problems with cst-2.3.1
julesg
I downloaded cst-2.3.1 from this website and have unpacked the file onto a system running Ubuntu 12.04.5 LTS 64-bit. I have created the key_pass.txt and serial files as directed but when I run the hab4_pki_tree.sh script I get the following errors (taken from a log file generated by the terminal client I am using):
Tue Jan 19 15:05:59.893 2016] ++++++++++++++++++++++++++++++++++++++++
[Tue Jan 19 15:05:59.893 2016] + Generating SRK key and certificate 1 +
[Tue Jan 19 15:05:59.893 2016] ++++++++++++++++++++++++++++++++++++++++
[Tue Jan 19 15:05:59.909 2016] Generating RSA private key, 4096 bit long modulus
[Tue Jan 19 15:05:59.909 2016] ..........................................++
[Tue Jan 19 15:06:00.236 2016] ..............................................................................................................++
[Tue Jan 19 15:06:01.080 2016] e is 65537 (0x10001)
[Tue Jan 19 15:06:01.111 2016] Using configuration from ../ca/openssl.cnf
[Tue Jan 19 15:06:01.111 2016] unable to load CA private key
[Tue Jan 19 15:06:01.111 2016] 140363626993312:error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt:evp_enc.c:539:
[Tue Jan 19 15:06:01.127 2016] 140363626993312:error:23077074:PKCS12 routines:PKCS12_pbe_crypt:pkcs12 cipherfinal error:p12_decr.c:104:
[Tue Jan 19 15:06:01.127 2016] 140363626993312:error:2306A075:PKCS12 routines:PKCS12_item_decrypt_d2i:pkcs12 pbe crypt error:p12_decr.c:130:
[Tue Jan 19 15:06:01.127 2016] 140363626993312:error:0907B00D:PEM routines:PEM_READ_BIO_PRIVATEKEY:ASN1 lib:pem_pkey.c:132:
[Tue Jan 19 15:06:01.127 2016] Error opening Certificate ../crts/SRK1_sha256_4096_65537_v3_ca_crt.pem
[Tue Jan 19 15:06:01.127 2016] 140265689716384:error:02001002:system library:fopen:No such file or directory:bss_file.c:398:fopen('../crts/SRK1_sha256_4096_65537_v3_ca_crt.pem','r')
[Tue Jan 19 15:06:01.127 2016] 140265689716384:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:400:
[Tue Jan 19 15:06:01.127 2016] unable to load certificate
[Tue Jan 19 15:06:01.142 2016]
[Tue Jan 19 15:06:01.142 2016] ++++++++++++++++++++++++++++++++++++++++
[Tue Jan 19 15:06:01.142 2016] + Generating CSF key and certificate 1 +
[Tue Jan 19 15:06:01.142 2016] Generating RSA private key, 4096 bit long modulus
[Tue Jan 19 15:06:01.142 2016] ..................................................................................................................................................................................................................................++
[Tue Jan 19 15:06:02.874 2016] ...++
[Tue Jan 19 15:06:02.905 2016] e is 65537 (0x10001)
[Tue Jan 19 15:06:02.936 2016] Using configuration from ../ca/openssl.cnf
[Tue Jan 19 15:06:02.936 2016] unable to load CA private key
[Tue Jan 19 15:06:02.936 2016] 139735995864736:error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt:evp_enc.c:539:
[Tue Jan 19 15:06:02.936 2016] 139735995864736:error:23077074:PKCS12 routines:PKCS12_pbe_crypt:pkcs12 cipherfinal error:p12_decr.c:104:
[Tue Jan 19 15:06:02.936 2016] 139735995864736:error:2306A075:PKCS12 routines:PKCS12_item_decrypt_d2i:pkcs12 pbe crypt error:p12_decr.c:130:
[Tue Jan 19 15:06:02.936 2016] 139735995864736:error:0907B00D:PEM routines:PEM_READ_BIO_PRIVATEKEY:ASN1 lib:pem_pkey.c:132:
[Tue Jan 19 15:06:02.936 2016] Error opening Certificate ../crts/CSF1_1_sha256_4096_65537_v3_usr_crt.pem
[Tue Jan 19 15:06:02.936 2016] 140679265150624:error:02001002:system library:fopen:No such file or directory:bss_file.c:398:fopen('../crts/CSF1_1_sha256_4096_65537_v3_usr_crt.pem','r')
[Tue Jan 19 15:06:02.936 2016] 140679265150624:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:400:
[Tue Jan 19 15:06:02.936 2016] unable to load certificate
[Tue Jan 19 15:06:02.952 2016]
[Tue Jan 19 15:06:02.952 2016] ++++++++++++++++++++++++++++++++++++++++
[Tue Jan 19 15:06:02.952 2016] + Generating IMG key and certificate 1 +
[Tue Jan 19 15:06:02.967 2016] Generating RSA private key, 4096 bit long modulus
[Tue Jan 19 15:06:02.967 2016] ........................................................................................................................................................................++
[Tue Jan 19 15:06:04.253 2016] ....................................................................................................................................................................................................................++
[Tue Jan 19 15:06:05.877 2016] e is 65537 (0x10001)
[Tue Jan 19 15:06:05.893 2016] Using configuration from ../ca/openssl.cnf
[Tue Jan 19 15:06:05.893 2016] unable to load CA private key
[Tue Jan 19 15:06:05.908 2016] 140552183891616:error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt:evp_enc.c:539:
[Tue Jan 19 15:06:05.908 2016] 140552183891616:error:23077074:PKCS12 routines:PKCS12_pbe_crypt:pkcs12 cipherfinal error:p12_decr.c:104:
[Tue Jan 19 15:06:05.908 2016] 140552183891616:error:2306A075:PKCS12 routines:PKCS12_item_decrypt_d2i:pkcs12 pbe crypt error:p12_decr.c:130:
[Tue Jan 19 15:06:05.908 2016] 140552183891616:error:0907B00D:PEM routines:PEM_READ_BIO_PRIVATEKEY:ASN1 lib:pem_pkey.c:132:
[Tue Jan 19 15:06:05.908 2016] Error opening Certificate ../crts/IMG1_1_sha256_4096_65537_v3_usr_crt.pem
[Tue Jan 19 15:06:05.908 2016] 140225580635808:error:02001002:system library:fopen:No such file or directory:bss_file.c:398:fopen('../crts/IMG1_1_sha256_4096_65537_v3_usr_crt.pem','r')
[Tue Jan 19 15:06:05.908 2016] 140225580635808:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:400:
[Tue Jan 19 15:06:05.908 2016] unable to load certificate
I get similar errors for each SRK. Any idea what the problem could be?
