rcu_preempt issue
rcu_preempt issue
6,109 次查看
57063778
Hi,all
    I am facing a Linux kernel dump issue after running about 48 hours. The BSP is Yocto with Linux 3.14.28 and the CPU is imx6Q. The dump information is as follow and how to fix the issue? Thanks in advance.
Dec 5 05:36:35 linux user.err kernel: INFO: rcu_preempt detected stalls on CPUs/tasks: { 2} (detected by 1, t=2102 jiffies, g=45107986, c=45107985, q=5227)
Dec 5 05:36:35 linux user.info kernel: Task dump for CPU 2:
Dec 5 05:36:35 linux user.info kernel: grep R running 0 1231 1228 0x00000002
Dec 5 05:36:35 linux user.warn kernel: [<80716800>] (__schedule) from [<a9c94020>] (0xa9c94020)
标记 (1)
6 回复数
5,255 次查看
57063778
Hi igor,
   Thanks for your reply.
   Will the linux "https://source.codeaurora.org/external/imx/linux-imx -b imx_4.14.78_1.0.0_ga" fix the RCU issue? Or which version can fix the issue?
5,255 次查看
igorpadykov
please try latest described on nxp official software page
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser...
5,255 次查看
57063778
Hi igorpadykov,
    The URL"https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser..." always redirect to "i.MX Software|NXP ". And I can not get the right information. Would you please send the according material to my email: [email protected].  Thank you very much.
5,255 次查看
igorpadykov
Hi [email protected]
actually it is the same link, you can find all relevant documentation on
i.MX Software|NXP
5,255 次查看
igorpadykov
5,255 次查看
igorpadykov
usually rcu_preempt errors happen due to arm/gpu bugs which were fixed in later nxp
linux releases (they are documented in Release Notes found on below link)
i.MX Software|NXP
