systemd with ttymxc0
kunyichen
hi,
    I try the below on v3.14.52_v1.1.0qa bsp,
because I need to use connman with WIFI
so add 'systemd' into DISTRO_FEATURES
currently connman work well with WIFI
but I can't use serial console (ttymxc0) to login my system now after add systemd
I have try this systemd for Administrators, Part XVI , but still failed
have anyone can tell me, how to login by ttymxc0?
kunyichen
okay, currently workable when to enable CONFIG_FHANDLE of kernel
kunyichen
when I booting into system then open a terminal to run below command will work,
systemctl enable [email protected]
but system booting still failed, check boot status
systemctl status [email protected]
will show Active: inactive(dead)
Dependency failed for Serial Getty on ttymxc0
Job [email protected] start failed with result 'dependency'
kunyichen
