I am also facing the same problem while compiling latest BSP L3.0.35_1.1.0_121218_source.tar.gz. The build fails at mtd-utils package.
Below is the log:
Processing platform: Host support packages
using /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: bison
Processing: flex
Processing: texinfo
Processing: autoconf
Processing: libtool
Processing: lkc
Processing: wget
Processing: uclinux-cksum
Processing: genext2fs
Processing: genromfs
Processing: gen_init_cpio
Processing: u-boot-tools
Processing: mtd-utils
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath ///opt/freescale/ltib/var/lib/rpm --target i686 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu i686' --define '__strip strip' --define '_topdir /opt/freescale/ltib/usr/src/rpm' --define '_prefix /opt/freescale/ltib/usr' --define '_tmppath /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/usr/src/rpm/RPMS' --define '_mandir /opt/freescale/ltib/usr/share/man' --define '_sysconfdir /opt/freescale/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/dist/lfs-5.1/mtd-utils/mtd-utils.spec
Building target platforms: i686
Building for target i686
Executing(%prep): /bin/sh -e /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/tmp/rpm-tmp.83205
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ rm -rf mtd-utils
+ /bin/gzip -dc /opt/freescale/ltib/usr/src/rpm/SOURCES/mtd-utils-1.5.0.tar.gz
+ tar -xvvf -
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/
-rw-rw-r-- root/root 764 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/.gitignore
-rw-rw-r-- root/root 18007 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/COPYING
-rwxrwxr-x root/root 786 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/MAKEDEV
-rw-rw-r-- root/root 3134 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/Makefile
-rw-rw-r-- root/root 2007 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/common.mk
-rw-rw-r-- root/root 14720 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr.c
-rw-rw-r-- root/root 3343 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr.h
-rw-rw-r-- root/root 3039 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr_lzo.c
-rw-rw-r-- root/root 2659 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr_rtime.c
-rw-rw-r-- root/root 3941 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/compr_zlib.c
-rw-rw-r-- root/root 4244 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/device_table.txt
-rw-rw-r-- root/root 3301 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/doc_loadbios.c
-rw-rw-r-- root/root 8901 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/docfdisk.c
-rw-rw-r-- root/root 308 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/feature-removal-schedule.txt
-rw-rw-r-- root/root 1980 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/fectest.c
-rw-rw-r-- root/root 7570 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_erase.c
-rwxrwxr-x root/root 150 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_eraseall
-rw-rw-r-- root/root 154 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_lock.c
-rw-rw-r-- root/root 1085 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_otp_dump.c
-rw-rw-r-- root/root 1308 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_otp_info.c
-rw-rw-r-- root/root 1588 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_otp_lock.c
-rw-rw-r-- root/root 2019 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_otp_write.c
-rw-rw-r-- root/root 2158 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flash_unlock.c
-rw-rw-r-- root/root 10817 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/flashcp.c
-rw-rw-r-- root/root 6427 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ftl_check.c
-rw-rw-r-- root/root 9485 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ftl_format.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/
-rw-rw-r-- root/root 4597 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/common.h
-rw-rw-r-- root/root 294 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/crc32.h
-rw-rw-r-- root/root 11661 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/libmtd.h
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/linux/
-rw-rw-r-- root/root 7033 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/linux/jffs2.h
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/
-rw-rw-r-- root/root 2646 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/ftl-user.h
-rw-rw-r-- root/root 1674 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/inftl-user.h
-rw-rw-r-- root/root 2371 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/jffs2-user.h
-rw-rw-r-- root/root 9304 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/mtd-abi.h
-rw-rw-r-- root/root 1199 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/mtd-user.h
-rw-rw-r-- root/root 1401 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/nftl-user.h
-rw-rw-r-- root/root 16929 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/ubi-media.h
-rw-rw-r-- root/root 15492 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd/ubi-user.h
-rw-rw-r-- root/root 1903 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/mtd_swab.h
-rw-rw-r-- root/root 2469 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/include/xalloc.h
-rw-rw-r-- root/root 8622 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/jffs-dump.c
-rw-rw-r-- root/root 22295 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/jffs2dump.c
-rw-rw-r-- root/root 21350 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/jffs2reader.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/
-rw-rw-r-- root/root 5567 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libcrc32.c
-rw-rw-r-- root/root 24552 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libfec.c
-rw-rw-r-- root/root 33433 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libmtd.c
-rw-rw-r-- root/root 3629 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libmtd_int.h
-rw-rw-r-- root/root 9135 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/lib/libmtd_legacy.c
-rwxrwxr-x root/root 4309 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/load_nandsim.sh
-rwxrwxr-x root/root 2035 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/make_a_release.sh
-rw-rw-r-- root/root 1537 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mcast_image.h
-rw-rw-r-- root/root 6782 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.jffs2.1
-rw-rw-r-- root/root 48903 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.jffs2.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/