Yuri
  From section 3.2.2 (Running the hab4_pki_tree script Example) of "HABCST_UG.pdf" :
"Run the hab4_pki_tree.sh script. The script will ask a series of questions:
— Do you want to use an existing CA key (y/n)?"
Please try "Choose no here ...".
Yuri
julesg
Hi Yuri,
Sorry I forgot to include the log entries from how I answered the questions when I started the script. I did answer "no" when asked about using an existing CA key ( see below).
[Tue Jan 19 15:05:33.543 2016] ./hab4_pki_tree.sh
[Tue Jan 19 15:05:35.932 2016]
[Tue Jan 19 15:05:35.932 2016]     +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
[Tue Jan 19 15:05:35.932 2016]     This script is a part of the Code signing tools for Freescale's
[Tue Jan 19 15:05:35.932 2016]     High Assurance Boot.  It generates a basic PKI tree.  The PKI
[Tue Jan 19 15:05:35.932 2016]     tree consists of one or more Super Root Keys (SRK), with each
[Tue Jan 19 15:05:35.932 2016]     SRK having two subordinate keys:
[Tue Jan 19 15:05:35.932 2016]         + a Command Sequence File (CSF) key
[Tue Jan 19 15:05:35.932 2016]         + Image key.
[Tue Jan 19 15:05:35.932 2016]     Additional keys can be added to the PKI tree but a separate
[Tue Jan 19 15:05:35.932 2016]     script is available for this.  This this script assumes openssl
[Tue Jan 19 15:05:35.932 2016]     is installed on your system and is included in your search
[Tue Jan 19 15:05:35.932 2016]     path.  Finally, the private keys generated are password
[Tue Jan 19 15:05:35.932 2016]     protectedwith the password provided by the file key_pass.txt.
[Tue Jan 19 15:05:35.932 2016]     The format of the file is the password repeated twice:
[Tue Jan 19 15:05:35.932 2016]         my_password
[Tue Jan 19 15:05:35.932 2016]     All private keys in the PKI tree are in PKCS #8 format will be
[Tue Jan 19 15:05:35.932 2016]     protected by the same password.
[Tue Jan 19 15:05:35.932 2016] Do you want to use an existing CA key (y/n)?:  n
[Tue Jan 19 15:05:45.850 2016] Enter key length in bits for PKI tree:  4096
[Tue Jan 19 15:05:49.751 2016] Enter PKI tree duration (years):  10
[Tue Jan 19 15:05:52.233 2016] How many Super Root Keys should be generated?  4
[Tue Jan 19 15:05:54.355 2016] Do you want the SRK certificates to have the CA flag set? (y/n)?:  y
[Tue Jan 19 15:05:58.676 2016]
[Tue Jan 19 15:05:58.676 2016] +++++++++++++++++++++++++++++++++++++
[Tue Jan 19 15:05:58.676 2016] + Generating CA key and certificate +
[Tue Jan 19 15:05:58.676 2016] Generating a 4096 bit RSA private key
[Tue Jan 19 15:05:58.676 2016] ...++
[Tue Jan 19 15:05:58.707 2016] ................................................................................................................................................++
[Tue Jan 19 15:05:59.831 2016] writing new private key to 'temp_ca.pem'
[Tue Jan 19 15:05:59.831 2016] -----
Yuri
Perhaps it makes sense to try under root (sudo).
Yuri.
julesg
Hi Yuri,
I tried again but this time under root using sudo but I still get the same errors. It looks like it doesn't like the CA private key that was previously generated for some reason. Why would this happen?
Yuri
  Please look at comment of  Ben Foose in the following thread
https://community.freescale.com/message/624469?et=watches.email.thread#comment-624469
Yuri.
