rcu_preempt issue
rcu_preempt issue
4,880 次查看
57063778
Hi,all
    I am facing a Linux kernel dump issue after running about 48 hours. The BSP is Yocto with Linux 3.14.28 and the CPU is imx6Q. The dump information is as follow and how to fix the issue? Thanks in advance.
Dec 5 05:36:35 linux user.err kernel: INFO: rcu_preempt detected stalls on CPUs/tasks: { 2} (detected by 1, t=2102 jiffies, g=45107986, c=45107985, q=5227)
Dec 5 05:36:35 linux user.info kernel: Task dump for CPU 2:
Dec 5 05:36:35 linux user.info kernel: grep R running 0 1231 1228 0x00000002
Dec 5 05:36:35 linux user.warn kernel: [<80716800>] (__schedule) from [<a9c94020>] (0xa9c94020)
标记 (1)
6 回复数
4,026 次查看
57063778
Hi igor,
   Thanks for your reply.
   Will the linux "https://source.codeaurora.org/external/imx/linux-imx -b imx_4.14.78_1.0.0_ga" fix the RCU issue? Or which version can fix the issue?
4,026 次查看
please try latest described on nxp official software page
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser...
4,026 次查看
57063778
Hi igorpadykov,
    The URL"https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser..." always redirect to "i.MX Software|NXP ". And I can not get the right information. Would you please send the according material to my email: xuyongxian@kehua.com.  Thank you very much.
4,026 次查看
Hi 57063778@qq.com
actually it is the same link, you can find all relevant documentation on
i.MX Software|NXP
4,026 次查看
4,026 次查看
usually rcu_preempt errors happen due to arm/gpu bugs which were fixed in later nxp
linux releases (they are documented in Release Notes found on below link)
i.MX Software|NXP
