - 0000001000]   BIOS data page ==> [0000000000 - 0000001000]
[    0.000000]   #1 [0000001000 - 0000002000]    EX TRAMPOLINE ==> [0000001000 - 0000002000]
[    0.000000]   #2 [0000006000 - 0000007000]       TRAMPOLINE ==> [0000006000 - 0000007000]
[    0.000000]   #3 [0000100000 - 00008780ac]    TEXT DATA BSS ==> [0000100000 - 00008780ac]
[    0.000000]   #4 [001f7a8000 - 001fedf437]          RAMDISK ==> [001f7a8000 - 001fedf437]
[    0.000000]   #5 [0000879000 - 000087d000]    INIT_PG_TABLE ==> [0000879000 - 000087d000]
[    0.000000]   #6 [000009f800 - 0000100000]    BIOS reserved ==> [000009f800 - 0000100000]
[    0.000000]   #7 [0000010000 - 0000011000]          PGTABLE ==> [0000010000 - 0000011000]
[    0.000000]   #8 [0000011000 - 0000015000]          BOOTMAP ==> [0000011000 - 0000015000]
[    0.000000] found SMP MP-table at [c00f69b0] 000f69b0
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x00020000
[    0.000000]   HighMem  0x00020000 -> 0x00020000
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[3] active PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009f
[    0.000000]     0: 0x00000100 -> 0x0001fef0
[    0.000000]     0: 0x0001ff00 -> 0x00020000
[    0.000000] On node 0 totalpages: 130943
[    0.000000] free_area_init_node: node 0, pgdat c06cb780, node_mem_map c1000200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3951 pages, LIFO batch:0
[    0.000000]   Normal zone: 992 pages used for memmap
[    0.000000]   Normal zone: 125968 pages, LIFO batch:31
[    0.000000]   HighMem zone: 0 pages used for memmap
[    0.000000]   Movable zone: 0 pages used for memmap
[    0.000000] ACPI: PM-Timer IO Port: 0x1008
[    0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000ca000
[    0.000000] PM: Registered nosave memory: 00000000000ca000 - 00000000000cc000
[    0.000000] PM: Registered nosave memory: 00000000000cc000 - 00000000000dc000
[    0.000000] PM: Registered nosave memory: 00000000000dc000 - 00000000000e4000
[    0.000000] PM: Registered nosave memory: 00000000000e4000 - 00000000000e8000
[    0.000000] PM: Registered nosave memory: 00000000000e8000 - 0000000000100000
[    0.000000] PM: Registered nosave memory: 000000001fef0000 - 000000001feff000
[    0.000000] PM: Registered nosave memory: 000000001feff000 - 000000001ff00000
[    0.000000] Allocating PCI resources starting at 30000000 (gap: 20000000:c0000000)
[    0.000000] PERCPU: Allocating 45056 bytes of per cpu data
[    0.000000] NR_CPUS: 64, nr_cpu_ids: 2, nr_node_ids 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129919
[    0.000000] Kernel command line: root=UUID=4cd19d43-ef10-48a7-95e5-3e39997f407c ro locale=zh_CN quiet splash
[    0.000000] Enabling fast FPU save and restore... done.
[    0.000000] Enabling unmasked SIMD FPU exception support... done.
[    0.000000] Initializing CPU#0
[    0.000000] PID hash table entries: 2048 (order: 11, 8192 bytes)
[    0.000000] Extended CMOS year: 2000
[    0.000000] TSC: Frequency read from the hypervisor
[    0.000000] Detected 2926.020 MHz processor.
[    0.004000] Console: colour VGA+ 80x25
[    0.004000] console [tty0] enabled
[    0.004000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.004000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.004000] allocated 2621120 bytes of page_cgroup
[    0.004000] please try cgroup_disable=memory option if you don't want
[    0.004000] Scanning for low memory corruption every 60 seconds
[    0.004000] Memory: 501296k/524288k available (4116k kernel code, 22240k reserved, 2198k data, 532k init, 0k highmem)
[    0.004000] virtual kernel memory layout:
[    0.004000]     fixmap  : 0xffc77000 - 0xfffff000   (3616 kB)
[    0.004000]     pkmap   : 0xff400000 - 0xff800000   (4096 kB)
[    0.004000]     vmalloc : 0xe0800000 - 0xff3fe000   ( 491 MB)
[    0.004000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.004000]       .init : 0xc0733000 - 0xc07b8000   ( 532 kB)
[    0.004000]       .data : 0xc05052e1 - 0xc072ae60   (2198 kB)
[    0.004000]       .text : 0xc0100000 - 0xc05052e1   (4116 kB)
[    0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.004000] SLUB: Genslabs=12, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.004017] Calibrating delay loop (skipped), value calculated using timer frequency.. 5852.04 BogoMIPS (lpj=11704080)
[    0.004177] Security Framework initialized
[    0.004188] SELinux:  Disabled at boot.
[    0.004326] AppArmor: AppArmor initialized
[    0.004334] Mount-cache hash table entries: 512
[    0.004781] Initializing cgroup subsys ns
[    0.004787] Initializing cgroup subsys cpuacct
[    0.004789] Initializing cgroup subsys memory
[    0.004806] Initializing cgroup subsys freezer
[    0.004832] CPU: Physical Processor ID: 0
[    0.004841] CPU: L1 I cache: 32K, L1 D cache: 32K
[    0.004842] CPU: L2 cache: 3072K
[    0.004868] Checking 'hlt' instruction... OK.
[    0.024007] ACPI: Core revision 20080926
[    0.024287] ACPI: Checking initramfs for custom DSDT
[    0.249792] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.289473] CPU0: Intel(R) Core(TM)2 Duo CPU     E7500  @ 2.93GHz stepping 0a
[    0.292001] Booting processor 1 APIC 0x1 ip 0x6000
[    0.004000] Initializing CPU#1
[    0.004000] Calibrating delay using timer specific routine.. 5768.83 BogoMIPS (lpj=11537676)
[    0.004000] CPU: Physical Processor ID: 1
[    0.004000] CPU: L1 I cache: 32K, L1 D cache: 32K
[    0.004000] CPU: L2 cache: 3072K
[    0.380201] CPU1: Intel(R) Core(TM)2 Duo CPU     E7500  @ 2.93GHz stepping 0a
[    0.381530] Skipping synchronization checks as TSC is reliable.
[    0.381658] Brought up 2 CPUs
[    0.381660] Total of 2 processors activated (11620.87 BogoMIPS).
[    0.381903] CPU0 attaching sched-domain:
[    0.381907]  domain 0: span 0-1 level CPU
[    0.381911]   groups: 0 1
[    0.381918] CPU1 attaching sched-domain:
[    0.381919]  domain 0: span 0-1 level CPU
[    0.381921]   groups: 1 0
[    0.382052] net_namespace: 776 bytes
[    0.382052] Booting paravirtualized kernel on bare hardware
[    0.382052] Time:  1:49:57  Date: 03/10/14
[    0.382052] regulator: core version 0.5
[    0.382052] NET: Registered protocol family 16
[    0.382052] EISA bus registered
[    0.382052] ACPI: bus type pci registered
[    0.382052] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[    0.382052] PCI: MCFG area at e0000000 reserved in E820
[    0.382052] PCI: Using MMCONFIG for extended config space
[    0.382052] PCI: Using configuration type 1 for base access
[    0.388430] ACPI: EC: Look up EC in DSDT
[    0.436670] ACPI: BIOS _OSI(Linux) query ignored
[    0.443376] ACPI: Interpreter enabled
[    0.443389] ACPI: (supports S0 S1 S4 S5)
[    0.443417] ACPI: Using IOAPIC for interrupt routing
[    0.537704] ACPI: No dock devices found.
[    0.537836] ACPI: PCI Root Bridge [PCI0] (0000:00)
[    0.539767] pci 0000:00:07.1: reg 20 io port: [0x10c0-0x10cf]
[    0.540420] pci 0000:00:07.3: quirk: region 1000-103f claimed by PIIX4 ACPI
[    0.540434] pci 0000:00:07.3: quirk: region 1040-104f claimed by PIIX4 SMB
[    0.541150] pci 0000:00:07.7: reg 10 io port: [0x1080-0x10bf]
[    0.543130] pci 0000:00:0f.0: reg 10 io port: [0x10d0-0x10df]
[    0.543177] pci 0000:00:0f.0: reg 14 32bit mmio: [0xd0000000-0xd7ffffff]
[    0.543220] pci 0000:00:0f.0: reg 18 32bit mmio: [0xd8000000-0xd87fffff]
[    0.543388] pci 0000:00:0f.0: reg 30 32bit mmio: [0x000000-0x007fff]
[    0.544005] pci 0000:00:10.0: reg 10 io port: [0x1400-0x14ff]
[    0.544634] pci 0000:00:10.0: reg 14 64bit mmio: [0xd8820000-0xd883ffff]
[    0.545306] pci 0000:00:10.0: reg 1c 64bit mmio: [0xd8800000-0xd881ffff]
[    0.545393] pci 0000:00:10.0: reg 30 32bit mmio: [0x000000-0x003fff]
[    0.546302] pci 0000:00:15.0: PME# supported from D0 D3hot D3cold
[    0.546336] pci 0000:00:15.0: PME# disabled
[    0.546994] pci 0000:00:15.1: PME# supported from D0 D3hot D3cold
[    0.547085] pci 0000:00:15.1: PME# disabled
[    0.547748] pci 0000:00:15.2: PME# supported from D0 D3hot D3cold
[    0.547783] pci 0000:00:15.2: PME# disabled
[    0.548437] pci 0000:00:15.3: PME# supported from D0 D3hot D3cold
[    0.548461] pci 0000:00:15.3: PME# disabled
[    0.548956] pci 0000:00:15.4: PME# supported from D0 D3hot D3cold
[    0.548979] pci 0000:00:15.4: PME# disabled
[    0.549469] pci 0000:00:15.5: PME# supported from D0 D3hot D3cold
[    0.549492] pci 0000:00:15.5: PME# disabled
[    0.550021] pci 0000:00:15.6: PME# supported from D0 D3hot D3cold
[    0.550044] pci 0000:00:15.6: PME# disabled
[    0.550541] pci 0000:00:15.7: PME# supported from D0 D3hot D3cold
[    0.550563] pci 0000:00:15.7: PME# disabled
[    0.551098] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.551122] pci 0000:00:16.0: PME# disabled
[    0.551621] pci 0000:00:16.1: PME# supported from D0 D3hot D3cold
[    0.551644] pci 0000:00:16.1: PME# disabled
[    0.552180] pci 0000:00:16.2: PME# supported from D0 D3hot D3cold
[    0.552203] pci 0000:00:16.2: PME# disabled
[    0.552699] pci 0000:00:16.3: PME# supported from D0 D3hot D3cold
[    0.552721] pci 0000:00:16.3: PME# disabled
[    0.553298] pci 0000:00:16.4: PME# supported from D0 D3hot D3cold
[    0.553321] pci 0000:00:16.4: PME# disabled
