question about two parallel camera inputs of I.MX6.
2,970 次查看
lynn1
i have question about two parallel camera inputs of I.MX6. Can the both parallel cameras'  video streams be inputted individually on the same time with no fault causing for each?
6 回复数
2,617 次查看
YixingKong
Senior Contributor IV
Lynn
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
2,617 次查看
YixingKong
Lynn
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
2,617 次查看
SergioSolis
Are you referring to have the 2 video feeds simultaneously stored into the board?, or transmitted to a display?, which i.MX6 are you using?
2,617 次查看
lynn1
any more advice or follow up?
2,617 次查看
SergioSolis
well, yes, you can simultaneously display 2 video feeds.
the difference between the C and the D in the i.mx6 nomenclature is the silicon revision.
Take a look at the errata document for changes:
i.MX6Q: i.MX 6Quad Family of Applications Processors
2,615 次查看
lynn1
Thx for quick response!
I’m referring to have the 2 video feeds simultaneously stored into the board. after storing into the board, we’ll process video data, then transmit data to a display or other device. we are using quad core MCIMX6Q6AVT10AC or  MCIMX6Q6AVT10AD for our design, what's difference between MCIMX6Q6AVT10AC and MCIMX6Q6AVT10AD?
