pwm_backlight_update_status
894 次查看
raysonrayson
Hi everyone:
     On imx6 sdq, I found pwm_backlight_update_status was called and the pwm was disabled ,
In function pwm_backlight_update_status()(drivers/video/backlight/pwm_bl.)
  pwm_config(pb->pwm, 0, pb->period);
  pwm_disable(pb->pwm);
and then , I got the current process, it is kworker/1:2,  but I do not know how can the kworker trigger the pwm_backlight_update_status ???
Can anybody help me, thanks a lot .
743 次查看
jimmychan
sorry, I don't understand your question. So, is the backlight work?
which board are you using?
which bsp are you using?
