plugin Gstreamer pour IMX 95
4,191件の閲覧回数
OlivierG
I'm trying to get gstreamer on Yocto on an IMX 95 verdin card with a minimal image.
I have the gstreamer executable but without any plugins.
What line should I put in local.conf for the Bitbake recipe?
I need the plugin for H264 compression, in particular.
Greetings
Olivier
9 返答(返信)
4,008件の閲覧回数
OlivierG
The problem is not the command line
The Yocto build doest not provide any gstreamer plugin.
Whatever the command, I get
ERROR: pipeline could not be constructed: no element <plugin name>
What line should i put in local.conf for the Bitbake recipe?
Greetings
Olivier
3,962件の閲覧回数
Bio_TICFSL
Yes, you build the bitbake imx-image-full, now the iMX95 still on beta phase where it can not be possible to obtain the fill gstreamer functionality.
3,944件の閲覧回数
OlivierG
I build the imx-image-full and i get the followings errors
ERROR: onnxruntime-1.17.1-r0 do_configure: ExecutionError('/home/olivier/Dev/yocto/buildImx95Full/tmp/work/armv8a-poky-linux/onnxruntime/1.17.1/temp/run.do_configure.553602', 1, None, None)
ERROR: Logfile of failure stored in: /home/olivier/Dev/yocto/buildImx95Full/tmp/work/armv8a-poky-linux/onnxruntime/1.17.1/temp/log.do_configure.553602
ERROR: Task (/home/olivier/Dev/yocto/sources/meta-imx/meta-imx-ml/recipes-libraries/onnxruntime/onnxruntime_1.17.1.bb:do_configure) failed with exit code '1'
Greetings
Olivier
3,936件の閲覧回数
Bio_TICFSL
Please download the 6.6.52 BSP that has better performance with the MX95:
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
and erase and restart for scratch yocto.
3,907件の閲覧回数
OlivierG
i upgrade to the latest version
I get:
ERROR: tensorflow-lite-2.18.0-r0 do_configure: Execution of '/home/olivier/Dev/Yocto2/buildImx95/tmp/work/armv8a-mx95-poky-linux/tensorflow-lite/2.18.0/temp/run.do_configure.1782864' failed with exit code 1
ERROR: Logfile of failure stored in: /home/olivier/Dev/Yocto2/buildImx95/tmp/work/armv8a-mx95-poky-linux/tensorflow-lite/2.18.0/temp/log.do_configure.1782864
ERROR: Task (/home/olivier/Dev/Yocto2/sources/meta-imx/meta-imx-ml/recipes-libraries/tensorflow-lite/tensorflow-lite_2.18.0.bb:do_configure) failed with exit code '1'
I precise that i need tensorflow
Greetings
Olivier
3,805件の閲覧回数
OlivierG
Finally the problem is due to a download problem du to the firewall
Olivier
3,900件の閲覧回数
Bio_TICFSL
The error is different to the first thread please Create a new one for this, but erase everything and reintalls
3,844件の閲覧回数
OlivierG
I started from a blank directory
the error is due to a download problem
https://gitlab.arm.com/kleidi/kleidiai/-/archive/cddf991af5de49fd34949fa39690e4e906e04074/kleidiai-c...
is not available
https://github.com/ARM-software/kleidiai/archive/cddf991af5de49fd34949fa39690e4e906e04074.zip is available
i would like to modify the recipe to download this link instead
Attached the entire error log
Greetings
Olivier
4,182件の閲覧回数
Bio_TICFSL
The i.MX95 utilizes GStreamer as its multimedia framework. Specifically, the gstreamer-imx plugins, which leverage the i.MX multimedia capabilities, are used on this platform. Yocto Linux, a common embedded Linux distribution, also uses GStreamer as its default multimedia framework, you need to build the imx-image-multimedia or the imx-image-full to have it.
The i.MX95 SoC features 4K@60fps H.264/H.265 VPU decoder.
Before starting video playback, please, ensure that the display is connected to the board.
The following commands can be used to start video playback (1.mov is a media file):
  • gst-play
gst-play /path/to/1.mov
  • gplay-1.0
gplay-1.0 /path/to/1.mov
  • gst-launch
This method is for advanced users. Please study this document before the start: i.MX8GStreamerUserGuide.pdf
gst-launch-1.0 -v filesrc location=/path/to/1.mov ! qtdemux name=d.video_0 ! h264parse ! avdec_h264 ! autovideosink
%3CLINGO-SUB%20id%3D%22lingo-sub-2136558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX%2095%E7%94%A8Gstreamer%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%8F%E3%82%A4%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7%E3%80%81IMX%2095%20verdin%20%E3%82%AB%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%20Yocto%20%E3%81%A7%20gstreamer%20%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Egstreamer%20%E5%AE%9F%E8%A1%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EBitbake%20%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81local.conf%20%E3%81%AB%E3%81%A9%E3%81%AE%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E7%89%B9%E3%81%AB%E3%80%81H264%20%E5%9C%A7%E7%B8%AE%E7%94%A8%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%88%E3%82%8B%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3E%E7%A9%BA%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgitlab.arm.com%2Fkleidi%2Fkleidiai%2F-%2Farchive%2Fcddf991af5de49fd34949fa39690e4e906e04074%2Fkleidiai-cddf991af5de49fd34949fa39690e4e906e04074.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.arm.com%2Fkleidi%2Fkleidiai%2F-%2Farchive%2Fcddf991af5de49fd34949fa39690e4e906e04074%2Fkleidiai-cddf991af5de49fd34949fa39690e4e906e04074.zip%3C%2FA%3E%3CBR%20%2F%3E%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FARM-software%2Fkleidiai%2Farchive%2Fcddf991af5de49fd34949fa39690e4e906e04074.