pull-up/pull-down resistors's tolerance
3,960 次查看
ko-hey
Senior Contributor II
Hi all
I have a question about resistance tolerance.
I want to know the resistance tolerance of GPIO's pull-up/pull-down resistors.
I can't find it in section 4.6.2 of following datasheet.
http://cache.nxp.com/files/32bit/doc/data_sheet/IMX6SDLIEC.pdf
Please provide the spec.
ko-hey
3,803 次查看
art
The tolerance of the i.MX6 series internal pull-up/down I/O resistors is +/- 10%.
Artur
3,804 次查看
art
Artur
3,803 次查看
ko-hey
Is the data described somewhere in RM ?
Ko-hey