[    0.553816] pci 0000:00:16.5: PME# supported from D0 D3hot D3cold
[    0.553839] pci 0000:00:16.5: PME# disabled
[    0.554358] pci 0000:00:16.6: PME# supported from D0 D3hot D3cold
[    0.554381] pci 0000:00:16.6: PME# disabled
[    0.554875] pci 0000:00:16.7: PME# supported from D0 D3hot D3cold
[    0.554899] pci 0000:00:16.7: PME# disabled
[    0.555392] pci 0000:00:17.0: PME# supported from D0 D3hot D3cold
[    0.555415] pci 0000:00:17.0: PME# disabled
[    0.555946] pci 0000:00:17.1: PME# supported from D0 D3hot D3cold
[    0.556004] pci 0000:00:17.1: PME# disabled
[    0.556506] pci 0000:00:17.2: PME# supported from D0 D3hot D3cold
[    0.556529] pci 0000:00:17.2: PME# disabled
[    0.557063] pci 0000:00:17.3: PME# supported from D0 D3hot D3cold
[    0.557086] pci 0000:00:17.3: PME# disabled
[    0.557583] pci 0000:00:17.4: PME# supported from D0 D3hot D3cold
[    0.557606] pci 0000:00:17.4: PME# disabled
[    0.558100] pci 0000:00:17.5: PME# supported from D0 D3hot D3cold
[    0.558122] pci 0000:00:17.5: PME# disabled
[    0.558637] pci 0000:00:17.6: PME# supported from D0 D3hot D3cold
[    0.558660] pci 0000:00:17.6: PME# disabled
[    0.559156] pci 0000:00:17.7: PME# supported from D0 D3hot D3cold
[    0.559182] pci 0000:00:17.7: PME# disabled
[    0.560035] pci 0000:00:18.0: PME# supported from D0 D3hot D3cold
[    0.560058] pci 0000:00:18.0: PME# disabled
[    0.560553] pci 0000:00:18.1: PME# supported from D0 D3hot D3cold
[    0.560576] pci 0000:00:18.1: PME# disabled
[    0.561084] pci 0000:00:18.2: PME# supported from D0 D3hot D3cold
[    0.561107] pci 0000:00:18.2: PME# disabled
[    0.561603] pci 0000:00:18.3: PME# supported from D0 D3hot D3cold
[    0.561625] pci 0000:00:18.3: PME# disabled
[    0.562245] pci 0000:00:18.4: PME# supported from D0 D3hot D3cold
[    0.562268] pci 0000:00:18.4: PME# disabled
[    0.562765] pci 0000:00:18.5: PME# supported from D0 D3hot D3cold
[    0.562788] pci 0000:00:18.5: PME# disabled
[    0.563283] pci 0000:00:18.6: PME# supported from D0 D3hot D3cold
[    0.563306] pci 0000:00:18.6: PME# disabled
[    0.563800] pci 0000:00:18.7: PME# supported from D0 D3hot D3cold
[    0.563823] pci 0000:00:18.7: PME# disabled
[    0.565260] pci 0000:02:00.0: reg 20 io port: [0x20c0-0x20df]
[    0.565945] pci 0000:02:01.0: reg 10 io port: [0x2000-0x207f]
[    0.566195] pci 0000:02:01.0: reg 30 32bit mmio: [0x000000-0x00ffff]
[    0.566933] pci 0000:02:02.0: reg 10 io port: [0x2080-0x20bf]
[    0.567629] pci 0000:02:03.0: reg 10 32bit mmio: [0xd8900000-0xd8900fff]
[    0.568224] pci 0000:00:11.0: transparent bridge
[    0.568246] pci 0000:00:11.0: bridge io port: [0x2000-0x3fff]
[    0.568270] pci 0000:00:11.0: bridge 32bit mmio: [0xd8900000-0xd9cfffff]
[    0.568317] pci 0000:00:11.0: bridge 64bit mmio pref: [0xdc400000-0xdc9fffff]
[    0.568773] pci 0000:00:15.0: bridge io port: [0x4000-0x4fff]
[    0.568796] pci 0000:00:15.0: bridge 32bit mmio: [0xd9d00000-0xd9dfffff]
[    0.568840] pci 0000:00:15.0: bridge 64bit mmio pref: [0xdca00000-0xdcafffff]
[    0.569289] pci 0000:00:15.1: bridge io port: [0x8000-0x8fff]
[    0.569312] pci 0000:00:15.1: bridge 32bit mmio: [0xda100000-0xda1fffff]
[    0.569356] pci 0000:00:15.1: bridge 64bit mmio pref: [0xdce00000-0xdcefffff]
[    0.569787] pci 0000:00:15.2: bridge io port: [0xc000-0xcfff]
[    0.569811] pci 0000:00:15.2: bridge 32bit mmio: [0xda500000-0xda5fffff]
[    0.569855] pci 0000:00:15.2: bridge 64bit mmio pref: [0xdd200000-0xdd2fffff]
[    0.570382] pci 0000:00:15.3: bridge 32bit mmio: [0xda900000-0xda9fffff]
[    0.570427] pci 0000:00:15.3: bridge 64bit mmio pref: [0xdd600000-0xdd6fffff]
[    0.570898] pci 0000:00:15.4: bridge 32bit mmio: [0xdad00000-0xdadfffff]
[    0.570943] pci 0000:00:15.4: bridge 64bit mmio pref: [0xdda00000-0xddafffff]
[    0.571396] pci 0000:00:15.5: bridge 32bit mmio: [0xdb100000-0xdb1fffff]
[    0.571441] pci 0000:00:15.5: bridge 64bit mmio pref: [0xdde00000-0xddefffff]
[    0.571965] pci 0000:00:15.6: bridge 32bit mmio: [0xdb500000-0xdb5fffff]
[    0.572052] pci 0000:00:15.6: bridge 64bit mmio pref: [0xde200000-0xde2fffff]
[    0.572506] pci 0000:00:15.7: bridge 32bit mmio: [0xdb900000-0xdb9fffff]
[    0.572550] pci 0000:00:15.7: bridge 64bit mmio pref: [0xde600000-0xde6fffff]
[    0.572989] pci 0000:00:16.0: bridge io port: [0x5000-0x5fff]
[    0.573013] pci 0000:00:16.0: bridge 32bit mmio: [0xd9e00000-0xd9efffff]
[    0.573057] pci 0000:00:16.0: bridge 64bit mmio pref: [0xdcb00000-0xdcbfffff]
[    0.573498] pci 0000:00:16.1: bridge io port: [0x9000-0x9fff]
[    0.573522] pci 0000:00:16.1: bridge 32bit mmio: [0xda200000-0xda2fffff]
[    0.573566] pci 0000:00:16.1: bridge 64bit mmio pref: [0xdcf00000-0xdcffffff]
[    0.574018] pci 0000:00:16.2: bridge io port: [0xd000-0xdfff]
[    0.574041] pci 0000:00:16.2: bridge 32bit mmio: [0xda600000-0xda6fffff]
[    0.574086] pci 0000:00:16.2: bridge 64bit mmio pref: [0xdd300000-0xdd3fffff]
[    0.574546] pci 0000:00:16.3: bridge 32bit mmio: [0xdaa00000-0xdaafffff]
[    0.574590] pci 0000:00:16.3: bridge 64bit mmio pref: [0xdd700000-0xdd7fffff]
[    0.575046] pci 0000:00:16.4: bridge 32bit mmio: [0xdae00000-0xdaefffff]
[    0.575093] pci 0000:00:16.4: bridge 64bit mmio pref: [0xddb00000-0xddbfffff]
[    0.575547] pci 0000:00:16.5: bridge 32bit mmio: [0xdb200000-0xdb2fffff]
[    0.575591] pci 0000:00:16.5: bridge 64bit mmio pref: [0xddf00000-0xddffffff]
[    0.576196] pci 0000:00:16.6: bridge 32bit mmio: [0xdb600000-0xdb6fffff]
[    0.576240] pci 0000:00:16.6: bridge 64bit mmio pref: [0xde300000-0xde3fffff]
[    0.576731] pci 0000:00:16.7: bridge 32bit mmio: [0xdba00000-0xdbafffff]
[    0.576775] pci 0000:00:16.7: bridge 64bit mmio pref: [0xde700000-0xde7fffff]
[    0.577223] pci 0000:00:17.0: bridge io port: [0x6000-0x6fff]
[    0.577246] pci 0000:00:17.0: bridge 32bit mmio: [0xd9f00000-0xd9ffffff]
[    0.577291] pci 0000:00:17.0: bridge 64bit mmio pref: [0xdcc00000-0xdccfffff]
[    0.577724] pci 0000:00:17.1: bridge io port: [0xa000-0xafff]
[    0.577747] pci 0000:00:17.1: bridge 32bit mmio: [0xda300000-0xda3fffff]
[    0.577792] pci 0000:00:17.1: bridge 64bit mmio pref: [0xdd000000-0xdd0fffff]
[    0.578247] pci 0000:00:17.2: bridge io port: [0xe000-0xefff]
[    0.578270] pci 0000:00:17.2: bridge 32bit mmio: [0xda700000-0xda7fffff]
[    0.578314] pci 0000:00:17.2: bridge 64bit mmio pref: [0xdd400000-0xdd4fffff]
[    0.578768] pci 0000:00:17.3: bridge 32bit mmio: [0xdab00000-0xdabfffff]
[    0.579061] pci 0000:00:17.3: bridge 64bit mmio pref: [0xdd800000-0xdd8fffff]
[    0.579520] pci 0000:00:17.4: bridge 32bit mmio: [0xdaf00000-0xdaffffff]
[    0.579564] pci 0000:00:17.4: bridge 64bit mmio pref: [0xddc00000-0xddcfffff]
[    0.580193] pci 0000:00:17.5: bridge 32bit mmio: [0xdb300000-0xdb3fffff]
[    0.580237] pci 0000:00:17.5: bridge 64bit mmio pref: [0xde000000-0xde0fffff]
[    0.580814] pci 0000:00:17.6: bridge 32bit mmio: [0xdb700000-0xdb7fffff]
[    0.580874] pci 0000:00:17.6: bridge 64bit mmio pref: [0xde400000-0xde4fffff]
[    0.581356] pci 0000:00:17.7: bridge 32bit mmio: [0xdbb00000-0xdbbfffff]
[    0.581400] pci 0000:00:17.7: bridge 64bit mmio pref: [0xde800000-0xde8fffff]
[    0.581836] pci 0000:00:18.0: bridge io port: [0x7000-0x7fff]
[    0.581859] pci 0000:00:18.0: bridge 32bit mmio: [0xda000000-0xda0fffff]
[    0.581907] pci 0000:00:18.0: bridge 64bit mmio pref: [0xdcd00000-0xdcdfffff]
[    0.582341] pci 0000:00:18.1: bridge io port: [0xb000-0xbfff]
[    0.582364] pci 0000:00:18.1: bridge 32bit mmio: [0xda400000-0xda4fffff]
[    0.582409] pci 0000:00:18.1: bridge 64bit mmio pref: [0xdd100000-0xdd1fffff]
[    0.582843] pci 0000:00:18.2: bridge io port: [0xf000-0xffff]
[    0.582866] pci 0000:00:18.2: bridge 32bit mmio: [0xda800000-0xda8fffff]
[    0.582911] pci 0000:00:18.2: bridge 64bit mmio pref: [0xdd500000-0xdd5fffff]
[    0.583366] pci 0000:00:18.3: bridge 32bit mmio: [0xdac00000-0xdacfffff]
[    0.583410] pci 0000:00:18.3: bridge 64bit mmio pref: [0xdd900000-0xdd9fffff]
[    0.583869] pci 0000:00:18.4: bridge 32bit mmio: [0xdb000000-0xdb0fffff]
[    0.583940] pci 0000:00:18.4: bridge 64bit mmio pref: [0xddd00000-0xdddfffff]
[    0.584432] pci 0000:00:18.5: bridge 32bit mmio: [0xdb400000-0xdb4fffff]
[    0.584476] pci 0000:00:18.5: bridge 64bit mmio pref: [0xde100000-0xde1fffff]
[    0.584938] pci 0000:00:18.6: bridge 32bit mmio: [0xdb800000-0xdb8fffff]
[    0.584982] pci 0000:00:18.6: bridge 64bit mmio pref: [0xde500000-0xde5fffff]
[    0.585436] pci 0000:00:18.7: bridge 32bit mmio: [0xdbc00000-0xdbcfffff]
[    0.585480] pci 0000:00:18.7: bridge 64bit mmio pref: [0xde900000-0xde9fffff]
[    0.588009] bus 00 -> node 0
[    0.588028] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.835926] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *9 10 11 14 15)
[    0.836139] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11 14 15)
[    0.836312] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 *10 11 14 15)
[    0.836494] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 9 10 11 14 15)
[    0.836738] ACPI: WMI: Mapper loaded
[    0.837986] SCSI subsystem initialized
[    0.837986] libata version 3.00 loaded.
