overlay filesystem to mount root filesystem on RAM
2,403 次查看
rvignesh496
I'm working on imx6ull14x14evk board, and I'm new to yocto build.
Currently I'm observing that the root filesystem is mounted in the nand-flash, but I want to create a overlay fs and mount the root filesystem in ram.
How can this be done?
Thanks in advance
2,394 次查看
Hi Vignesh
may be useful tutorial below
https://imxdev.gitlab.io/tutorial/How_to_boot_imx_using_ramdisk/
2,395 次查看
Hi Vignesh
