repo sync failure while running script for i.MX8M Mini android 10
shamiullah
Start fetching the source for android build
Setting REL_PACKAGE_DIR to /mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0
Setting WORKSPACE to /mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0
Setting android_builddir to /mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build
repo: warning: your Python 3 version is no longer supported; Please upgrade to Python 3.6+.
Traceback (most recent call last):
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/main.py", line 627, in <module>
_Main(sys.argv[1:])
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/main.py", line 601, in _Main
result = run()
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/main.py", line 594, in <lambda>
run = lambda: repo._Run(name, gopts, argv) or 0
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/main.py", line 260, in _Run
result = cmd.Execute(copts, cargs)
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/subcmds/sync.py", line 856, in Execute
self._UpdateManifestProject(opt, mp, manifest_name)
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/subcmds/sync.py", line 769, in _UpdateManifestProject
clone_filter=self.manifest.CloneFilter)
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/project.py", line 1105, in Sync_NetworkHalf
and self._ApplyCloneBundle(initial=is_new, quiet=quiet, verbose=verbose)):
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/project.py", line 2201, in _ApplyCloneBundle
bundle_url = remote.url + '/clone.bundle'
TypeError: unsupported operand type(s) for +: 'NoneType' and 'str'
Try repo sync 1 time(s)
_Main(sys.argv[1:])
result = run()
Try repo sync 2 time(s)
_Main(sys.argv[1:])
result = run()
Try repo sync 3 time(s)
_Main(sys.argv[1:])
result = run()
_Main(sys.argv[1:])
result = run()
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/subcmds/sync.py", line 774, in _UpdateManifestProject
if mp.HasChanges:
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/project.py", line 3235, in HasChanges
revid = self.GetRevisionId(all_refs)
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/project.py", line 1189, in GetRevisionId
rev = rem.ToLocal(self.revisionExpr)
File "/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/.repo/repo/git_config.py", line 736, in ToLocal
(self.projectname, self.name, rev))
error.GitError: None: remote origin does not have refs/heads/master
------Repo sync failure
./imx_android_setup-ALPHA1.sh: line 88: return: can only `return' from a function or sourced script
fatal: can't open patch '/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/device/fsl/imx8m/phyboard_polis/patch/0001-imx8mm_bl31_setup-allow-uart4-from-A53-processor.patch': No such file or directory
fatal: can't open patch '/mnt/Andriod/shammi_work/android_imx8m_mini_polis/imx-android-10.0.0_2.0.0/android_build/device/fsl/imx8m/phyboard_polis/patch/0001-Parsing-the-devicetree-name.patch': No such file or directory
Android source is ready for the build
python version 2.7.12
Please let me know for any changes
Thanks & Regards,
Shamiullah
shamiullah
sudo apt-get install git-core gnupg flex bison build-essential zip curl zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 lib32ncurses5-dev x11proto-core-dev libx11-dev lib32z1-dev libgl1-mesa-dev libxml2-utils xsltproc unzip fontconfig uuid uuid-dev liblz-dev liblzo2-2 liblzo2-dev u-boot-tools mtd-utils android-tools-fsutils openjdk-8-jdk device-tree-compiler gdisk m4 libz-dev libssl-dev
Zhiming_Liu
Can you provide all your operations(including host package install)?