[    0.837986] usbcore: registered new interface driver usbfs
[    0.837986] usbcore: registered new interface driver hub
[    0.837986] usbcore: registered new device driver usb
[    0.837986] PCI: Using ACPI for IRQ routing
[    0.844025] Bluetooth: Core ver 2.13
[    0.844185] NET: Registered protocol family 31
[    0.844185] Bluetooth: HCI device and connection manager initialized
[    0.844185] Bluetooth: HCI socket layer initialized
[    0.844185] NET: Registered protocol family 8
[    0.844185] NET: Registered protocol family 20
[    0.844185] NetLabel: Initializing
[    0.844185] NetLabel:  domain hash size = 128
[    0.844185] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.844185] NetLabel:  unlabeled traffic allowed by default
[    0.844288] AppArmor: AppArmor Filesystem Enabled
[    0.848137] Switched to high resolution mode on CPU 0
[    0.848152] pnp: PnP ACPI init
[    0.848170] ACPI: bus type pnp registered
[    0.849026] Switched to high resolution mode on CPU 1
[    0.912267] pnp: PnP ACPI: found 13 devices
[    0.912272] ACPI: ACPI bus type pnp unregistered
[    0.912289] PnPBIOS: Disabled by ACPI PNP
[    0.912327] system 00:01: ioport range 0x1000-0x103f has been reserved
[    0.912329] system 00:01: ioport range 0x1040-0x104f has been reserved
[    0.912331] system 00:01: ioport range 0xcf0-0xcf1 has been reserved
[    0.912339] system 00:0c: ioport range 0x1060-0x107f has been reserved
[    0.912342] system 00:0c: iomem range 0xe0000000-0xefffffff has been reserved
[    0.912344] system 00:0c: iomem range 0xdbe00000-0xdbffffff has been reserved
[    0.948076] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[    0.948079] pci 0000:00:01.0:   IO window: disabled
[    0.948113] pci 0000:00:01.0:   MEM window: disabled
[    0.948136] pci 0000:00:01.0:   PREFETCH window: disabled
[    0.948180] pci 0000:00:11.0: PCI bridge, secondary bus 0000:02
[    0.948194] pci 0000:00:11.0:   IO window: 0x2000-0x3fff
[    0.948227] pci 0000:00:11.0:   MEM window: 0xd8900000-0xd9cfffff
[    0.948249] pci 0000:00:11.0:   PREFETCH window: 0x000000dc400000-0x000000dc9fffff
[    0.948292] pci 0000:00:15.0: PCI bridge, secondary bus 0000:03
[    0.948306] pci 0000:00:15.0:   IO window: 0x4000-0x4fff
[    0.948338] pci 0000:00:15.0:   MEM window: 0xd9d00000-0xd9dfffff
[    0.948361] pci 0000:00:15.0:   PREFETCH window: 0x000000dca00000-0x000000dcafffff
[    0.948469] pci 0000:00:15.1: PCI bridge, secondary bus 0000:04
[    0.948484] pci 0000:00:15.1:   IO window: 0x8000-0x8fff
[    0.948516] pci 0000:00:15.1:   MEM window: 0xda100000-0xda1fffff
[    0.948539] pci 0000:00:15.1:   PREFETCH window: 0x000000dce00000-0x000000dcefffff
[    0.948600] pci 0000:00:15.2: PCI bridge, secondary bus 0000:05
[    0.948614] pci 0000:00:15.2:   IO window: 0xc000-0xcfff
[    0.948647] pci 0000:00:15.2:   MEM window: 0xda500000-0xda5fffff
[    0.948670] pci 0000:00:15.2:   PREFETCH window: 0x000000dd200000-0x000000dd2fffff
[    0.948729] pci 0000:00:15.3: PCI bridge, secondary bus 0000:06
[    0.948732] pci 0000:00:15.3:   IO window: disabled
[    0.948765] pci 0000:00:15.3:   MEM window: 0xda900000-0xda9fffff
[    0.948788] pci 0000:00:15.3:   PREFETCH window: 0x000000dd600000-0x000000dd6fffff
[    0.948847] pci 0000:00:15.4: PCI bridge, secondary bus 0000:07
[    0.948849] pci 0000:00:15.4:   IO window: disabled
[    0.948883] pci 0000:00:15.4:   MEM window: 0xdad00000-0xdadfffff
[    0.948905] pci 0000:00:15.4:   PREFETCH window: 0x000000dda00000-0x000000ddafffff
[    0.948966] pci 0000:00:15.5: PCI bridge, secondary bus 0000:08
[    0.948968] pci 0000:00:15.5:   IO window: disabled
[    0.948997] pci 0000:00:15.5:   MEM window: 0xdb100000-0xdb1fffff
[    0.948997] pci 0000:00:15.5:   PREFETCH window: 0x000000dde00000-0x000000ddefffff
[    0.948997] pci 0000:00:15.6: PCI bridge, secondary bus 0000:09
[    0.948997] pci 0000:00:15.6:   IO window: disabled
[    0.948997] pci 0000:00:15.6:   MEM window: 0xdb500000-0xdb5fffff
[    0.948997] pci 0000:00:15.6:   PREFETCH window: 0x000000de200000-0x000000de2fffff
[    0.948997] pci 0000:00:15.7: PCI bridge, secondary bus 0000:0a
[    0.948997] pci 0000:00:15.7:   IO window: disabled
[    0.948997] pci 0000:00:15.7:   MEM window: 0xdb900000-0xdb9fffff
[    0.948997] pci 0000:00:15.7:   PREFETCH window: 0x000000de600000-0x000000de6fffff
[    0.948997] pci 0000:00:16.0: PCI bridge, secondary bus 0000:0b
[    0.948997] pci 0000:00:16.0:   IO window: 0x5000-0x5fff
[    0.948997] pci 0000:00:16.0:   MEM window: 0xd9e00000-0xd9efffff
[    0.948997] pci 0000:00:16.0:   PREFETCH window: 0x000000dcb00000-0x000000dcbfffff
[    0.948997] pci 0000:00:16.1: PCI bridge, secondary bus 0000:0c
[    0.948997] pci 0000:00:16.1:   IO window: 0x9000-0x9fff
[    0.948997] pci 0000:00:16.1:   MEM window: 0xda200000-0xda2fffff
[    0.948997] pci 0000:00:16.1:   PREFETCH window: 0x000000dcf00000-0x000000dcffffff
[    0.948997] pci 0000:00:16.2: PCI bridge, secondary bus 0000:0d
[    0.948997] pci 0000:00:16.2:   IO window: 0xd000-0xdfff
[    0.948997] pci 0000:00:16.2:   MEM window: 0xda600000-0xda6fffff
[    0.948997] pci 0000:00:16.2:   PREFETCH window: 0x000000dd300000-0x000000dd3fffff
[    0.948997] pci 0000:00:16.3: PCI bridge, secondary bus 0000:0e
[    0.948997] pci 0000:00:16.3:   IO window: disabled
[    0.948997] pci 0000:00:16.3:   MEM window: 0xdaa00000-0xdaafffff
[    0.948997] pci 0000:00:16.3:   PREFETCH window: 0x000000dd700000-0x000000dd7fffff
[    0.948997] pci 0000:00:16.4: PCI bridge, secondary bus 0000:0f
[    0.948997] pci 0000:00:16.4:   IO window: disabled
[    0.948997] pci 0000:00:16.4:   MEM window: 0xdae00000-0xdaefffff
[    0.948997] pci 0000:00:16.4:   PREFETCH window: 0x000000ddb00000-0x000000ddbfffff
[    0.948997] pci 0000:00:16.5: PCI bridge, secondary bus 0000:10
[    0.948997] pci 0000:00:16.5:   IO window: disabled
[    0.949006] pci 0000:00:16.5:   MEM window: 0xdb200000-0xdb2fffff
[    0.949029] pci 0000:00:16.5:   PREFETCH window: 0x000000ddf00000-0x000000ddffffff
[    0.949088] pci 0000:00:16.6: PCI bridge, secondary bus 0000:11
[    0.949090] pci 0000:00:16.6:   IO window: disabled
[    0.949124] pci 0000:00:16.6:   MEM window: 0xdb600000-0xdb6fffff
[    0.949146] pci 0000:00:16.6:   PREFETCH window: 0x000000de300000-0x000000de3fffff
[    0.949205] pci 0000:00:16.7: PCI bridge, secondary bus 0000:12
[    0.949208] pci 0000:00:16.7:   IO window: disabled
[    0.949241] pci 0000:00:16.7:   MEM window: 0xdba00000-0xdbafffff
[    0.949264] pci 0000:00:16.7:   PREFETCH window: 0x000000de700000-0x000000de7fffff
[    0.949323] pci 0000:00:17.0: PCI bridge, secondary bus 0000:13
[    0.949337] pci 0000:00:17.0:   IO window: 0x6000-0x6fff
[    0.949370] pci 0000:00:17.0:   MEM window: 0xd9f00000-0xd9ffffff
[    0.949393] pci 0000:00:17.0:   PREFETCH window: 0x000000dcc00000-0x000000dccfffff
[    0.949452] pci 0000:00:17.1: PCI bridge, secondary bus 0000:14
[    0.949466] pci 0000:00:17.1:   IO window: 0xa000-0xafff
[    0.949498] pci 0000:00:17.1:   MEM window: 0xda300000-0xda3fffff
[    0.949521] pci 0000:00:17.1:   PREFETCH window: 0x000000dd000000-0x000000dd0fffff
[    0.949580] pci 0000:00:17.2: PCI bridge, secondary bus 0000:15
[    0.949594] pci 0000:00:17.2:   IO window: 0xe000-0xefff
[    0.949627] pci 0000:00:17.2:   MEM window: 0xda700000-0xda7fffff
[    0.949650] pci 0000:00:17.2:   PREFETCH window: 0x000000dd400000-0x000000dd4fffff
[    0.949709] pci 0000:00:17.3: PCI bridge, secondary bus 0000:16
[    0.949711] pci 0000:00:17.3:   IO window: disabled
[    0.949744] pci 0000:00:17.3:   MEM window: 0xdab00000-0xdabfffff
[    0.949767] pci 0000:00:17.3:   PREFETCH window: 0x000000dd800000-0x000000dd8fffff
[    0.949826] pci 0000:00:17.4: PCI bridge, secondary bus 0000:17
[    0.949831] pci 0000:00:17.4:   IO window: disabled
[    0.949864] pci 0000:00:17.4:   MEM window: 0xdaf00000-0xdaffffff
[    0.949887] pci 0000:00:17.4:   PREFETCH window: 0x000000ddc00000-0x000000ddcfffff
[    0.949946] pci 0000:00:17.5: PCI bridge, secondary bus 0000:18
[    0.949948] pci 0000:00:17.5:   IO window: disabled
[    0.950028] pci 0000:00:17.5:   MEM window: 0xdb300000-0xdb3fffff
[    0.950051] pci 0000:00:17.5:   PREFETCH window: 0x000000de000000-0x000000de0fffff
[    0.950111] pci 0000:00:17.6: PCI bridge, secondary bus 0000:19
[    0.950113] pci 0000:00:17.6:   IO window: disabled
[    0.950146] pci 0000:00:17.6:   MEM window: 0xdb700000-0xdb7fffff
[    0.950169] pci 0000:00:17.6:   PREFETCH window: 0x000000de400000-0x000000de4fffff
[    0.950228] pci 0000:00:17.7: PCI bridge, secondary bus 0000:1a
[    0.950230] pci 0000:00:17.7:   IO window: disabled
[    0.950264] pci 0000:00:17.7:   MEM window: 0xdbb00000-0xdbbfffff
[    0.950286] pci 0000:00:17.7:   PREFETCH window: 0x000000de800000-0x000000de8fffff
[    0.950345] pci 0000:00:18.0: PCI bridge, secondary bus 0000:1b
[    0.950360] pci 0000:00:18.0:   IO window: 0x7000-0x7fff
[    0.950392] pci 0000:00:18.0:   MEM window: 0xda000000-0xda0fffff
[    0.950415] pci 0000:00:18.0:   PREFETCH window: 0x000000dcd00000-0x000000dcdfffff
[    0.950475] pci 0000:00:18.1: PCI bridge, secondary bus 0000:1c
[    0.950489] pci 0000:00:18.1:   IO window: 0xb000-0xbfff
[    0.950522] pci 0000:00:18.1:   MEM window: 0xda400000-0xda4fffff
[    0.950545] pci 0000:00:18.1:   PREFETCH window: 0x000000dd100000-0x000000dd1fffff
[    0.950604] pci 0000:00:18.2: PCI bridge, secondary bus 0000:1d
[    0.950618] pci 0000:00:18.2:   IO window: 0xf000-0xffff
[    0.950651] pci 0000:00:18.2:   MEM window: 0xda800000-0xda8fffff
[    0.950674] pci 0000:00:18.2:   PREFETCH window: 0x000000dd500000-0x000000dd5fffff