-rw-rw-r-- root/root 12 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/.gitignore
-rw-rw-r-- root/root 18007 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/COPYING
-rw-rw-r-- root/root 608 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/README
-rw-rw-r-- root/root 4680 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/compr.c
-rw-rw-r-- root/root 1437 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/compr.h
-rw-rw-r-- root/root 2618 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/crc16.c
-rw-rw-r-- root/root 599 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/crc16.h
-rw-rw-r-- root/root 1990 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/defs.h
-rw-rw-r-- root/root 14732 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/devtable.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/
-rw-rw-r-- root/root 9064 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable.c
-rw-rw-r-- root/root 7374 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable.h
-rw-rw-r-- root/root 5783 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable_itr.c
-rw-rw-r-- root/root 4086 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable_itr.h
-rw-rw-r-- root/root 2955 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/hashtable/hashtable_private.h
-rw-rw-r-- root/root 5078 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/key.h
-rw-rw-r-- root/root 15842 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/lpt.c
-rw-rw-r-- root/root 980 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/lpt.h
-rw-rw-r-- root/root 62542 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/mkfs.ubifs.c
-rw-rw-r-- root/root 4435 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/mkfs.ubifs.h
-rw-rw-r-- root/root 22044 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/ubifs-media.h
-rw-rw-r-- root/root 11642 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mkfs.ubifs/ubifs.h
-rw-rw-r-- root/root 727 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mtd-utils.spec
-rw-rw-r-- root/root 9296 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/mtd_debug.c
-rw-rw-r-- root/root 13597 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nanddump.c
-rw-rw-r-- root/root 6206 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nandtest.c
-rw-rw-r-- root/root 14637 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nandwrite.c
-rw-rw-r-- root/root 12460 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nftl_format.c
-rw-rw-r-- root/root 7826 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/nftldump.c
-rw-rw-r-- root/root 8620 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/rbtree.c
-rw-rw-r-- root/root 5247 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/rbtree.h
-rw-rw-r-- root/root 14837 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/recv_image.c
-rw-rw-r-- root/root 7315 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/rfddump.c
-rw-rw-r-- root/root 3412 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/rfdformat.c
-rw-rw-r-- root/root 7837 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/serve_image.c
-rw-rw-r-- root/root 4860 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/summary.h
-rw-rw-r-- root/root 25396 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/sumtool.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/
-rw-rw-r-- root/root 141 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/Makefile
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/
-rw-rw-r-- root/root 20 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/.gitignore
-rw-rw-r-- root/root 101 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/Makefile
-rw-rw-r-- root/root 6989 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/README
-rw-rw-r-- root/root 21657 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/checkfs.c
-rw-rw-r-- root/root 1197 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/comm.c
-rw-rw-r-- root/root 216 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/common.h
-rw-rw-r-- root/root 8520 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/checkfs/makefiles.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/
-rw-rw-r-- root/root 137 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/Makefile
-rwxrwxr-x root/root 1420 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/help_all.sh
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/integrity/
-rw-rw-r-- root/root 9 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/integrity/.gitignore
-rw-rw-r-- root/root 674 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/integrity/Makefile
-rw-rw-r-- root/root 78377 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/integrity/integck.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/lib/
-rw-rw-r-- root/root 166 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/lib/Makefile
-rw-rw-r-- root/root 30375 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/lib/tests.c
-rw-rw-r-- root/root 7328 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/lib/tests.h
-rwxrwxr-x root/root 715 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/run_all.sh
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/
-rw-rw-r-- root/root 36 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/.gitignore
-rw-rw-r-- root/root 350 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/Makefile
-rw-rw-r-- root/root 2668 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/ftrunc.c
-rw-rw-r-- root/root 4633 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/orph.c
-rw-rw-r-- root/root 5097 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/perf.c
-rw-rw-r-- root/root 4370 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/test_1.c
-rw-rw-r-- root/root 6356 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/simple/test_2.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/
-rw-rw-r-- root/root 150 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/Makefile
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/
-rw-rw-r-- root/root 99 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/.gitignore
-rw-rw-r-- root/root 511 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/Makefile
-rw-rw-r-- root/root 5820 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/fwrite00.c
-rw-rw-r-- root/root 5322 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/gcd_hupper.c
-rw-rw-r-- root/root 3646 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/pdfrun.c
-rw-rw-r-- root/root 3692 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/rmdir00.c
