server certificate verification failed
embedded_Dev
Hello @all,
I am trying to download android 11 source. When I run the script imx_android_setup.sh, I am facing the following issues
Error:
fatal: unable to access 'https://source.codeaurora.org/external/imx/aosp/platform/development/': server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
When I am trying to compile the imx6ul yocto source, I am facing the same issue as shown above. Previousely the yocto source use to compile but from yesterday it is showing the certificates error.
Please let me know if any
embedded_Dev
Thanks for the response
i used the below commands
$ sudo apt update
$ sudo apt upgrade
The issue got resolved
jimmychan
I tried to build it and do not see the error you mentioned. Could you try to make a clean build again?
Jimmy
embedded_Dev
$ sudo apt update
$ sudo apt upgrade
