i have question about two parallel camera inputs of I.MX6. Can the both parallel cameras' video streams be inputted individually on the same time with no fault causing for each?
Lynn
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
Lynn
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
 SergioSolis
			SergioSolis
		Are you referring to have the 2 video feeds simultaneously stored into the board?, or transmitted to a display?, which i.MX6 are you using?
 SergioSolis
			SergioSolis
		well, yes, you can simultaneously display 2 video feeds.
the difference between the C and the D in the i.mx6 nomenclature is the silicon revision.
Take a look at the errata document for changes:
Thx for quick response!
I’m referring to have the 2 video feeds simultaneously stored into the board. after storing into the board, we’ll process video data, then transmit data to a display or other device. we are using quad core MCIMX6Q6AVT10AC or MCIMX6Q6AVT10AD for our design, what's difference between MCIMX6Q6AVT10AC and MCIMX6Q6AVT10AD?
