package installation on pre-built linux
3,448 次查看
uriuri
i am new to this board
i want to ask, is it possible to install package like opencv or tensorflow lite to the pre-built linux installed at emmc? if possible can you tell me how to do it?
also it seems i get error when trying the apt-get update
thx
4 回复数
3,421 次查看
Harvey021
Have a try with command dpkg
Harvey
3,260 次查看
uriuri
in the end i building the yocto from beginning, bc it is easier than using dpkg
3,406 次查看
uriuri
ok lemme try it first
but installing package with dpkg really abit troublesome
also can i ask if the pre-built linux on emmc is same as bsp linux on the start guide embedded linux part?
3,404 次查看
Harvey021
Should be same.
Harvey
