repo sync no response
3,547 次查看
wushengyong
Update the yocto,but no respose:
keyto@ubuntu:~$ cd fsl-release-bsp
keyto@ubuntu:~/fsl-release-bsp$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga
keyto@ubuntu:~/fsl-release-bsp$ repo sync
after repo sync command, directly back to command line, no response, how to do with this issue?
标记 (1)
3,313 次查看
gusarambula
Hello Wu Shengyong,
Have you installed the repo tool? Does the repo initialization show ant output?
I would start checking that you have the required installed packages and the repo tool in place, as well as Internet access. Have you followed section 3.1 and 3.2 of the Yocto User’s Guide prior to initializing the BSP repo?
3,314 次查看
gusarambula
Hello Wu Shengyong,
3,313 次查看
wushengyong
Re-setup the repo tool, it's OK now.