[    0.950733] pci 0000:00:18.3: PCI bridge, secondary bus 0000:1e
[    0.950735] pci 0000:00:18.3:   IO window: disabled
[    0.950768] pci 0000:00:18.3:   MEM window: 0xdac00000-0xdacfffff
[    0.950791] pci 0000:00:18.3:   PREFETCH window: 0x000000dd900000-0x000000dd9fffff
[    0.950850] pci 0000:00:18.4: PCI bridge, secondary bus 0000:1f
[    0.950852] pci 0000:00:18.4:   IO window: disabled
[    0.950886] pci 0000:00:18.4:   MEM window: 0xdb000000-0xdb0fffff
[    0.950908] pci 0000:00:18.4:   PREFETCH window: 0x000000ddd00000-0x000000dddfffff
[    0.950967] pci 0000:00:18.5: PCI bridge, secondary bus 0000:20
[    0.950978] pci 0000:00:18.5:   IO window: disabled
[    0.951012] pci 0000:00:18.5:   MEM window: 0xdb400000-0xdb4fffff
[    0.951035] pci 0000:00:18.5:   PREFETCH window: 0x000000de100000-0x000000de1fffff
[    0.951094] pci 0000:00:18.6: PCI bridge, secondary bus 0000:21
[    0.951096] pci 0000:00:18.6:   IO window: disabled
[    0.951129] pci 0000:00:18.6:   MEM window: 0xdb800000-0xdb8fffff
[    0.951152] pci 0000:00:18.6:   PREFETCH window: 0x000000de500000-0x000000de5fffff
[    0.951218] pci 0000:00:18.7: PCI bridge, secondary bus 0000:22
[    0.951221] pci 0000:00:18.7:   IO window: disabled
[    0.951254] pci 0000:00:18.7:   MEM window: 0xdbc00000-0xdbcfffff
[    0.951277] pci 0000:00:18.7:   PREFETCH window: 0x000000de900000-0x000000de9fffff
[    0.951388] pci 0000:00:01.0: setting latency timer to 64
[    0.951487] pci 0000:00:15.0: setting latency timer to 64
[    0.951552] pci 0000:00:15.1: setting latency timer to 64
[    0.951617] pci 0000:00:15.2: setting latency timer to 64
[    0.951682] pci 0000:00:15.3: setting latency timer to 64
[    0.951748] pci 0000:00:15.4: setting latency timer to 64
[    0.951813] pci 0000:00:15.5: setting latency timer to 64
[    0.951878] pci 0000:00:15.6: setting latency timer to 64
[    0.951943] pci 0000:00:15.7: setting latency timer to 64
[    0.952144] pci 0000:00:16.0: setting latency timer to 64
[    0.952289] pci 0000:00:16.1: setting latency timer to 64
[    0.952354] pci 0000:00:16.2: setting latency timer to 64
[    0.952419] pci 0000:00:16.3: setting latency timer to 64
[    0.952505] pci 0000:00:16.4: setting latency timer to 64
[    0.952571] pci 0000:00:16.5: setting latency timer to 64
[    0.952636] pci 0000:00:16.6: setting latency timer to 64
[    0.952702] pci 0000:00:16.7: setting latency timer to 64
[    0.952767] pci 0000:00:17.0: setting latency timer to 64
[    0.952858] pci 0000:00:17.1: setting latency timer to 64
[    0.952924] pci 0000:00:17.2: setting latency timer to 64
[    0.952989] pci 0000:00:17.3: setting latency timer to 64
[    0.952997] pci 0000:00:17.4: setting latency timer to 64
[    0.952997] pci 0000:00:17.5: setting latency timer to 64
[    0.952997] pci 0000:00:17.6: setting latency timer to 64
[    0.952997] pci 0000:00:17.7: setting latency timer to 64
[    0.952997] pci 0000:00:18.0: setting latency timer to 64
[    0.952997] pci 0000:00:18.1: setting latency timer to 64
[    0.952997] pci 0000:00:18.2: setting latency timer to 64
[    0.952997] pci 0000:00:18.3: setting latency timer to 64
[    0.952997] pci 0000:00:18.4: setting latency timer to 64
[    0.952997] pci 0000:00:18.5: setting latency timer to 64
[    0.952997] pci 0000:00:18.6: setting latency timer to 64
[    0.952997] pci 0000:00:18.7: setting latency timer to 64
[    0.953005] bus: 00 index 0 io port: [0x00-0xffff]
[    0.953009] bus: 00 index 1 mmio: [0x000000-0xffffffff]
[    0.953011] bus: 01 index 0 mmio: [0x0-0x0]
[    0.953013] bus: 01 index 1 mmio: [0x0-0x0]
[    0.953015] bus: 01 index 2 mmio: [0x0-0x0]
[    0.953017] bus: 01 index 3 mmio: [0x0-0x0]
[    0.953020] bus: 02 index 0 io port: [0x2000-0x3fff]
[    0.953022] bus: 02 index 1 mmio: [0xd8900000-0xd9cfffff]
[    0.953025] bus: 02 index 2 mmio: [0xdc400000-0xdc9fffff]
[    0.953027] bus: 02 index 3 io port: [0x00-0xffff]
[    0.953029] bus: 02 index 4 mmio: [0x000000-0xffffffff]
[    0.953031] bus: 03 index 0 io port: [0x4000-0x4fff]
[    0.953034] bus: 03 index 1 mmio: [0xd9d00000-0xd9dfffff]
[    0.953036] bus: 03 index 2 mmio: [0xdca00000-0xdcafffff]
[    0.953038] bus: 03 index 3 mmio: [0x0-0x0]
[    0.953041] bus: 04 index 0 io port: [0x8000-0x8fff]
[    0.953043] bus: 04 index 1 mmio: [0xda100000-0xda1fffff]
[    0.953045] bus: 04 index 2 mmio: [0xdce00000-0xdcefffff]
[    0.953047] bus: 04 index 3 mmio: [0x0-0x0]
[    0.953050] bus: 05 index 0 io port: [0xc000-0xcfff]
[    0.953052] bus: 05 index 1 mmio: [0xda500000-0xda5fffff]
[    0.953054] bus: 05 index 2 mmio: [0xdd200000-0xdd2fffff]
[    0.953056] bus: 05 index 3 mmio: [0x0-0x0]
[    0.953059] bus: 06 index 0 mmio: [0x0-0x0]
[    0.953061] bus: 06 index 1 mmio: [0xda900000-0xda9fffff]
[    0.953063] bus: 06 index 2 mmio: [0xdd600000-0xdd6fffff]
[    0.953065] bus: 06 index 3 mmio: [0x0-0x0]
[    0.953068] bus: 07 index 0 mmio: [0x0-0x0]
[    0.953070] bus: 07 index 1 mmio: [0xdad00000-0xdadfffff]
[    0.953072] bus: 07 index 2 mmio: [0xdda00000-0xddafffff]
[    0.953074] bus: 07 index 3 mmio: [0x0-0x0]
[    0.953076] bus: 08 index 0 mmio: [0x0-0x0]
[    0.953079] bus: 08 index 1 mmio: [0xdb100000-0xdb1fffff]
[    0.953081] bus: 08 index 2 mmio: [0xdde00000-0xddefffff]
[    0.953083] bus: 08 index 3 mmio: [0x0-0x0]
[    0.953085] bus: 09 index 0 mmio: [0x0-0x0]
[    0.953087] bus: 09 index 1 mmio: [0xdb500000-0xdb5fffff]
[    0.953090] bus: 09 index 2 mmio: [0xde200000-0xde2fffff]
[    0.953092] bus: 09 index 3 mmio: [0x0-0x0]
[    0.953094] bus: 0a index 0 mmio: [0x0-0x0]
[    0.953096] bus: 0a index 1 mmio: [0xdb900000-0xdb9fffff]
[    0.953098] bus: 0a index 2 mmio: [0xde600000-0xde6fffff]
[    0.953101] bus: 0a index 3 mmio: [0x0-0x0]
[    0.953103] bus: 0b index 0 io port: [0x5000-0x5fff]
[    0.953105] bus: 0b index 1 mmio: [0xd9e00000-0xd9efffff]
[    0.953107] bus: 0b index 2 mmio: [0xdcb00000-0xdcbfffff]
[    0.953114] bus: 0b index 3 mmio: [0x0-0x0]
[    0.953116] bus: 0c index 0 io port: [0x9000-0x9fff]
[    0.953118] bus: 0c index 1 mmio: [0xda200000-0xda2fffff]
[    0.953120] bus: 0c index 2 mmio: [0xdcf00000-0xdcffffff]
[    0.953123] bus: 0c index 3 mmio: [0x0-0x0]
[    0.953125] bus: 0d index 0 io port: [0xd000-0xdfff]
[    0.953127] bus: 0d index 1 mmio: [0xda600000-0xda6fffff]
[    0.953129] bus: 0d index 2 mmio: [0xdd300000-0xdd3fffff]
[    0.953131] bus: 0d index 3 mmio: [0x0-0x0]
[    0.953134] bus: 0e index 0 mmio: [0x0-0x0]
[    0.953136] bus: 0e index 1 mmio: [0xdaa00000-0xdaafffff]
[    0.953138] bus: 0e index 2 mmio: [0xdd700000-0xdd7fffff]
[    0.953140] bus: 0e index 3 mmio: [0x0-0x0]
[    0.953142] bus: 0f index 0 mmio: [0x0-0x0]
[    0.953145] bus: 0f index 1 mmio: [0xdae00000-0xdaefffff]
[    0.953147] bus: 0f index 2 mmio: [0xddb00000-0xddbfffff]
[    0.953149] bus: 0f index 3 mmio: [0x0-0x0]
[    0.953151] bus: 10 index 0 mmio: [0x0-0x0]
[    0.953153] bus: 10 index 1 mmio: [0xdb200000-0xdb2fffff]
[    0.953156] bus: 10 index 2 mmio: [0xddf00000-0xddffffff]
[    0.953158] bus: 10 index 3 mmio: [0x0-0x0]
[    0.953160] bus: 11 index 0 mmio: [0x0-0x0]
[    0.953162] bus: 11 index 1 mmio: [0xdb600000-0xdb6fffff]
[    0.953165] bus: 11 index 2 mmio: [0xde300000-0xde3fffff]
[    0.953167] bus: 11 index 3 mmio: [0x0-0x0]
[    0.953169] bus: 12 index 0 mmio: [0x0-0x0]
[    0.953171] bus: 12 index 1 mmio: [0xdba00000-0xdbafffff]
[    0.953174] bus: 12 index 2 mmio: [0xde700000-0xde7fffff]
[    0.953176] bus: 12 index 3 mmio: [0x0-0x0]
[    0.953178] bus: 13 index 0 io port: [0x6000-0x6fff]
[    0.953180] bus: 13 index 1 mmio: [0xd9f00000-0xd9ffffff]
[    0.953183] bus: 13 index 2 mmio: [0xdcc00000-0xdccfffff]
[    0.953185] bus: 13 index 3 mmio: [0x0-0x0]
[    0.953187] bus: 14 index 0 io port: [0xa000-0xafff]
[    0.953189] bus: 14 index 1 mmio: [0xda300000-0xda3fffff]
[    0.953192] bus: 14 index 2 mmio: [0xdd000000-0xdd0fffff]
[    0.953194] bus: 14 index 3 mmio: [0x0-0x0]
[    0.953196] bus: 15 index 0 io port: [0xe000-0xefff]
[    0.953198] bus: 15 index 1 mmio: [0xda700000-0xda7fffff]
[    0.953201] bus: 15 index 2 mmio: [0xdd400000-0xdd4fffff]
[    0.953203] bus: 15 index 3 mmio: [0x0-0x0]
[    0.953205] bus: 16 index 0 mmio: [0x0-0x0]
[    0.953207] bus: 16 index 1 mmio: [0xdab00000-0xdabfffff]
[    0.953210] bus: 16 index 2 mmio: [0xdd800000-0xdd8fffff]
[    0.953212] bus: 16 index 3 mmio: [0x0-0x0]
[    0.953214] bus: 17 index 0 mmio: [0x0-0x0]
[    0.953216] bus: 17 index 1 mmio: [0xdaf00000-0xdaffffff]
[    0.953219] bus: 17 index 2 mmio: [0xddc00000-0xddcfffff]
[    0.953221] bus: 17 index 3 mmio: [0x0-0x0]
[    0.953223] bus: 18 index 0 mmio: [0x0-0x0]
[    0.953225] bus: 18 index 1 mmio: [0xdb300000-0xdb3fffff]
[    0.953227] bus: 18 index 2 mmio: [0xde000000-0xde0fffff]
[    0.953230] bus: 18 index 3 mmio: [0x0-0x0]
[    0.953232] bus: 19 index 0 mmio: [0x0-0x0]
[    0.953234] bus: 19 index 1 mmio: [0xdb700000-0xdb7fffff]
[    0.953236] bus: 19 index 2 mmio: [0xde400000-0xde4fffff]
[    0.953239] bus: 19 index 3 mmio: [0x0-0x0]
[    0.953241] bus: 1a index 0 mmio: [0x0-0x0]
[    0.953243] bus: 1a index 1 mmio: [0xdbb00000-0xdbbfffff]
[    0.953245] bus: 1a index 2 mmio: [0xde800000-0xde8fffff]
[    0.953248] bus: 1a index 3 mmio: [0x0-0x0]
[    0.953250] bus: 1b index 0 io port: [0x7000-0x7fff]
[    0.953252] bus: 1b index 1 mmio: [0xda000000-0xda0fffff]
[    0.953254] bus: 1b index 2 mmio: [0xdcd00000-0xdcdfffff]
[    0.953257] bus: 1b index 3 mmio: [0x0-0x0]
[    0.953259] bus: 1c index 0 io port: [0xb000-0xbfff]
[    0.953261] bus: 1c index 1 mmio: [0xda400000-0xda4fffff]
[    0.953264] bus: 1c index 2 mmio: [0xdd100000-0xdd1fffff]
