shared library issue
nalli
I'm using imx8m mini hardaware,if i want to run cross compiled opencv program in imx8m mini, i got error like libopencv_ts.so shared library can't open.could you please help me to solve this error.can you exaplain how exactly cross compile opencv program to imx 8m mini.
Harvey021
Hi @nalli
You need to check if there is libopencv_ts.so in your toolchain.
If there is no such lib. you can add the line (IMAGE_INSTALL:append = " opencv-apps opencv-samples python3-opencv ") to conf/local.conf and follow up the 4.5.12 How to build U-Boot and Kernel in standalone environment in i.MX Linux User's Guide to setup and install SDK.
Harvey
