on the imx-gpu-viv-6.4.0.p1.0 version, there are specific opengl library for wayland and x11 however there is no opengl binary for framebuffer for 32bit gpu driver. In Yocto Project, you create a dummy opengl library then it is used as main opengl library when we compile with framebuffer backend in Yocto.
You don't support for framebuffer and x11 support for imx8 series. Do you plan to drop framebuffer your support for 32bit arhitecture?