[    0.953266] bus: 1c index 3 mmio: [0x0-0x0]
[    0.953268] bus: 1d index 0 io port: [0xf000-0xffff]
[    0.953270] bus: 1d index 1 mmio: [0xda800000-0xda8fffff]
[    0.953274] bus: 1d index 2 mmio: [0xdd500000-0xdd5fffff]
[    0.953276] bus: 1d index 3 mmio: [0x0-0x0]
[    0.953279] bus: 1e index 0 mmio: [0x0-0x0]
[    0.953281] bus: 1e index 1 mmio: [0xdac00000-0xdacfffff]
[    0.953283] bus: 1e index 2 mmio: [0xdd900000-0xdd9fffff]
[    0.953285] bus: 1e index 3 mmio: [0x0-0x0]
[    0.953287] bus: 1f index 0 mmio: [0x0-0x0]
[    0.953290] bus: 1f index 1 mmio: [0xdb000000-0xdb0fffff]
[    0.953292] bus: 1f index 2 mmio: [0xddd00000-0xdddfffff]
[    0.953294] bus: 1f index 3 mmio: [0x0-0x0]
[    0.953296] bus: 20 index 0 mmio: [0x0-0x0]
[    0.953299] bus: 20 index 1 mmio: [0xdb400000-0xdb4fffff]
[    0.953301] bus: 20 index 2 mmio: [0xde100000-0xde1fffff]
[    0.953303] bus: 20 index 3 mmio: [0x0-0x0]
[    0.953305] bus: 21 index 0 mmio: [0x0-0x0]
[    0.953308] bus: 21 index 1 mmio: [0xdb800000-0xdb8fffff]
[    0.953310] bus: 21 index 2 mmio: [0xde500000-0xde5fffff]
[    0.953312] bus: 21 index 3 mmio: [0x0-0x0]
[    0.953314] bus: 22 index 0 mmio: [0x0-0x0]
[    0.953316] bus: 22 index 1 mmio: [0xdbc00000-0xdbcfffff]
[    0.953319] bus: 22 index 2 mmio: [0xde900000-0xde9fffff]
[    0.953321] bus: 22 index 3 mmio: [0x0-0x0]
[    0.953351] NET: Registered protocol family 2
[    0.968126] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.968769] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.970191] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.972566] TCP: Hash tables configured (established 65536 bind 65536)
[    0.972570] TCP reno registered
[    0.976207] NET: Registered protocol family 1
[    0.976341] checking if image is initramfs... it is
[    1.329307] Freeing initrd memory: 7389k freed
[    1.329366] Simple Boot Flag at 0x36 set to 0x1
[    1.332841] cpufreq: No nForce2 chipset.
[    1.333227] audit: initializing netlink socket (disabled)
[    1.333494] type=2000 audit(1394416197.332:1): initialized
[    1.335354] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    1.336627] VFS: Disk quotas dquot_6.5.1
[    1.336692] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.337659] fuse init (API version 7.10)
[    1.337790] msgmni has been set to 993
[    1.338190] alg: No test for stdrng (krng)
[    1.338207] io scheduler noop registered
[    1.338209] io scheduler anticipatory registered
[    1.338212] io scheduler deadline registered
[    1.338222] io scheduler cfq registered (default)
[    1.338244] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[    1.338312] pci 0000:00:0f.0: Boot video device
[    1.390690] pcieport-driver 0000:00:15.0: setting latency timer to 64
[    1.391274] pcieport-driver 0000:00:15.0: found MSI capability
[    1.391676] pcieport-driver 0000:00:15.0: irq 2303 for MSI/MSI-X
[    1.391829] pci_express 0000:00:15.0:pcie00: allocate port service
[    1.391867] pci_express 0000:00:15.0:pcie02: allocate port service
[    1.391991] pcieport-driver 0000:00:15.1: setting latency timer to 64
[    1.392089] pcieport-driver 0000:00:15.1: found MSI capability
[    1.392446] pcieport-driver 0000:00:15.1: irq 2302 for MSI/MSI-X
[    1.392581] pci_express 0000:00:15.1:pcie00: allocate port service
[    1.392595] pci_express 0000:00:15.1:pcie02: allocate port service
[    1.393137] pcieport-driver 0000:00:15.2: setting latency timer to 64
[    1.393640] pcieport-driver 0000:00:15.2: found MSI capability
[    1.394006] pcieport-driver 0000:00:15.2: irq 2301 for MSI/MSI-X
[    1.394142] pci_express 0000:00:15.2:pcie00: allocate port service
[    1.394157] pci_express 0000:00:15.2:pcie02: allocate port service
[    1.394658] pcieport-driver 0000:00:15.3: setting latency timer to 64
[    1.395153] pcieport-driver 0000:00:15.3: found MSI capability
[    1.395509] pcieport-driver 0000:00:15.3: irq 2300 for MSI/MSI-X
[    1.395644] pci_express 0000:00:15.3:pcie00: allocate port service
[    1.395678] pci_express 0000:00:15.3:pcie02: allocate port service
[    1.396153] pcieport-driver 0000:00:15.4: setting latency timer to 64
[    1.396632] pcieport-driver 0000:00:15.4: found MSI capability
[    1.396989] pcieport-driver 0000:00:15.4: irq 2299 for MSI/MSI-X
[    1.397148] pci_express 0000:00:15.4:pcie00: allocate port service
[    1.397159] pci_express 0000:00:15.4:pcie02: allocate port service
[    1.397656] pcieport-driver 0000:00:15.5: setting latency timer to 64
[    1.398146] pcieport-driver 0000:00:15.5: found MSI capability
[    1.398503] pcieport-driver 0000:00:15.5: irq 2298 for MSI/MSI-X
[    1.398639] pci_express 0000:00:15.5:pcie00: allocate port service
[    1.398685] pci_express 0000:00:15.5:pcie02: allocate port service
[    1.399456] pcieport-driver 0000:00:15.6: setting latency timer to 64
[    1.399991] pcieport-driver 0000:00:15.6: found MSI capability
[    1.399992] pcieport-driver 0000:00:15.6: irq 2297 for MSI/MSI-X
[    1.399992] pci_express 0000:00:15.6:pcie00: allocate port service
[    1.399992] pci_express 0000:00:15.6:pcie02: allocate port service
[    1.400198] pcieport-driver 0000:00:15.7: setting latency timer to 64
[    1.400688] pcieport-driver 0000:00:15.7: found MSI capability
[    1.401111] pcieport-driver 0000:00:15.7: irq 2296 for MSI/MSI-X
[    1.401247] pci_express 0000:00:15.7:pcie00: allocate port service
[    1.401268] pci_express 0000:00:15.7:pcie02: allocate port service
[    1.401782] pcieport-driver 0000:00:16.0: setting latency timer to 64
[    1.402272] pcieport-driver 0000:00:16.0: found MSI capability
[    1.402630] pcieport-driver 0000:00:16.0: irq 2295 for MSI/MSI-X
[    1.402765] pci_express 0000:00:16.0:pcie00: allocate port service
[    1.402787] pci_express 0000:00:16.0:pcie02: allocate port service
[    1.403405] pcieport-driver 0000:00:16.1: setting latency timer to 64
[    1.403886] pcieport-driver 0000:00:16.1: found MSI capability
[    1.404339] pcieport-driver 0000:00:16.1: irq 2294 for MSI/MSI-X
[    1.404475] pci_express 0000:00:16.1:pcie00: allocate port service
[    1.404527] pci_express 0000:00:16.1:pcie02: allocate port service
[    1.405110] pcieport-driver 0000:00:16.2: setting latency timer to 64
[    1.405591] pcieport-driver 0000:00:16.2: found MSI capability
[    1.405970] pcieport-driver 0000:00:16.2: irq 2293 for MSI/MSI-X
[    1.406106] pci_express 0000:00:16.2:pcie00: allocate port service
[    1.406144] pci_express 0000:00:16.2:pcie02: allocate port service
[    1.406640] pcieport-driver 0000:00:16.3: setting latency timer to 64
[    1.407131] pcieport-driver 0000:00:16.3: found MSI capability
[    1.407489] pcieport-driver 0000:00:16.3: irq 2292 for MSI/MSI-X
[    1.407626] pci_express 0000:00:16.3:pcie00: allocate port service
[    1.407637] pci_express 0000:00:16.3:pcie02: allocate port service
[    1.407992] pcieport-driver 0000:00:16.4: setting latency timer to 64
[    1.407992] pcieport-driver 0000:00:16.4: found MSI capability
[    1.408062] pcieport-driver 0000:00:16.4: irq 2291 for MSI/MSI-X
[    1.408198] pci_express 0000:00:16.4:pcie00: allocate port service
[    1.408209] pci_express 0000:00:16.4:pcie02: allocate port service
[    1.408710] pcieport-driver 0000:00:16.5: setting latency timer to 64
[    1.409225] pcieport-driver 0000:00:16.5: found MSI capability
[    1.409583] pcieport-driver 0000:00:16.5: irq 2290 for MSI/MSI-X
[    1.409718] pci_express 0000:00:16.5:pcie00: allocate port service
[    1.409764] pci_express 0000:00:16.5:pcie02: allocate port service
[    1.410273] pcieport-driver 0000:00:16.6: setting latency timer to 64
[    1.410751] pcieport-driver 0000:00:16.6: found MSI capability
[    1.411115] pcieport-driver 0000:00:16.6: irq 2289 for MSI/MSI-X
[    1.411250] pci_express 0000:00:16.6:pcie00: allocate port service
[    1.411264] pci_express 0000:00:16.6:pcie02: allocate port service
[    1.411763] pcieport-driver 0000:00:16.7: setting latency timer to 64
[    1.412046] pcieport-driver 0000:00:16.7: found MSI capability
[    1.412407] pcieport-driver 0000:00:16.7: irq 2288 for MSI/MSI-X
[    1.412543] pci_express 0000:00:16.7:pcie00: allocate port service
[    1.412640] pci_express 0000:00:16.7:pcie02: allocate port service
[    1.413187] pcieport-driver 0000:00:17.0: setting latency timer to 64
[    1.413670] pcieport-driver 0000:00:17.0: found MSI capability
[    1.414031] pcieport-driver 0000:00:17.0: irq 2287 for MSI/MSI-X
[    1.414167] pci_express 0000:00:17.0:pcie00: allocate port service
[    1.414179] pci_express 0000:00:17.0:pcie02: allocate port service
[    1.414679] pcieport-driver 0000:00:17.1: setting latency timer to 64
[    1.415163] pcieport-driver 0000:00:17.1: found MSI capability
[    1.415521] pcieport-driver 0000:00:17.1: irq 2286 for MSI/MSI-X
[    1.415657] pci_express 0000:00:17.1:pcie00: allocate port service
[    1.415668] pci_express 0000:00:17.1:pcie02: allocate port service
[    1.415992] pcieport-driver 0000:00:17.2: setting latency timer to 64
[    1.415992] pcieport-driver 0000:00:17.2: found MSI capability
[    1.416083] pcieport-driver 0000:00:17.2: irq 2285 for MSI/MSI-X
[    1.416219] pci_express 0000:00:17.2:pcie00: allocate port service
[    1.416233] pci_express 0000:00:17.2:pcie02: allocate port service
[    1.416733] pcieport-driver 0000:00:17.3: setting latency timer to 64
[    1.417257] pcieport-driver 0000:00:17.3: found MSI capability
[    1.417613] pcieport-driver 0000:00:17.3: irq 2284 for MSI/MSI-X
[    1.417749] pci_express 0000:00:17.3:pcie00: allocate port service
[    1.417761] pci_express 0000:00:17.3:pcie02: allocate port service
[    1.418262] pcieport-driver 0000:00:17.4: setting latency timer to 64
