support -lglfw -lGLEW -lGL
1,433 次查看
mjaafar
Hi all,
 I wonder if there is a support for
libglfw3 libglfw3-dev libglew-dev
in yocto
Thank you
标记 (1)
1,396 次查看
Dhruvit
Hi @mjaafar,
I hope you are doing well.
Yes, The mentioned library is supported by the yocto. One can refer to the below files for the recipes of the same.
Thanks & Regards,
Dhruvit Vasavada
