running viv_samples tutorials
prathameshghane
Fresh Out Contributor
I am getting my hands on imx6 SABRE-AUTO board.
I tried running some tutorials in /opt/viv_samples directory.
I want to know what output should the tutorials give on the console/screen??
e.g tutorial1 when executed from command line, comes out to the prompt without reporting any failure/printing anything on the console etc.
Another tutorial "tiger" reports the following error.
-sh-4.1# ./tiger
vdkIntialize() failed.
CreateWindow() failed.
Can you please guide me as to how should I go about using the tutorials and how do I interpret the messages.
Thanks and regards,
Prathamesh
Labels (3)
jimmychan
which BSP are you using?
Have you enable the GPU driver in kernel configuration? and gpu-viv-bin-mx6q installed?
For more information, please check the BSP Reference Manual (e.g. i.MX_6Dual6Quad_Linux_Reference_Manual.pdf).
fulinux
have you solved this issue?
