ssp slave
ssp slave
3,372 次查看
tomi
hey
is there a more detailed hardware description for ssp ports in slave mode
for example wich chip select is needed ..
tom
5 回复数
3,108 次查看
YixingKong
Senior Contributor IV
Thomas, has Arthur's reply answered your question? If yes, please click Correct Answer, otherwise please keep working with Arthur. Please do not leave the DI there un-attended, as we will close Di in 3 days, if nothing happens.
Yixing
3,108 次查看
arthur_lai
Senior Contributor II
Hi Tom,
The SSP can work in a number of modes. How would you like to use the SSP?
Please check Table 17-1 on the reference manual and you should be able to find the info needed.
Arthur
3,108 次查看
tomi
sorry,
i want to use the ssp Port as spi slave and i can not find some detailed descriptions about it in the Userers manual.
3,108 次查看
YixingKong
Thomas,do you still have unresolved issues? If not, we will close the DI in 3 days.
Yixing
3,108 次查看
arthur_lai
Hi Thomas,
For SPI signals assignment, you can refer to Table 17-1 on the Reference Manual.
The hardware connections are basically the same for either master or slave mode. The difference is that i.MX28 SCK, MOSI and SSn0 are input pins in slave mode.
Arthur
