no ipu interrupts sometimes
1,260 次查看
pravverma
Our coustom board is based on i.mx53 & we are using linux 2.6.35.
We are using mxc_v4l2_overlay.out application to capture & display.
Everything works fine, but sometimes there is no data on display.
We found that when there is no data on display, there is no ipu interrupt generated.
In working/non-working case, the code flow is same & there is no error.
I am not sure why the ipu interrupt is not getting generated sometimes?
Please help us to understand the problem.
Praveen
标签 (2)
1,153 次查看
Bio_TICFSL
Hi praveen,
If there is any issue, you should see some error/warning messages in your console, also make sure to enable the camera input modprobe mxc_v4l2_capture. I suggest to read Chapter 11 of you MX53 BSP documentation linux reference manual in order to check all options and usage of the ipu unit test codes.
