setting repo
setting repo
19,185 次查看
zhangbaobing
I do it as up following,but always fault,
i wander why.
标记 (1)
32 回复数
12,984 次查看
iris_wen
Please try the following steps:
1. Save the attachment in ~/bin
2. $ chmod a+x ~/bin/repo
3. Add the following line to the ~/.bashrc file
   export PATH=~/bin:$PATH
4.$ source ~/.bashrc
12,984 次查看
zhangbaobing
Executeing this instruction which is fault
so the back instructon still fault.
12,984 次查看
iris_wen
Do you really follow the steps I provided?
The first step is to save the attachment in ~/bin. Then the repo is already in your computer. You don't need to download again.
Remember to unzip the attachment...ONLY copy the file repo in ~/bin...
12,979 次查看
zhangbaobing
first ,what is attachment?
12,979 次查看
zhangbaobing
where is the attachment?
and can you give me specfications ?
12,979 次查看
zhangbaobing
12,979 次查看
joanxie
maybe you can refer to the link as below, get the repo from tsinghua
"https://mirrors.tuna.tsinghua.edu.cn/help/git-rep"
I suggest that you can update to the latest version, some packages in the git.freescale.com are removed, if you build the 3.14.28, maybe you will get the connection error even if you can repo sync successfully, I have built 4.14.52 successfully before, but I don't know if you can get 3.14.28 source package or not
12,979 次查看
zhangbaobing
12,979 次查看
joanxie
12,979 次查看
zhangbaobing
i download L4.1.15 still fault
12,979 次查看
zhangbaobing
12,979 次查看
joanxie
as I mentioned before, the source code was removed from git.freescale.com, maybe you can refer to my another document
https://community.nxp.com/docs/DOC-346089
12,979 次查看
zhangbaobing
still fault
12,979 次查看
joanxie
do you mind reading my document again? as I mentioned,  you couldn't use git.freescale.com, try to use the new command as my document mentions
12,979 次查看
zhangbaobing
pastedImage_1.pngstill fault
12,979 次查看
joanxie
I don't find any error according to the pic you attached
12,984 次查看
iris_wen
Hi Baobing,
Did you reboot or source the .bashrc file by the following command?
$ source ~/.bashrc
12,984 次查看
iris_wen
If the instruction in user guide is not detailed enough, please follow this link.
https://blog.csdn.net/xuanwolanxue/article/details/104678027?ops_request_misc=%257B%2522request%255F...
12,984 次查看
zhangbaobing
hi ,that is still false
12,984 次查看
iris_wen
Could you please share the log?