[    1.418743] pcieport-driver 0000:00:17.4: found MSI capability
[    1.419104] pcieport-driver 0000:00:17.4: irq 2283 for MSI/MSI-X
[    1.419241] pci_express 0000:00:17.4:pcie00: allocate port service
[    1.419252] pci_express 0000:00:17.4:pcie02: allocate port service
[    1.419755] pcieport-driver 0000:00:17.5: setting latency timer to 64
[    1.419991] pcieport-driver 0000:00:17.5: found MSI capability
[    1.419991] pcieport-driver 0000:00:17.5: irq 2282 for MSI/MSI-X
[    1.419991] pci_express 0000:00:17.5:pcie00: allocate port service
[    1.419991] pci_express 0000:00:17.5:pcie02: allocate port service
[    1.420390] pcieport-driver 0000:00:17.6: setting latency timer to 64
[    1.420870] pcieport-driver 0000:00:17.6: found MSI capability
[    1.421271] pcieport-driver 0000:00:17.6: irq 2281 for MSI/MSI-X
[    1.421407] pci_express 0000:00:17.6:pcie00: allocate port service
[    1.421422] pci_express 0000:00:17.6:pcie02: allocate port service
[    1.421919] pcieport-driver 0000:00:17.7: setting latency timer to 64
[    1.422407] pcieport-driver 0000:00:17.7: found MSI capability
[    1.422764] pcieport-driver 0000:00:17.7: irq 2280 for MSI/MSI-X
[    1.422899] pci_express 0000:00:17.7:pcie00: allocate port service
[    1.422910] pci_express 0000:00:17.7:pcie02: allocate port service
[    1.423424] pcieport-driver 0000:00:18.0: setting latency timer to 64
[    1.423905] pcieport-driver 0000:00:18.0: found MSI capability
[    1.423992] pcieport-driver 0000:00:18.0: irq 2279 for MSI/MSI-X
[    1.423992] pci_express 0000:00:18.0:pcie00: allocate port service
[    1.423992] pci_express 0000:00:18.0:pcie02: allocate port service
[    1.423992] pcieport-driver 0000:00:18.1: setting latency timer to 64
[    1.424643] pcieport-driver 0000:00:18.1: found MSI capability
[    1.425040] pcieport-driver 0000:00:18.1: irq 2278 for MSI/MSI-X
[    1.425176] pci_express 0000:00:18.1:pcie00: allocate port service
[    1.425195] pci_express 0000:00:18.1:pcie02: allocate port service
[    1.425703] pcieport-driver 0000:00:18.2: setting latency timer to 64
[    1.426212] pcieport-driver 0000:00:18.2: found MSI capability
[    1.426572] pcieport-driver 0000:00:18.2: irq 2277 for MSI/MSI-X
[    1.426707] pci_express 0000:00:18.2:pcie00: allocate port service
[    1.426723] pci_express 0000:00:18.2:pcie02: allocate port service
[    1.427230] pcieport-driver 0000:00:18.3: setting latency timer to 64
[    1.427708] pcieport-driver 0000:00:18.3: found MSI capability
[    1.427992] pcieport-driver 0000:00:18.3: irq 2276 for MSI/MSI-X
[    1.427992] pci_express 0000:00:18.3:pcie00: allocate port service
[    1.427992] pci_express 0000:00:18.3:pcie02: allocate port service
[    1.427992] pcieport-driver 0000:00:18.4: setting latency timer to 64
[    1.428452] pcieport-driver 0000:00:18.4: found MSI capability
[    1.428808] pcieport-driver 0000:00:18.4: irq 2275 for MSI/MSI-X
[    1.428943] pci_express 0000:00:18.4:pcie00: allocate port service
[    1.428987] pci_express 0000:00:18.4:pcie02: allocate port service
[    1.429499] pcieport-driver 0000:00:18.5: setting latency timer to 64
[    1.429985] pcieport-driver 0000:00:18.5: found MSI capability
[    1.430342] pcieport-driver 0000:00:18.5: irq 2274 for MSI/MSI-X
[    1.430506] pci_express 0000:00:18.5:pcie00: allocate port service
[    1.430552] pci_express 0000:00:18.5:pcie02: allocate port service
[    1.431075] pcieport-driver 0000:00:18.6: setting latency timer to 64
[    1.431552] pcieport-driver 0000:00:18.6: found MSI capability
[    1.431909] pcieport-driver 0000:00:18.6: irq 2273 for MSI/MSI-X
[    1.431991] pci_express 0000:00:18.6:pcie00: allocate port service
[    1.431991] pci_express 0000:00:18.6:pcie02: allocate port service
[    1.431991] pcieport-driver 0000:00:18.7: setting latency timer to 64
[    1.432097] pcieport-driver 0000:00:18.7: found MSI capability
[    1.432455] pcieport-driver 0000:00:18.7: irq 2272 for MSI/MSI-X
[    1.432590] pci_express 0000:00:18.7:pcie00: allocate port service
[    1.432602] pci_express 0000:00:18.7:pcie02: allocate port service
[    1.433075] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.433875] pciehp 0000:00:15.0:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.434135] pciehp 0000:00:15.0:pcie02: service driver pciehp loaded
[    1.434537] pciehp 0000:00:15.1:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.434769] pciehp 0000:00:15.1:pcie02: service driver pciehp loaded
[    1.435169] pciehp 0000:00:15.2:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.435401] pciehp 0000:00:15.2:pcie02: service driver pciehp loaded
[    1.435798] pciehp 0000:00:15.3:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.435994] pciehp 0000:00:15.3:pcie02: service driver pciehp loaded
[    1.435994] pciehp 0000:00:15.4:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.435994] pciehp 0000:00:15.4:pcie02: service driver pciehp loaded
[    1.436122] pciehp 0000:00:15.5:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.436374] pciehp 0000:00:15.5:pcie02: service driver pciehp loaded
[    1.436772] pciehp 0000:00:15.6:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.437050] pciehp 0000:00:15.6:pcie02: service driver pciehp loaded
[    1.437639] pciehp 0000:00:15.7:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.437892] pciehp 0000:00:15.7:pcie02: service driver pciehp loaded
[    1.438296] pciehp 0000:00:16.0:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.438528] pciehp 0000:00:16.0:pcie02: service driver pciehp loaded
[    1.439012] pciehp 0000:00:16.1:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.439244] pciehp 0000:00:16.1:pcie02: service driver pciehp loaded
[    1.439643] pciehp 0000:00:16.2:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.439902] pciehp 0000:00:16.2:pcie02: service driver pciehp loaded
[    1.439992] pciehp 0000:00:16.3:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.439992] pciehp 0000:00:16.3:pcie02: service driver pciehp loaded
[    1.440235] pciehp 0000:00:16.4:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.440493] pciehp 0000:00:16.4:pcie02: service driver pciehp loaded
[    1.440899] pciehp 0000:00:16.5:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.441174] pciehp 0000:00:16.5:pcie02: service driver pciehp loaded
[    1.441574] pciehp 0000:00:16.6:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.441806] pciehp 0000:00:16.6:pcie02: service driver pciehp loaded
[    1.442215] pciehp 0000:00:16.7:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.442446] pciehp 0000:00:16.7:pcie02: service driver pciehp loaded
[    1.442844] pciehp 0000:00:17.0:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.443077] pciehp 0000:00:17.0:pcie02: service driver pciehp loaded
[    1.443499] pciehp 0000:00:17.1:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.443730] pciehp 0000:00:17.1:pcie02: service driver pciehp loaded
[    1.443992] pciehp 0000:00:17.2:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.443992] pciehp 0000:00:17.2:pcie02: service driver pciehp loaded
[    1.443992] pciehp 0000:00:17.3:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.444052] pciehp 0000:00:17.3:pcie02: service driver pciehp loaded
[    1.444451] pciehp 0000:00:17.4:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.444682] pciehp 0000:00:17.4:pcie02: service driver pciehp loaded
[    1.445120] pciehp 0000:00:17.5:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.445353] pciehp 0000:00:17.5:pcie02: service driver pciehp loaded
[    1.445752] pciehp 0000:00:17.6:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.445986] pciehp 0000:00:17.6:pcie02: service driver pciehp loaded
[    1.446384] pciehp 0000:00:17.7:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.446616] pciehp 0000:00:17.7:pcie02: service driver pciehp loaded
[    1.447021] pciehp 0000:00:18.0:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.447254] pciehp 0000:00:18.0:pcie02: service driver pciehp loaded
[    1.447654] pciehp 0000:00:18.1:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.447907] pciehp 0000:00:18.1:pcie02: service driver pciehp loaded
[    1.447991] pciehp 0000:00:18.2:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.447991] pciehp 0000:00:18.2:pcie02: service driver pciehp loaded
[    1.447991] pciehp 0000:00:18.3:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.448233] pciehp 0000:00:18.3:pcie02: service driver pciehp loaded
[    1.448633] pciehp 0000:00:18.4:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.448865] pciehp 0000:00:18.4:pcie02: service driver pciehp loaded
[    1.449242] pciehp 0000:00:18.5:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.449478] pciehp 0000:00:18.5:pcie02: service driver pciehp loaded
[    1.449877] pciehp 0000:00:18.6:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.450135] pciehp 0000:00:18.6:pcie02: service driver pciehp loaded
[    1.450534] pciehp 0000:00:18.7:pcie02: HPC vendor_id 15ad device_id 7a0 ss_vid 0 ss_did 0
[    1.450768] pciehp 0000:00:18.7:pcie02: service driver pciehp loaded
[    1.450780] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.451168] ACPI: AC Adapter [ACAD] (on-line)
[    1.451375] input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[    1.451378] ACPI: Power Button (FF) [PWRF]
[    1.451987] processor ACPI_CPU:00: registered as cooling_device0
[    1.451998] ACPI: Processor [CP00] (supports 8 throttling states)
[    1.452522] processor ACPI_CPU:01: registered as cooling_device1
[    1.452526] ACPI: Processor [CP01] (supports 8 throttling states)
[    1.499911] isapnp: Scanning for PnP cards...