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FARM-software%2Fkleidiai%2Farchive%2Fcddf991af5de49fd34949fa39690e4e906e04074.zip%3C%2FA%3E%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%AC%E3%82%B7%E3%83%94%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%E5%85%A8%E4%BD%93%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AEThread%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E5%86%8D%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3E%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%BE%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20tensorflow-lite-2.18.0-r0%20do_configure%3A%20'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Folivier%2FDev%2FYocto2%2FbuildImx95%2Ftmp%2Fwork%2Farmv8a-mx95-poky-Linux%2Ftensorflow-lite%2F2.18.0%2Ftemp%2Frun.do_configure.1782864'%20%E3%81%AE%E5%AE%9F%E8%A1%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%891%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Folivier%2FDev%2FYocto2%2FbuildImx95%2Ftmp%2Fwork%2Farmv8a-mx95-poky-Linux%2Ftensorflow-lite%2F2.18.0%2Ftemp%2Flog.do_configure.1782864%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20(%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Folivier%2FDev%2FYocto2%2Fsources%2Fmeta-imx%2Fmeta-imx-ml%2Frecipes-libraries%2Ftensorflow-lite%2Ftensorflow-lite_2.18.0.bb%3Ado_configure)%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFTensorflow%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A0%E3%81%A8%E6%98%8E%E7%A2%BA%E3%81%AB%E8%A8%80%E3%81%86%3C%2FP%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMX95%20%E3%81%A7%E3%82%88%E3%82%8A%E5%84%AA%E3%82%8C%E3%81%9F%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E7%99%BA%E6%8F%AE%E3%81%99%E3%82%8B%206.6.52%20BSP%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%82%AF%E3%83%A9%E3%83%83%E3%83%81%20yocto%20%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3Eimx-image-full%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20onnxruntime-1.17.1-r0%20do_configure%3A%20ExecutionError('%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Folivier%2FDev%2FYocto%2FbuildImx95Full%2Ftmp%2Fwork%2Farmv8a-poky-Linux%2Fonnxruntime%2F1.17.1%2Ftemp%2Frun.do_configure.553602'%2C%201%2C%20None%2C%20None)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Folivier%2FDev%2FYocto%2FbuildImx95Full%2Ftmp%2Fwork%2Farmv8a-poky-Linux%2Fonnxruntime%2F1.17.1%2Ftemp%2Flog.do_configure.553602%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20(%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Folivier%2FDev%2FYocto%2Fsources%2Fmeta-imx%2Fmeta-imx-ml%2Frecipes-libraries%2Fonnxruntime%2Fonnxruntime_1.17.1.bb%3Ado_configure)%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81bitbake%20imx-image-full%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81iMX95%20%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%99%E3%83%BC%E3%82%BF%20%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81gstreamer%20%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E6%A9%9F%E8%83%BD%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3EYocto%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%AF%20gstreamer%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AF%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%82%93%E3%81%AA%E5%91%BD%E4%BB%A4%E3%81%A7%E3%82%82%E7%A7%81%E3%81%AF%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%3CBR%20%2F%3E%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20%E8%A6%81%E7%B4%A0%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CPLUGIN%20name%3D%22%22%3E%3C%2FPLUGIN%3E%3C%2FP%3E%3CP%3EBitbake%20%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AE%20local.conf%20%E3%81%AB%E3%81%A9%E3%81%AE%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%B4%E3%82%A3%E3%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20plugin%20Gstreamer%20pour%20IMX%2095%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%2217349224196443715229%22%3Ei.MX95%E3%81%AF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6GStreamer%E3%82%92%E6%8E%A1%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%2217349224196443716500%22%3E%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81i.MX%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E6%A9%9F%E8%83%BD%E3%82%92%E6%B4%BB%E7%94%A8%E3%81%99%E3%82%8Bgstreamer-imx%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E3%81%93%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%2217349224196443713675%22%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BFLinux%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8BYocto%20Linux%E3%82%82%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6GStreamer%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82GStreamer%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81imx-image-multimedia%E3%81%BE%E3%81%9F%E3%81%AFimx-image-full%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ei.MX95%20SoC%20%E3%81%AF%E3%80%814K%4060fps%20H.264%2FH.265%20VPU%20%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E5%86%8D%E7%94%9F%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E5%86%8D%E7%94%9F%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20(%20%3CSTRONG%3E1.mov%3C%2FSTRONG%3E%E3%81%AF%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99)%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Egst%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CPRE%20translate%3D%22no%22%3Egst-play%20%2Fpath%2Fto%2F1.mov%0A%3C%2FPRE%3E%0A%3CUL%3E%0A%3CLI%3Egplay-1.0%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CPRE%20translate%3D%22no%22%3Egplay-1.0%20%2Fpath%2Fto%2F1.mov%0A%3C%2FPRE%3E%0A%3CUL%3E%0A%3CLI%3EGST%E3%83%AD%E3%83%BC%E3%83%B3%E3%83%81%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E4%B8%8A%E7%B4%9A%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%91%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E5%A7%8B%E3%82%81%E3%82%8B%E5%89%8D%E3%81%AB%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20class%3D%22external%20text%22%20href%3D%22https%3A%2F%2Fraw.githubusercontent.com%2Fcompulab-yokneam%2FDocumentation%2Fmaster%2Fpdfs%2Fi.MX8GStreamerUserGuide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX8GStreamerUserGuide.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Egst-launch-1.0%20-v%20filesrc%20location%3D%2Fpath%2Fto%2F1.mov%26nbsp%3B!%20qtdemux%20name%3Dd.video_0%26nbsp%3B!%20h264parse%26nbsp%3B!%20avdec_h264%26nbsp%3B!%20autovideosink%3C%2FPRE%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