-rw-rw-r-- root/root 4329 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/rndrm00.c
-rw-rw-r-- root/root 10320 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/rndrm99.c
-rw-rw-r-- root/root 5282 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/rndwrite00.c
-rw-rw-r-- root/root 2655 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/stress_1.c
-rw-rw-r-- root/root 3011 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/stress_2.c
-rw-rw-r-- root/root 3129 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/atoms/stress_3.c
-rwxrwxr-x root/root 1124 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/stress00.sh
-rwxrwxr-x root/root 644 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/stress/stress01.sh
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/
-rw-rw-r-- root/root 28 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/.gitignore
-rw-rw-r-- root/root 250 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/Makefile
-rw-rw-r-- root/root 1510 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/free_space.c
-rw-rw-r-- root/root 5272 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/fs-tests/utils/fstest_monitor.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/
-rw-rw-r-- root/root 30 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/.gitignore
-rw-rw-r-- root/root 18007 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/COPYING
-rw-rw-r-- root/root 34759 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/JitterTest.c
-rw-rw-r-- root/root 1782 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/Makefile
-rw-rw-r-- root/root 6727 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/README
-rw-rw-r-- root/root 250 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/filljffs2.sh
-rw-rw-r-- root/root 10267 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/jittertest/plotJittervsFill.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/
-rw-rw-r-- root/root 102 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/.gitignore
-rw-rw-r-- root/root 702 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/Makefile
-rw-rw-r-- root/root 1253 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/README.udev
-rw-rw-r-- root/root 8942 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/common.c
-rw-rw-r-- root/root 4775 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/common.h
-rw-rw-r-- root/root 19103 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/integ.c
-rw-rw-r-- root/root 4265 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/io_basic.c
-rw-rw-r-- root/root 7460 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/io_paral.c
-rw-rw-r-- root/root 8614 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/io_read.c
-rw-rw-r-- root/root 7133 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/io_update.c
-rw-rw-r-- root/root 7348 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/mkvol_bad.c
-rw-rw-r-- root/root 5441 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/mkvol_basic.c
-rw-rw-r-- root/root 2484 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/mkvol_paral.c
-rw-rw-r-- root/root 6542 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/rsvol.c
-rwxrwxr-x root/root 616 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/runtests.sh
-rw-rw-r-- root/root 3026 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/tests/ubi-tests/volrefcnt.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/
-rw-rw-r-- root/root 124 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/.gitignore
-rw-rw-r-- root/root 1083 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/LICENSE.libiniparser
-rw-rw-r-- root/root 11442 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/dictionary.c
drwxrwxr-x root/root 0 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/
-rw-rw-r-- root/root 6589 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/dictionary.h
-rw-rw-r-- root/root 10270 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/libiniparser.h
-rw-rw-r-- root/root 3156 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/libscan.h
-rw-rw-r-- root/root 16285 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/libubi.h
-rw-rw-r-- root/root 6131 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/libubigen.h
-rw-rw-r-- root/root 1120 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/include/ubiutils-common.h
-rw-rw-r-- root/root 20001 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libiniparser.c
-rw-rw-r-- root/root 5548 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libscan.c
-rw-rw-r-- root/root 30363 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libubi.c
-rw-rw-r-- root/root 4293 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libubi_int.h
-rw-rw-r-- root/root 8463 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/libubigen.c
-rw-rw-r-- root/root 11179 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/mtdinfo.c
-rw-rw-r-- root/root 6215 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubiattach.c
-rw-rw-r-- root/root 2797 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubicrc32.c
-rw-rw-r-- root/root 5447 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubidetach.c
-rw-rw-r-- root/root 24677 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubiformat.c
-rw-rw-r-- root/root 8288 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubimkvol.c
-rw-rw-r-- root/root 11685 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubinfo.c
-rw-rw-r-- root/root 19997 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubinize.c
-rw-rw-r-- root/root 4002 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubirename.c
-rw-rw-r-- root/root 5076 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubirmvol.c
-rw-rw-r-- root/root 6284 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubirsvol.c
-rw-rw-r-- root/root 7280 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubiupdatevol.c
-rw-rw-r-- root/root 5019 2012-05-07 03:19 mtd-utils-v1.5.0-b0f3b6e/ubi-utils/ubiutils-common.c
+ STATUS=0
+ [ 0 -ne 0 ]
+ cd mtd-utils
cd: 1: can't cd to mtd-utils
error: Bad exit status from /home/lucid/working/OSI-L/L3.0.35_1.1.0_121218_source/ltib/tmp/rpm-tmp.83205 (%prep)
RPM build errors:
Build time for mtd-utils: 0 seconds
Failed building mtd-utils
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
main::host_checks:1447
main:554
Started: Tue Feb 26 16:31:07 2013
Ended: Tue Feb 26 16:31:07 2013
Elapsed: 0 seconds
These packages failed to build:
mtd-utils
Build Failed
Please let me know the cause of this error and how should I fix this?
Sumit