[    1.855556] isapnp: No Plug & Play device found
[    1.857398] Serial: 8250/16550 driver4 ports, IRQ sharing enabled
[    1.857973] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.858449] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    1.859102] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.859603] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    1.860091] brd: module loaded
[    1.860481] loop: module loaded
[    1.860596] Fixed MDIO Bus: probed
[    1.860607] PPP generic driver version 2.4.2
[    1.860713] input: Macintosh mouse button emulation as /devices/virtual/input/input1
[    1.860745] Driver 'sd' needs updating - please use bus_type methods
[    1.860753] Driver 'sr' needs updating - please use bus_type methods
[    1.860844] ata_piix 0000:00:07.1: version 2.12
[    1.861688] scsi0 : ata_piix
[    1.861885] scsi1 : ata_piix
[    1.861974] ata1: PATA max UDMA/33 cmd 0x1f0 ctl 0x3f6 bmdma 0x10c0 irq 14
[    1.861976] ata2: PATA max UDMA/33 cmd 0x170 ctl 0x376 bmdma 0x10c8 irq 15
[    2.236976] ata2.00: ATAPI: VMware Virtual IDE CDROM Drive, 00000001, max UDMA/33
[    2.237724] ata2.00: configured for UDMA/33
[    2.238899] scsi 1:0:0:0: CD-ROM            NECVMWar VMware IDE CDR10 1.00 PQ: 0 ANSI: 5
[    2.241463] sr0: scsi3-mmc drive: 1x/1x xa/form2 cdda tray
[    2.241473] Uniform CD-ROM driver Revision: 3.20
[    2.241591] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.241633] sr 1:0:0:0: Attached scsi generic sg0 type 5
[    2.241928] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.242026] ehci_hcd 0000:02:03.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    2.242216] ehci_hcd 0000:02:03.0: EHCI Host Controller
[    2.242275] ehci_hcd 0000:02:03.0: new USB bus registered, assigned bus number 1
[    2.242626] ehci_hcd 0000:02:03.0: cache line size of 32 is not supported
[    2.242685] ehci_hcd 0000:02:03.0: irq 17, io mem 0xd8900000
[    2.252089] ehci_hcd 0000:02:03.0: USB 2.0 started, EHCI 1.00
[    2.252215] usb usb1: configuration #1 chosen from 1 choice
[    2.252236] hub 1-0:1.0: USB hub found
[    2.252263] hub 1-0:1.0: 6 ports detected
[    2.252452] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.252480] uhci_hcd: USB Universal Host Controller Interface driver
[    2.252576] uhci_hcd 0000:02:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    2.252615] uhci_hcd 0000:02:00.0: UHCI Host Controller
[    2.252647] uhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 2
[    2.252921] uhci_hcd 0000:02:00.0: irq 18, io base 0x000020c0
[    2.253202] usb usb2: configuration #1 chosen from 1 choice
[    2.253220] hub 2-0:1.0: USB hub found
[    2.253243] hub 2-0:1.0: 2 ports detected
[    2.253494] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOUS] at 0x60,0x64 irq 1,12
[    2.783155] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.783188] serio: i8042 AUX port at 0x60,0x64 irq 12
[    2.785150] mice: PS/2 mouse device common for all mice
[    2.793472] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[    2.793579] rtc0: alarms up to one month, y3k, 114 bytes nvram
[    2.793667] device-mapper: uevent: version 1.0.3
[    2.793911] device-mapper: ioctl: 4.14.0-ioctl (2008-04-23) initialised: dm-devel@redhat.com
[    2.794589] device-mapper: multipath: version 1.0.5 loaded
[    2.794593] device-mapper: multipath round-robin: version 1.0.0 loaded
[    2.794898] EISA: Probing bus 0 at eisa.0
[    2.794923] Cannot allocate resource for EISA slot 1
[    2.794926] Cannot allocate resource for EISA slot 2
[    2.794929] Cannot allocate resource for EISA slot 3
[    2.794931] Cannot allocate resource for EISA slot 4
[    2.794934] Cannot allocate resource for EISA slot 5
[    2.794936] Cannot allocate resource for EISA slot 6
[    2.794938] Cannot allocate resource for EISA slot 7
[    2.794943] Cannot allocate resource for EISA slot 8
[    2.794945] EISA: Detected 0 cards.
[    2.795456] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[    2.795544] cpuidle: using governor ladder
[    2.795548] cpuidle: using governor menu
[    2.795789] TCP cubic registered
[    2.795903] NET: Registered protocol family 10
[    2.795999] lo: Disabled Privacy Extensions
[    2.796183] NET: Registered protocol family 17
[    2.796210] Bluetooth: L2CAP ver 2.11
[    2.796214] Bluetooth: L2CAP socket layer initialized
[    2.796217] Bluetooth: SCO (Voice Link) ver 0.6
[    2.796219] Bluetooth: SCO socket layer initialized
[    2.796420] Bluetooth: RFCOMM socket layer initialized
[    2.796432] Bluetooth: RFCOMM TTY layer initialized
[    2.796434] Bluetooth: RFCOMM ver 1.10
[    2.796586] Using IPI No-Shortcut mode
[    2.796739] registered taskstats version 1
[    2.796864]   Magic number: 6:621:811
[    2.816906] rtc_cmos 00:04: setting system clock to 2014-03-10 01:50:00 UTC (1394416200)
[    2.816911] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    2.816913] EDD information not available.
[    2.817102] Freeing unused kernel memory: 532k freed
[    2.817527] Write protecting the kernel text: 4120k
[    2.817650] Write protecting the kernel read-only data: 1524k
[    3.004178] usb 1-1: new high speed USB device using ehci_hcd and address 2
[    3.153090] Fusion MPT base driver 3.04.07
[    3.153094] Copyright (c) 1999-2008 LSI Corporation
[    3.156235] Fusion MPT SPI Host driver 3.04.07
[    3.156331] mptspi 0000:00:10.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    3.166089] mptbase: ioc0: Initiating bringup
[    3.169093] pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de
[    3.169178] pcnet32 0000:02:01.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[    3.169354] pcnet32: PCnet/PCI II 79C970A at 0x2000, 00:0c:29:33:6b:64 assigned IRQ 19.
[    3.169769] eth0: registered as PCnet/PCI II 79C970A
[    3.169840] pcnet32: 1 cards_found.
[    3.214648] Floppy drive(s): fd0 is 1.44M
[    3.228997] FDC 0 is a post-1991 82077
[    3.236342] ioc0: LSI53C1030 B0: Capabilities={Initiator}
[    3.377552] scsi2 : ioc0: LSI53C1030 B0, FwRev=01032920h, Ports=1, MaxQ=128, IRQ=17
[    3.489698] scsi 2:0:0:0: Direct-Access     VMware,  VMware Virtual S 1.0  PQ: 0 ANSI: 2
[    3.489734] scsi target2:0:0: Beginning Domain Validation
[    3.490392] scsi target2:0:0: Domain Validation skipping write tests
[    3.490395] scsi target2:0:0: Ending Domain Validation
[    3.490426] scsi target2:0:0: FAST-40 WIDE SCSI 80.0 MB/s ST (25 ns, offset 127)
[    3.491448] sd 2:0:0:0: [sda] 41943040 512-byte hardware sectors: (21.4 GB/20.0 GiB)
[    3.491488] sd 2:0:0:0: [sda] Write Protect is off
[    3.491491] sd 2:0:0:0: [sda] Mode Sense: 5d 00 00 00
[    3.491585] sd 2:0:0:0: [sda] Cache data unavailable
[    3.491587] sd 2:0:0:0: [sda] Assuming drive cache: write through
[    3.491710] sd 2:0:0:0: [sda] 41943040 512-byte hardware sectors: (21.4 GB/20.0 GiB)
[    3.491745] sd 2:0:0:0: [sda] Write Protect is off
[    3.491748] sd 2:0:0:0: [sda] Mode Sense: 5d 00 00 00
[    3.491805] sd 2:0:0:0: [sda] Cache data unavailable
[    3.491807] sd 2:0:0:0: [sda] Assuming drive cache: write through
[    3.491810]  sda: sda1 sda2 < sda5 >
[    3.501600] sd 2:0:0:0: [sda] Attached SCSI disk
[    3.501666] sd 2:0:0:0: Attached scsi generic sg1 type 0
[    3.614338] PM: Starting manual resume from disk
[    3.614342] PM: Resume from partition 8:5
[    3.614344] PM: Checking hibernation image.
[    3.614442] PM: Resume from disk failed.
[    3.624791] kjournald starting.  Commit interval 5 seconds
[    3.624859] EXT3-fs: mounted filesystem with ordered data mode.
[    5.478831] udev: starting version 141
[    5.722427] udev: renamed network interface eth0 to eth1
[    5.863565] Linux agpgart interface v0.103
[    5.883438] parport_pc 00:08: reported by Plug and Play ACPI
[    5.883672] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[    5.889403] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    5.891992] ACPI: I/O resource piix4_smbus [0x1040-0x1047] conflicts with ACPI region SMB_ [0x1040-0x104b]
[    5.891992] ACPI: Device needs an ACPI driver
[    5.891992] piix4_smbus 0000:00:07.3: Host SMBus controller not enabled!
[    5.900295] input: PC Speaker as /devices/platform/pcspkr/input/input3
[    5.909236] agpgart-intel 0000:00:00.0: Intel 440BX Chipset
[    5.910266] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0x0
[    5.924499] synaptics was reset on resume, see synaptics_resume_reset if you have trouble on resume
[    5.925778] psmouse serio1: ID: 10 00 64<6>input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input4
[    6.060412] ENS1371 0000:02:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    6.090652] ppdev: user-space parallel port driver
[    7.024263] lp0: using parport0 (interrupt-driven).
[    7.120410] Adding 915664k swap on /dev/sda5.  Priority:-1 extents:1 across:915664k
[    7.693523] EXT3 FS on sda1, internal journal
[    8.004129] ehci_hcd 0000:02:03.0: Unlink after no-IRQ?  Controller is probably using the wrong IRQ.
[    8.412186] usb 1-1: device descriptor read/64, error -32
[    8.661768] type=1505 audit(1394416206.344:2): operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" name2="default" pid=2110
[    8.689149] type=1505 audit(1394416206.372:3): operation="profile_load" name="/sbin/dhclient-script" name2="default" pid=2114
[    8.689358] type=1505 audit(1394416206.372:4): operation="profile_load" name="/sbin/dhclient3" name2="default" pid=2114
[    8.689467] type=1505 audit(1394416206.372:5): operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" name2="default" pid=2114
[    8.689507] type=1505 audit(1394416206.372:6): operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" name2="default" pid=2114
[    8.772228] type=1505 audit(1394416206.455:7): operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" name2="default" pid=2119
[    8.772652] type=1505 audit(1394416206.455:8): operation="profile_load" name="/usr/sbin/cupsd" name2="default" pid=2119
[    8.792151] type=1505 audit(1394416206.475:9): operation="profile_load" name="/usr/sbin/tcpdump" name2="default" pid=2123
[   10.135017] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[   10.203482] acpiphp: Slot [32] registered
[   10.204475] acpiphp: Slot [33] registered
[   10.205383] acpiphp: Slot [34] registered
[   10.208071] acpiphp: Slot [35] registered
[   10.208082] acpiphp: Slot [36] registered
[   10.208094] acpiphp: Slot [37] registered
[   10.208106] acpiphp: Slot [38] registered
[   10.208119] acpiphp: Slot [39] registered
[   10.208132] acpiphp: Slot [40] registered
[   10.208141] acpiphp: Slot [41] registered
[   10.208150] acpiphp: Slot [42] registered
[   10.208159] acpiphp: Slot [43] registered
[   10.208168] acpiphp: Slot [44] registered
[   10.208177] acpiphp: Slot [45] registered
[   10.208186] acpiphp: Slot [46] registered
[   10.208199] acpiphp: Slot [47] registered
[   10.208217] acpiphp: Slot [48] registered
[   10.208236] acpiphp: Slot [49] registered
[   10.208251] acpiphp: Slot [50] registered
[   10.208266] acpiphp: Slot [51] registered
[   10.208278] acpiphp: Slot [52] registered
[   10.208287] acpiphp: Slot [53] registered
[   10.208296] acpiphp: Slot [54] registered
[   10.208305] acpiphp: Slot [55] registered
[   10.208321] acpiphp: Slot [56] registered
[   10.208333] acpiphp: Slot [57] registered
[   10.208342] acpiphp: Slot [58] registered
[   10.208350] acpiphp: Slot [59] registered
[   10.208359] acpiphp: Slot [60] registered
[   10.208373] acpiphp: Slot [61] registered
[   10.208383] acpiphp: Slot [62] registered
[   10.208395] acpiphp: Slot [63] registered
[   10.208468] acpiphp_glue: Slot 160 already registered by another hotplug driver
[   10.208489] acpiphp_glue: Slot 192 already registered by another hotplug driver
[   10.208508] acpiphp_glue: Slot 224 already registered by another hotplug driver
[   10.208528] acpiphp_glue: Slot 256 already registered by another hotplug driver
[   10.208566] acpiphp_glue: Slot 161 already registered by another hotplug driver
[   10.208585] acpiphp_glue: Slot 162 already registered by another hotplug driver
[   10.208608] acpiphp_glue: Slot 163 already registered by another hotplug driver
[   10.208624] acpiphp_glue: Slot 164 already registered by another hotplug driver
[   10.208640] acpiphp_glue: Slot 165 already registered by another hotplug driver
[   10.208734] acpiphp_glue: Slot 166 already registered by another hotplug driver
[   10.208755] acpiphp_glue: Slot 167 already registered by another hotplug driver
[   10.208772] acpiphp_glue: Slot 193 already registered by another hotplug driver
[   10.208793] acpiphp_glue: Slot 194 already registered by another hotplug driver
[   10.208809] acpiphp_glue: Slot 195 already registered by another hotplug driver
[   10.208826] acpiphp_glue: Slot 196 already registered by another hotplug driver
[   10.208842] acpiphp_glue: Slot 197 already registered by another hotplug driver
[   10.208858] acpiphp_glue: Slot 198 already registered by another hotplug driver
[   10.208873] acpiphp_glue: Slot 199 already registered by another hotplug driver
[   10.208890] acpiphp_glue: Slot 225 already registered by another hotplug driver
[   10.208908] acpiphp_glue: Slot 226 already registered by another hotplug driver
[   10.208925] acpiphp_glue: Slot 227 already registered by another hotplug driver
[   10.208941] acpiphp_glue: Slot 228 already registered by another hotplug driver
[   10.208959] acpiphp_glue: Slot 229 already registered by another hotplug driver
[   10.208976] acpiphp_glue: Slot 230 already registered by another hotplug driver
[   10.208992] acpiphp_glue: Slot 231 already registered by another hotplug driver
[   10.209008] acpiphp_glue: Slot 257 already registered by another hotplug driver
[   10.209026] acpiphp_glue: Slot 258 already registered by another hotplug driver
[   10.209043] acpiphp_glue: Slot 259 already registered by another hotplug driver
[   10.209059] acpiphp_glue: Slot 260 already registered by another hotplug driver
[   10.209076] acpiphp_glue: Slot 261 already registered by another hotplug driver
[   10.209095] acpiphp_glue: Slot 262 already registered by another hotplug driver
[   10.209112] acpiphp_glue: Slot 263 already registered by another hotplug driver
[   10.859783] vmhgfs: disagrees about version of symbol struct_module
[   11.003489] vmmemctl: disagrees about version of symbol struct_module
[   11.081439] vmxnet: disagrees about version of symbol struct_module
[   11.155722] vmci: disagrees about version of symbol struct_module
[   11.222530] vmblock: disagrees about version of symbol struct_module
[   14.424968] usb 1-1: device descriptor read/64, error -32
[   14.640907] usb 1-1: new high speed USB device using ehci_hcd and address 3
[   16.397755] RPC: Registered udp transport module.
[   16.397759] RPC: Registered tcp transport module.
[   16.445095] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   16.655375] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[   16.661583] NFSD: starting 90-second grace period
[   19.848220] usb 1-1: device descriptor read/64, error -32
[   25.160453] usb 1-1: device descriptor read/64, error -32
[   25.376406] usb 1-1: new high speed USB device using ehci_hcd and address 4
[   30.396701] usb 1-1: device descriptor read/8, error -110
[   35.516942] usb 1-1: device descriptor read/8, error -110
[   35.776883] usb 1-1: new high speed USB device using ehci_hcd and address 5
[   41.472197] usb 1-1: device descriptor read/8, error -110
[   46.592413] usb 1-1: device descriptor read/8, error -110
[   46.696417] hub 1-0:1.0: unable to enumerate USB device on port 1
[   46.812742] ppdev0: registered pardevice
[   46.860954] ppdev0: unregistered pardevice
[   47.799460] ppdev0: registered pardevice
[   47.849273] ppdev0: unregistered pardevice
[   49.154466] type=1503 audit(1394416246.836:10): operation="capable" name="sys_admin" pid=3129 profile="/usr/sbin/cupsd"
[   49.223118] ppdev0: registered pardevice
[   49.268490] ppdev0: unregistered pardevice
[   81.224953] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   81.224955] Bluetooth: BNEP filters: protocol multicast
[   81.241317] Bridge firewalling registered
[   81.336865] usb 1-1: new high speed USB device using ehci_hcd and address 6
[   87.444137] usb 1-1: device descriptor read/64, error -32
[   92.756390] usb 1-1: device descriptor read/64, error -32
[   92.972405] usb 1-1: new high speed USB device using ehci_hcd and address 7
[   98.180658] usb 1-1: device descriptor read/64, error -32
[  103.492861] usb 1-1: device descriptor read/64, error -32
[  103.708851] usb 1-1: new high speed USB device using ehci_hcd and address 8
[  108.728230] usb 1-1: device descriptor read/8, error -110
[  113.848368] usb 1-1: device descriptor read/8, error -110
[  114.064337] usb 1-1: new high speed USB device using ehci_hcd and address 9
[  119.876746] usb 1-1: device descriptor read/8, error -110
[  124.996883] usb 1-1: device descriptor read/8, error -110
[  125.100877] hub 1-0:1.0: unable to enumerate USB device on port 1
[  130.320977] eth1: link up
[  141.784566] eth1: no IPv6 routers present
[  206.936411] usb 1-1: new high speed USB device using ehci_hcd and address 10
[  213.044677] usb 1-1: device descriptor read/64, error -32
[  218.356885] usb 1-1: device descriptor read/64, error -32
[  218.573022] usb 1-1: new high speed USB device using ehci_hcd and address 11
[  223.780208] usb 1-1: device descriptor read/64, error -32
[  229.092361] usb 1-1: device descriptor read/64, error -32
[  229.308422] usb 1-1: new high speed USB device using ehci_hcd and address 12
[  234.328693] usb 1-1: device descriptor read/8, error -110
[  239.448893] usb 1-1: device descriptor read/8, error -110
[  239.664189] usb 1-1: new high speed USB device using ehci_hcd and address 13
[  245.404185] usb 1-1: device descriptor read/8, error -110
[  250.524396] usb 1-1: device descriptor read/8, error -110
[  250.628447] hub 1-0:1.0: unable to enumerate USB device on port 1
aaron@aaron:~$ sudo lsusb -v
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            2.06
  iManufacturer           3 Linux 2.6.28-19-generic ehci_hcd
  iProduct                2 EHCI Host Controller
  iSerial                 1 0000:02:03.0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             6
  wHubCharacteristic 0x000a
    No power switching (usb 1.0)
    Per-port overcurrent protection
  bPwrOn2PwrGood       10 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 2: 0000.0100 power
   Port 3: 0000.0100 power
   Port 4: 0000.0100 power
   Port 5: 0000.0100 power
   Port 6: 0000.0100 power
Device Status:     0x0003
  Self Powered
  Remote Wakeup Enabled
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idProduct          0x0001 1.1 root hub
  bcdDevice            2.06
  iManufacturer           3 Linux 2.6.28-19-generic uhci_hcd
  iProduct                2 UHCI Host Controller
  iSerial                 1 0000:02:00.0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
  bPwrOn2PwrGood        1 * 2 milli seconds
Hub Port Status:
   Port 1: 0000.0100 power
  Self Powered
标签 (6)
0 回复数
